Operators 'act on' the wavefunction
In summary, an operator does not necessarily change the state of the system if the state is an eigenstate of the operator. If the state is a mixture of more than one proper state, when the operator acts on the system, the wavefunction of the system is changed to one of these proper states. Any subsequent "action" of the operator on the ensuing proper state leaves it unchanged.
says
594
The wavefunction describes the state of a system. When an operator 'acts on' the wavefunction are we saying, in layman's terms, that the operator is changing the state of the system?
Not necessarily. If the state is an eigenstate of the operator, then the operator obviously will not change the state.
Also, it depends on what is meant by "acting on." It can be simply a mathematical operation, like if we operate on a wave function with the time evolution operator, which will tell us how the system will evolve naturally, or it can correspond to a physical process, such as a measurement.
Personally, I see "acting on" a wave function as a mathematical operation, whose physical significance depends on why we are acting on the wave function.
Yes, unless the the wavefunction is a "proper" state (eigenstate) of the operator in which case the state of the system after the application of the operator is the same as before. In other words, if the state of the system is a mixture of more than one proper states, when the operator acts on the system, the wavefunction of the system is changed to one of these proper states. Any subsequent "action" of the operator on the ensuing proper state leaves it unchanged.
This sounds like you're saying that the operator causes a quantum collapse of the state, which isn't true... Isn't that what happens only in a measurement? A measurement is an irreversible process, while acting with a hermitian operator causes no loss of information unless some of its eigenvalues are zero.
@says, did you mean to ask about observables, not operators (as @kuruman assumed)? Generally we assume an operator is bounded and linear, but that's all. It's a linear function "on" a vector space (in QM, that would be a Hilbert Space), meaning, its domain is the whole space and its range is a subspace.
Since the identity matrix is (can be considered to be) an operator then clearly, an operator doesn't necessarily change the vector it's acting on (in QM, that would be the wavefunction). Also there's no change if the wavefunction is an eigenvector of the operator. More generally: the operator will leave it unchanged iff the eigenvalues associated with all the wavefunction's nonzero eigenstates are equal (degenerate), as for instance with identity operator.
The above are mathematical facts (unless I made a mistake) about all operators. They're true in physics also of course, except for one thing, often referred to as the "collapse".
If the Hermitian operator is applied as a measurement, and it has no degenerate eigenvalues, and if we suppose the usual collapse interpretation, then the wavefunction must become a single one of its eigenvectors. Only in the special case that the wavefunction already was an eigenvector of that operator, will there be no change. If there's degeneracy, then there's no change if the wave is in the degenerate subspace - except maybe in the phase. I'm not quite sure ... @DrClaude knows, ask him.
FAQ: Operators 'act on' the wavefunction
What does it mean when operators 'act on' the wavefunction?
When we say that operators 'act on' the wavefunction, we mean that they manipulate or transform the wavefunction in some way. Operators are mathematical tools used in quantum mechanics to describe the behavior of physical systems.
What is the purpose of operators in quantum mechanics?
Operators are used in quantum mechanics to describe the physical properties of a quantum system, such as position, momentum, energy, and spin. They allow us to make predictions about the behavior of particles in a quantum system.
How do operators affect the wavefunction?
Operators can affect the wavefunction in different ways, depending on the specific operator being used. Some operators, such as the position operator, shift the wavefunction to a different position in space. Others, like the momentum operator, change the shape and direction of the wavefunction.
What happens when multiple operators act on the wavefunction?
When multiple operators act on the wavefunction, they are applied in succession and their effects are combined. This allows us to describe more complex physical systems and make more detailed predictions about their behavior.
Are there specific rules or equations for how operators act on the wavefunction?
Yes, there are specific mathematical rules and equations that govern how operators act on the wavefunction. These rules, known as the rules of quantum mechanics, dictate how operators are applied to the wavefunction and how the resulting wavefunction is interpreted.
