Operator algebra: Hermicity and Eigenstates
In summary, "Operator algebra: Hermicity and Eigenstates" discusses the fundamental principles of operator theory in quantum mechanics, focusing on the properties of Hermitian operators and their significance in determining eigenstates. It emphasizes that Hermitian operators have real eigenvalues and orthogonal eigenstates, which are essential for the physical interpretation of quantum systems. The text further explores the implications of these properties for the measurement process and the stability of quantum states, highlighting the role of operator algebra in understanding quantum behavior.
physicsxanime
See screenshot next
hermitian operator ##A^\dagger = A##
antihermitian operator ##A^\dagger = -A##
A. I can show that A is either hermitian or antihermitian by
$$(B^\dagger B=1-A^2)^\dagger$$
$$B^\dagger B=1-A^\dagger A^\dagger$$
comparing, we know that
$$A^\dagger = \pm A$$
I don't know how I can make use of the communtation relation to get hermiticity of B. But I know that A and B must have same hermiticity because hermitian * antihermitian = 0 and the communtation relation will not make sense.
B. The fact that the question hints on only the other eigenstate is weird, does the above imply A and B are 2x2?
Anyway, consider the state ##B|a=0>##
$$AB|a=0> = BA|a=0> + B|a=0> = 0 + B|a=0>$$
Therefore, ##B|a=0>## is a eigenstate of eigenvalue 1.
C. This need result in A.
note that we can work in the basis of A
##|a=0> =
\begin{pmatrix}
1\\
\end{pmatrix}
##B|a=0> =
\begin{pmatrix}
0\\
\end{pmatrix}
We see ##B
\begin{pmatrix}
0\\
\end{pmatrix}
= B^2|a=0> = \pm B^\dagger B|a=0> = \pm(1-A^2)|a=0> = \pm |a=0>
Very simple matrix to diagonalize
physicsxanime said:
Homework Statement: See screenshot next
Relevant Equations: hermitian operator ##A^\dagger = A##
##(B^†B=1−A^2)^†##
##B^†B=1−A^†A^†##
##A^†=±A##
I don't see how from $$B^\dagger B=1-A^2$$ you get $$A^\dagger = \pm A$$
Consider the following counterexample:
##A =\begin{pmatrix}
0 &1\\
0 &0\end{pmatrix}##
##B =\begin{pmatrix}
1 &0\\
0 &1\end{pmatrix}##
0 &1\\
0 &0\end{pmatrix}##
1 &0\\
0 &1\end{pmatrix}##
How is that a counterexample? Those two matrices don't even satisfy the first condition of the problem listed under ##2.##: ##[A,B]=AB-BA=0\neq B##.
It is a counterexample to the OP derivation in part A, where the OP does not use the condition ##[A,B]=B##.
Likes physicsxanime and PeroK
Yes, I should be more careful. The proof is comparing second condition from question with the hermitian conjugate of it, we have:
$$AA = A^\dagger A^\dagger$$
This can be satisfied only with either ##AA=A^\dagger A^\dagger=0## or ##A^\dagger = \pm A##
Then I compare and by imposing imposing ##A^2 = 0##
$$[A,[A,B]] = B$$
$$-2ABA = B$$
with
$$A[A,B] = AB$$
$$-ABA = AB$$
Since ##B^\dagger B = 1## I can show a contradiction from these.
Therefore, ##A^\dagger = \pm A## is established.
Also, I am thinking I can prove ##A## is symmetric.
Consider
$$[A,B] = B$$
$$AB-BA = B$$
$$AB= B(1+A)$$
$$B^\dagger AB= B^\dagger B(1+A)$$
$$B^\dagger AB= (1+A^2)(1+A)$$
$$(B^\dagger AB= (1+A^2)(1+A))^\dagger$$
$$\pm B^\dagger AB= (1+A^2)(1\pm A)$$
Comparing 5th and last line, ##A## has to be symmetric.
physicsxanime said:
[...] comparing second condition from question with the hermitian conjugate of it, we have:
These are not the only possibilities. To see why, decompose A into hermitian and skew-hermitian parts, i.e.,
$$\mbox{Let}~~ A ~=~ X + Y ~,~~~ \mbox{where}~~ X^\dagger = X ~,~~~ \mbox{and}~~ Y^\dagger = -Y ~.$$(Do you know how to prove that A can always be decomposed like this?)
With this decomposition, the equation ##\,AA = A^\dagger A^\dagger\,## gives
$$(X + Y)(X + Y) ~=~(X + Y)^\dagger (X + Y)^\dagger $$$$X^2 + XY + YX + Y^2 ~=~ (X^\dagger)^2 + X^\dagger Y^\dagger + Y^\dagger X^\dagger + (Y^\dagger)^2 ~=~ X^2 - XY - YX + Y^2$$$$\Rightarrow~~ (XY + YX) ~=~ - (XY + YX) ~,~~~ \Rightarrow~ XY + YX = 0 ~.$$I.e., X and Y anticommute.
Of course, ##X=0## or ##Y=0## are possibilities, but not the most general ones.
Likes physicsxanime
The question mentions the other eigenstates of A, so no reason to assume only 2.
Likes physicsxanime
@physicsxanime : where did this exercise come from? Please post a link or reference.
Likes renormalize
It turns out that the commutation relation stated above in 2 is that of the generators aff(1) of the 2-parameter, non-abelian 1D affine group Aff(1) (see, e.g., https://math.stackexchange.com/questions/223496/example-of-two-dimensional-non-abelian-lie-algebra). In a 2x2 matrix realization of aff(1), a general element can be written as: $$
\left(\begin{array}{cc}
a & b\\
0 & 0
\end{array}\right)
$$In particular, defining:$$
A\equiv\left(\begin{array}{cc}
1 & 0\\
0 & 0
\end{array}\right),\:B\equiv\left(\begin{array}{cc}
0 & e^{i\phi}\\
0 & 0
\end{array}\right)
$$it's easy to verify that ##\left[A,B\right]=B## and:$$
B^{\dagger}B=1-A^{2}=\left(\begin{array}{cc}
0 & 0\\
0 & 1
\end{array}\right)
$$as required. So ##A## is hermitian and symmetric, and ##B## is neither hermitian nor antihermitian (as anticipated by @strangerep in a private conversation).
Likes physicsxanime
a & b\\
0 & 0
\end{array}\right)
1 & 0\\
0 & 0
0 & e^{i\phi}\\
0 & 0
\end{array}\right)
0 & 0\\
0 & 1
\end{array}\right)
Thanks so much! If you have spare time, I would really benefit from knowing your motivation on how you come up with a solution and that how one can anticipate the result before the calculation.
For now, it seemed to me that you either know the existence of such group or you don't. At the end of the day what are some ways I can use to figure out the anwser?
Here is my "proof" (from the private conversation mentioned by @renormalize), that if ##A## is hermitian, then ##B## cannot have definite hermiticity...
Suppose ##A^\dagger = A##. Then, $$B ~=~ [A,B]~, ~~~\Rightarrow~~ B^\dagger ~=~
[B^\dagger, A^\dagger] ~=~ [B^\dagger, A] ~=~ -[A,B^\dagger] ~.$$So IF B has definite hermiticity, i.e., if ##B = \pm B^\dagger##, then we have ##\pm B = \mp [A,B]##, hence ##B = -[A,B]##, and so ##B=0## (comparing with the original commutation rule).
Instead, if ##A^\dagger = -A##, then, $$B ~=~ [A,B]~, ~~~\Rightarrow~~ B^\dagger
~=~ [B^\dagger, A^\dagger] ~=~ [B^\dagger, -A] ~=~ [A,B^\dagger] ~,$$which seems to have no useful implications. I still don't see how one can prove that A must be hermitian.
Separately,... about "you either know the existence of such group or you don't"... yes,... theoretical physicists are supposed to be very familiar with lots of group theory and representations.
Actually, for this problem you don't need any Lie-algebra knowledge once you make the "mental leap" to representing the operators ##A,B## as finite-dimensional square matrices. It's then natural to start playing with the smallest such matrices, which are 2x2. And it doesn't take much experimenting before you realize that a pair of two 2x2 matrices, containing only a single non-zero entry in each, can be chosen to satisfy both the commutation relation ##[A,B]=B## and the constraint ##B^{\dagger}B=1-A^{2}##.
FAQ: Operator algebra: Hermicity and Eigenstates
What is operator algebra in the context of quantum mechanics?
Operator algebra in quantum mechanics refers to the mathematical framework used to describe physical observables and states. Operators are mathematical entities that act on the wave functions of quantum systems, and they can represent measurable quantities such as position, momentum, and energy. The algebraic properties of these operators, including their commutation relations, are crucial for understanding the underlying physical principles of quantum mechanics.
What does it mean for an operator to be Hermitian?
An operator is considered Hermitian (or self-adjoint) if it satisfies the condition that its adjoint (or conjugate transpose) is equal to the operator itself. Mathematically, an operator \( A \) is Hermitian if \( A^\dagger = A \). Hermitian operators have real eigenvalues and their eigenstates corresponding to different eigenvalues are orthogonal, making them suitable for representing observable quantities in quantum mechanics.
Why are eigenstates important in quantum mechanics?
Eigenstates are important in quantum mechanics because they represent the states of a quantum system that yield definite values (eigenvalues) when measured. When a measurement is performed on a system described by a Hermitian operator, the system collapses into one of its eigenstates, and the corresponding eigenvalue is the result of the measurement. This property is fundamental to the interpretation of quantum mechanics and the probabilistic nature of measurements.
How do you determine the eigenvalues and eigenstates of a Hermitian operator?
To determine the eigenvalues and eigenstates of a Hermitian operator, one typically solves the eigenvalue equation \( A \psi = \lambda \psi \), where \( A \) is the Hermitian operator, \( \psi \) is the eigenstate, and \( \lambda \) is the eigenvalue. This involves substituting the operator into the equation and solving for \( \lambda \) and \( \psi \). The solutions provide the eigenvalues and the corresponding eigenstates, which can often be found using techniques such as diagonalization or perturbation theory.
What is the significance of the orthogonality of eigenstates?
The orthogonality of eigenstates is significant because it ensures that measurements of different observables do not interfere with each other. If two eigenstates correspond to different eigenvalues of a Hermitian operator, they are orthogonal, meaning that their inner product is zero. This property allows for a clear distinction between different measurement outcomes and is essential for the completeness of the quantum state space, enabling the construction of a basis for representing any quantum state.
