Samtheguy said:Also, the gain would be given by -Rf/Rin, therefore, -1M/100K = -10
Samtheguy said:Thanks for your reply. To caluate the DC gain (without feedback) would I use:
A_d = 2x10^5 / (1+jf/7) and set f=0 since it is DC. Therefore, I get A_d = 2x10^5. In dB, this is a gain of 106.02 dB. To find the -3dB point, do 106.02 - 3 = 103.02dB and convert back to magnitude using, 10^(103.02/20) = 141579.
Am I on the right path to the solution?
Samtheguy said:The magnitude of (1+j) is sqrt(2) or 1.414. So therefore f would be 7Hz at the -3dB point.
Samtheguy said:Okay. So Gain-bandwidth product = Open-loop gain X cut-off frequency. Is this the answer to the small signal bandwidth or is there a lot more computation to do? (I'm guessing there is more to do)
An operational amplifier is an electronic device that amplifies the input voltage signal and outputs a larger version of the signal. It consists of a high-gain differential amplifier and additional circuitry to provide desired characteristics such as high input impedance, low output impedance, and a wide range of frequency response. The input voltages are compared to each other and the difference is amplified, which results in a larger output voltage.
There are two main types of op-amps: inverting and non-inverting. In an inverting op-amp, the input voltage is applied to the inverting input terminal and the output voltage is the inverted version of the input voltage. In a non-inverting op-amp, the input voltage is applied to the non-inverting input terminal and the output voltage is the same polarity as the input voltage. Other types include summing, differential, and instrumentation op-amps, which have different configurations and purposes.
To analyze an op-amp circuit, you can use the golden rules of op-amps. These rules state that the input currents are zero, the input voltages are equal, and the output voltage is such that the difference between the input voltages is amplified by the gain of the op-amp. To solve problems, you can use circuit analysis techniques such as Kirchhoff's laws and Ohm's law to determine the values of the unknown components in the circuit.
Op-amps have a wide range of applications, including signal amplification, filtering, and signal conditioning. They are commonly used in audio and video equipment, sensors, and control systems. They are also used in mathematical operations such as addition, subtraction, differentiation, and integration. Additionally, op-amps are used in feedback circuits to stabilize and control the gain of the circuit.
When choosing an op-amp, you should consider factors such as the required input and output voltage ranges, the desired gain and bandwidth, and the power supply requirements. Other important considerations include the input and output impedance, noise level, and temperature range. It is important to carefully read the datasheet of the op-amp to ensure that it meets your specific needs for your application.
