Operator mapping in Hilbert space
In summary, the conversation discusses the operator L, given by the expression (d/dx + ia), and its application on the subspace C and R, which leads to the conclusion that L can be written as L: H -> H, where H is a Hilbert space with subspaces C and R. However, there is confusion about the subspaces and their relation to L, as well as the projection of L on x. The conversation also mentions the position and momentum operators and their commutation with L, but there is a lack of understanding about operators acting on functions and functional composition. It is suggested that the individual may have jumped into the deep end of functional analysis without sufficient mathematical background.
SeM
Hi, I have an operator given by the expression:
L = (d/dx +ia) where a is some constant. Applying this on x, gives a result in the subspace C and R. Can I safely conclude that the operator L can be given as:
\begin{equation}
L: \mathcal{H} \rightarrow \mathcal{H}
\end{equation}
where H is Hilbert space, with subspaces C and R ?
I think you have a confusion of ideas here. I'm not sure where the subspaces come into it.
I thought C and R , being complex and real, are both subspace to the entire space H, composed of R and C. Disregarding the term "subspace", does this look reasonable?
The reason I am not sure is because the projection of L on x (which can be any real value) goes from R to R and C. Is this generalized form right?
\begin{equation}
L : \mathcal{H} \rightarrow \mathcal{H}
\end{equation}
The reason I am not sure is whether the projection of L on x, being from x (which can be any real value) onto R and C, is correctly given by the form:
\begin{equation}
\end{equation}
What Hilbert space are we talking about here?
Lx, where x are real values.
L is doing something to z, it is transforming it to 1 +i ax. If x is in R, and R is Hilbert space, then Lx is R and C, still Hilbert space?
Sorry, none of that makes much sense. If ##L## is a differential operator it must be acting on functions, not on real or complex numbers.
It is acting on a function y(x) = x. It is written above
In that case, as you have defined it, we have:
##Lx = iax +1##
Which is another function.
So, iax+1 and x are both two functions , respectively in C and R and in R. What can one say about this, in a Hilbert space?
But you've written something with the variable ##x##, then ##z## and now ##y##. Can you just say, which spaces you're talking about? Perhaps with a complete example.
There is nothing exotic about Hilbert spaces and examples are many. So again:
Me neither.
No, in this context ##\mathbb{C}## and ##\mathbb{R}## are fields of scalars. They are not subspaces of a Hilbert Space of functions.
I have this operator, L, and I Have to explain what it does in a Hilbert space on two other operators, the position operator x, and the momentum operator d/dx.
In Kreyszig Functional Analaysis it says:
Let T: H -> H be a bounded inear operator on a complex Hilbert space H.
How does this NOT apply on L? Can't I write:
L: H -> H ?
L: H -> H ?
Your grasp of the material is such that it is difficult to follow what you are asking.
Have you jumped into a functional analysis text on a digression from QM?
I don't think it is a digression indeed. QM and Hilbert spaces go hand in hand. I have to analyze an operator for its properties in a Hilbert space, and its commutation with other operators. The latter is OK. The former, I am not sure.
If the Operator L is acting on say the position operator x, and it is composed of d/dx + ia, what can one say about this operator in a Hilbert space? And please answer at least something instead of asking me more questions, if possible.
Thanks
Thanks
A study of pure functional analysis requires considerable mathematical prerequisites. And, although QM relies on Hilbert Spaces, the mathematical treatment of Hilbert Spaces goes much deeper than is required for an initial study of QM.
In this case, you are confused by the concepts of operators acting on functions in your Hilbert space and operators being combined through functional composition.
I believe you have jumped in the mathematical deep end here.
Likes George Jones
Your question might be:
What is the commutator of ##L## and ##\hat{x}##?
Likes SeM
L: H -> H ?
Are you trying do do a particular problem in Kreysyzig? If so, which one?
Echoing PeroK;
As functional analysis books go, Kreyszig (my text as a student long before my beard turned white) requires less mathematical prerequisites (e.g., no measure theory or topology) and is more pedagogical than most other functional analysis texts, but even it requires a dose of mathematical sophistication that is administered through material like elementary real analysis.
Quantum mechanics can provide motivation to learn a bit of functional analysis for interest's sake, but the functional analysis does not often help with quantum mechanics, and can actually hinder one's progress in quantum mechanics, i.e., the rigour gained can cause rigour mortis to set in.
Personal digression: Kreyszig's son was a fellow student in a numerical analysis course that I took.
Likes PeroK
Hi Perok, I have investigated the commutation algebra, and it is fine. I found out , as another post I put on the QM section, that this operator has more algebraic combinations with the imaginary position operator, ix, which is what you write here?
This goes a little bit out of the scope of the project. My project is simply to answer the very general request by the tutor:
"The set up of the Hamiltonian requires a proper set up (i.e. Hilbert space etc)". Can you imagine now, why I am am confused?
I'm confused! In any case, I don't understand what question you are asking.
Likes SeM
Me neither, because I don't understand the tutor's request, and he doesn't want to specify more...
Specifically he says " "The set up of the Hamitonian requires a proper set up (Hilbert space, etc). Since the student does not motivate a concrete system in which the newly proposed Hamiltonian could be explored, this point is crucial."
No, I am using Kreyszig Operator Algebra to list up the properties of an own operator. I have gone through the commutation algebra. However, when I try to show the operator's properties in a Hilbert space, I am not sure my proof shows that the operator is applicable (or acting) in a Hilbert space. How does one prove that an operator can transform a function, say f= e^ipx in a Hilbert space, even though it is evident from doing a simple operation with it on f?
Dear Perok, why did you bring in the hat operator? Is it because of the mapping of L: H-> H ? Sorry, but much of this is new to me.
I'm sure something must be lost in translation here. In any case, this statement is not a question or problem that I can help you with.
Note that I used ##\hat{x}## as the position operator, to distinguish it from a point ##x## or the function ##f(x) = x##.
You need to talk to your tutor and straighten out what exactly it is that he wants you to learn.
Thanks for the clarification. Yes, this and the momentum operators have been clarified already for commutation. All well!
Well, if ##x## lives in the set of real numbers, then ##e^{ipx}## does not live in the standard Hilbert space of (equivalence classes of) square-integrable functions. Restricting ##x## (i.e., the domain of the functions) to the bounded interval ##\left[a , b\right]## seems to help, but, in this case, the momentum operator is unbounded (see page 569). Then, by page 525, a self-adjoint moment momentum operator can't have the Hilbert space all the square-integrable functions on ##\left[a , b\right]## as its domain. Done "properly", this stuff is quite subtle.
Likes SeM
This is what I was hoping for! Thanks! I will give this a thought for a few days.
PS: The restriction to L^2[a,b] works for the operator, and that makes it Hilbert space. If the wavefunction is completely different from the given, and is hermitian, and it normalizes to 1 in the interval a b, then both the Operator and the hermitian solution are all in the Hilbert space, right?
PS: George, does this mean that any solution to a Hamiltonian in a Hilbert space must be continuous and square-integrable and must satisfy ALL the fundamental prescriptions of quantum mechanics, or just the two mentioned here?
A second thing: A Hamitlonian transforms a wavefunction to give a result, whether it is the energy in the Schrödinger eqn, or some other solution. That function is transformed by a i.e derivation. If the Hamiltonian (L) is deriving a wavefunction, and that wavefunction is hermitian, does it automatically mean that L is projecting the wavefunction into its derivative (in the same space)? So L: H-> H , where the wfn is in H before and after the operation? Is the plain and simple confirmation of the action of an operator in Hilbert space?
PS: Being entirely frank, I need to clarify a thing. What does this really mean?
\begin{equation}
\end{equation}
I thought it means that an operator L is doing some operation on some function in Hilbert space H, and its product is still in Hilbert space. For instance, a square integrable function is operated on, and it yields a second square-integrable function, where both, before and after the arrow, are in Hilbert space?
Thanks!
\begin{equation}
\end{equation}
Thanks!
Yes, that's what it means. It's really just the definition of a function, ##L##, from a set ##\mathcal{H}## to itself (*).
Note that ##\mathcal{H}## is the Hilbert space (in this case of square integrable functions).
But, you know, if you need to ask these questions, you need a crash course in pure mathematics before you dive into functional analysis.
(*) Note that mathematically unless you specify more, then that is all it means. However, in this case there are probably other statements like:
Let ##L## be a linear operator. Or let ##L## be defined by ... etc.
  • #31
Its inverse, I had an Advanced Mathematics course in my PhD last year, and I am MORE interested in this and reading on my own, while doing other courses which are completely irrelated. So I take I am doing all I can at the moment. I remember stupid questions are the foundation for many things I have learned, and I ask them places where no one can see me, like here.
Thanks for this Perok. This L, is actually a linear operator, and I take that an example where H is not H anymore would be:
\begin{equation}
P: \mathcal{H} \rightarrow \mathcal{O}
\end{equation}
would be where that operator P, the integral, is sending the function to a different space, i.e. an integration such as this:
\begin{equation}
\int x dxdy = 1/2x^2 + xy
\end{equation}
which is an example of an operation on a one dimensional function , x, making it a two dimensional function when integrated with respected to dx and dy?
Is this an example of
\begin{equation}
\end{equation}
Thanks!
  • #32
A simpler example of a function that is not a linear operator is the norm. In any Hilbert space you have an inner product and if you take the inner product of a vector with itself you get the norm (squared). So, you could have:
##N: \mathcal{H} \rightarrow \mathbb{R}##
Defined by
##N(f) = ||f|| \equiv \langle f, f \rangle ^{1/2}##
Another, very important example, is the idea of a Linear Functional. Take any function ##f \in H##. Define:
##L_f : H \rightarrow \mathbb{C}##
where ##L_f(g) = \langle f, g \rangle##
In this case, therefore, ##L_f## maps each function to a complex number. Note that for every ##f \in H## you have a linear functional ##L_f##. The set of all linear functionals is called the Dual Space ...
Another example, which I think you are getting at is where the ##L## is an operator, but it produces functions that lie outside the Hilbert Space. For example, you take ##H## to be the space of square integrable functions on some interval ##[a, b]##, where the functions vanish at ##a## and ##b##. That is:
If ##f \in H##, then ##f(a) = f(b) = 0##
Now, the differential operator ##L = \frac{d}{dx}## maps functions to functions that may not vanish at the end-points. In this case, ##L## maps functions in the original Hilbert space into a different space, that involves a wider class of functions.
But, you know, I don't really have time to teach anyone functional analysis!
Likes SeM
  • #33
Defined by
If ##f \in H##, then ##f(a) = f(b) = 0##Now, the differential operator ##L = \frac{d}{dx}## maps functions to functions that may not vanish at the end-points. In this case, ##L## maps functions in the original Hilbert space into a different space, that involves a wider class of functions.
You pretty much just did! And thanks for the confirmation. I noticed in the book by Kreyszig, that he showed an operator which did like you wrote here, mapping into another spce, where he drawed a sketch of a plane (where one function was before operation) and a perpendicular plane over it, where the function "was sent to" after operation. That sketch illustrated a lot, however, one who is not experienced asks:
Why write a strangely simple formula as this:
\begin{equation}
\end{equation}
where one describes that a function from space H is operated to another function in the same space, or as you wrote, a function "from a space H on itself H".
I understand George's example, where one confirms that an operator : is producing an output in H of an input in H, which is square integrable in H before and after operation. This is directly confirming that one or even two of the fundamental pescriptions of quantum mechanics are preserved with THAT operator, by that simple statement:\begin{equation}
\end{equation}
But why not use this alternative to confirm square integrable of a function?
\begin{equation}
L : \mathbb{R}, \mathbb{C} \rightarrow \mathbb{R}, \mathbb{C}
\end{equation}
Is it because one ALWAYS assumes that H is both R and C?
Thanks! Have a good weekend!
  • #34
\begin{equation}
\end{equation}
That notation makes no sense, as ##H## is a set/space/Hilbert Space of functions. It's not a set of numbers. An "operator" is just a function that maps functions to functions (or vectors to vectors).
In finite-dimensional vector spaces, Linear Operators are represented by matrices. But, the set of square integrable functions is actually an infinite dimensional vector space. And, this makes this more complicated than the finite-dimensional case.
Note that finite dimensional Hilbert Spaces turn up in QM when you consider spin, for example. And,in these cases, the linear operators are indeed represented by matrices: e.g. the Pauli spin matrices.
You may be confused because both ##\mathbb{R}## and ##\mathbb{C}## are, in fact, Hilbert spaces in their own right. But, in terms of square-integrable functions and QM this is irrelevant.
In terms of Hilbert spaces, very roughly, you have:
##\mathbb{C}## - not relevant to QM as a Hilbert space, but as a field of scalars
##\mathbb{C}^n## - Hilbert spaces in which spin states reside
##\mathcal{H} \equiv L^2## - Hilbert space in which wavefunctions reside.
Likes SeM
  • #35
PeroK said:
A simpler example of a function that is not a linear operator is the norm. In any Hilbert space you have an inner product and if you take the inner product of a vector with itself you get the norm (squared). So, you could have:Another, very important example, is the idea of a Linear Functional. Take any function ##f \in H##. Define:
Just to add that Riesz representation theorem states that every element of the continuous dual can be written in this way for some fixed ##f##, in case that may help the conversation .
Likes SeM
<h2> What is operator mapping in Hilbert space?</h2><p>Operator mapping in Hilbert space is a mathematical concept used in quantum mechanics to describe the relationship between operators and vectors in a Hilbert space. It involves mapping operators, which represent physical observables, onto vectors, which represent the states of a quantum system.</p><h2> How is operator mapping used in quantum mechanics?</h2><p>In quantum mechanics, operator mapping is used to calculate the expectation values of physical observables, such as position, momentum, or energy. By mapping an operator onto a vector, we can determine the probability of measuring a particular value for that observable in the given state.</p><h2> What is the importance of operator mapping in Hilbert space?</h2><p>Operator mapping is important in Hilbert space because it provides a mathematical framework for understanding the behavior of quantum systems. It allows us to make predictions about the outcomes of measurements and to describe the evolution of quantum states over time.</p><h2> Can operator mapping be applied to other mathematical spaces?</h2><p>Yes, operator mapping can be applied to other mathematical spaces, such as Banach spaces or function spaces. However, it is most commonly used in Hilbert space due to its relevance to quantum mechanics.</p><h2> Are there any limitations to operator mapping in Hilbert space?</h2><p>One limitation of operator mapping in Hilbert space is that it only applies to linear operators, which means that it cannot be used for non-linear systems. Additionally, it may not accurately describe the behavior of systems with a large number of particles, as the Hilbert space becomes too large and complex to work with.</p>
FAQ: Operator mapping in Hilbert space
