Operator Product Expansion as shown in Schwartz
In summary, the author claims that the interaction due to the full electroweak Lagrangian should be non-local while for the lower energy 4 Fermi theory, it should be local. He also claims that if one uses the full charged current interaction Lagrangian, one gets two contractions, one for the W^{+} and the other for W^{-}.
Elmo
38
TL;DR Summary
Need help in understanding the operator product expansion as shown in Schwartz
I have included here the screen shot of the page I am referring to.I am unsure of how this non-local Lagrangian of Eqtn(32.68) has been constructed. Have they just integrated the interaction Lagrangian densities over two different sets of points (x & y) ?
If so, then why is there no P_L in there, why just a gamma matrix ?
And in this Eqtn(32.68) have they used the full electroweak theory ?
The paragraph above claims that they have integrated out the W boson ,then got this expression but then why have the written the W propagator in there as well ?
In the next step Eqtn(32.69) I don't get how the expression for the propagator is modified ie where does the DeAlembertian come from ?
From this it seems to me that the thing responsible for converting a non-local Lagrangian to a local one,is simply the position space delta function resulting from the momentum integral of the exponential.
From what I understand, the interaction due to the full electroweak Lagrangian should be non-local while for the lower energy 4 Fermi theory, it should be local. So would the answer have been the same had they used the 4 Fermi theory instead ?
He seems to invent names for himself. There are no non-local Lagrangians in QFT.
1) What he calls “non-local Lagrangian” is the scattering operator for second order processes: [tex]S^{(2)} = - \frac{1}{2} \int d^{4}x d^{4}y \ T \Big\{\mathcal{L}_{I}(x) \mathcal{L}_{I}(y) \Big\} ,[/tex] where [tex]\mathcal{L}_{I}(x) = g \ N \left[ J^{\mu}(x) W_{\mu}(x) \right] ,[/tex] is the (normal-ordered) local interaction Lagrangian.
2) By “integrating out” the [itex]W[/itex] field he means applying the Wick theorem to the product of fields in [itex]S^{(2)}[/itex] and picking the term which contains the contraction of the two [itex]W[/itex] fields: [tex]\overline{W_{\mu}(x)W_{\nu}}(y) \equiv \langle 0 |T \{ W_{\mu}(x)W_{\nu}(y)\}|0 \rangle = iD_{\mu\nu}(x - y) ,[/tex] where [itex]D_{\mu\nu}(x)[/itex] is the propagator of the (very) massive vector field [itex]W_{\mu}(x)[/itex] [tex]D_{\mu\nu}(x - y) = \frac{1}{(2\pi)^{4}} \int d^{4}p \ \frac{- \eta_{\mu\nu}}{p^{2} - M^{2}} \ e^{ip(x - y)} .[/tex] So, basically you obtain a process similar to the Moller scattering in QED: current emits a [itex]W[/itex] boson at [itex]x[/itex] which propagates to [itex]y[/itex] and get absorbed by the second current: [tex]S^{2}(2 \to 2) = - g^{2} \int d^{4}xd^{4}y \ N\left[ J^{\mu}(x)J^{\nu}(y)\right] \ D_{\mu\nu}(x - y).[/tex]
This follows from the following (easy to show) identity [tex]\left( \partial^{2} + M^{2}\right) \int d^{4}p \ \frac{e^{ipx}}{p^{2} - M^{2}} = - \int d^{4}p \ e^{ipx},[/tex] by applying [itex](\partial^{2} + M^{2})^{-1}[/itex] to both sides: [tex]\int d^{4}p \ \frac{-1}{p^{2} - M^{2}} \ e^{ip(x - y)} = \frac{1}{\partial^{2}_{x} + M^{2}} \int d^{4}p \ e^{ip(x - y)} .[/tex]
All interactions in the relativistic QFT are local.
No, because there is no boson in the Fermi phenomenological model. Fermi (4 fermions) interaction is a contact interaction.
Likes vanhees71, etotheipi and JD_PM
Thanks a lot,that was quite helpful.
So if I follow you,Schwartzs` first equation is just about writing the amplitude for a scattering process at second order ? And these Psis are meant to be left Weyl spinors ,I take it ?
Additionally I am a bit doubtful if I understood his distinction between local and non local. Seems like if the fields are at the same point (x) he is calling it local.
Yes.
I don’t know what he did before or after those calculations. I believe he treated the W boson as massive photon just to demonstrate the idea. One can get away with such simplification because, had one used the full charged current interaction Lagrangian [tex]\mathcal{L}_{cc}(x) = \frac{g}{\sqrt{2}}\left(J^{+ \mu}(x)W^{+}_{\mu}(x) + J^{- \mu}(x)W^{-}_{\mu}(x)\right),[/tex] with [itex]J^{+ \mu} = \bar{\nu}_{L}\gamma^{\mu}e_{L} + \cdots [/itex], and applied the Wick theorem, one then simply gets two contractions, one for the [itex]W^{+}[/itex] and the other for [itex]W^{-}[/itex].
That is okay in the Lagrangian or the Hamiltonian but not in the perturbative expansion of the scattering operator.
Likes Elmo
A further question regarding OPE.
I have seen it quoted from multiple sources that in OPE the effective operators express the long distance effects and the Wilson coefficients the short distance effect.
Yet I can't seem to see how the derivation by Schwartz shows this long and short distance dependence anywhere.
FAQ: Operator Product Expansion as shown in Schwartz
What is the Operator Product Expansion (OPE) in quantum field theory?
The Operator Product Expansion is a mathematical technique used in quantum field theory to express the product of two operators as a sum of other operators. It is based on the idea that in certain situations, the product of two operators can be written as a series of terms with increasing dimensions.
How is the OPE used in calculations?
The OPE is used to simplify calculations involving products of operators in quantum field theory. By expressing the product as a sum of other operators, it allows for easier manipulation and evaluation of the resulting terms.
What are the benefits of using the OPE?
The OPE allows for the calculation of physical quantities in quantum field theory, such as correlation functions, to be expressed in terms of simpler and more well-defined operators. This can lead to more accurate and efficient calculations.
Are there any limitations to the OPE?
Yes, there are limitations to the OPE. It is only applicable in certain situations, such as when the operators are close to each other in space or time. It also assumes that the operators have well-defined dimensions, which may not always be the case.
How does the OPE relate to conformal field theory?
The OPE is closely related to conformal field theory, as it is used to calculate correlation functions in conformally invariant theories. In fact, conformal invariance is a key requirement for the OPE to be applicable.
