Opposing speakers and standing waves
In summary: But that would be due to a mismatch of impedance and not interference. Each cone would be preventing the other one from moving as far as the amplifier would be expected to move it.
Israel Lucindo
If one speaker is placed facing another speaker with the inverted phase and we reproduce an equal frequency in both, what happened?
Did the sound completely cancel out or would a standing wave be created as if it were in phase?
Is this animation valid for sound waves? https://www.compadre.org/Physlets/waves/illustration17_4.cfm
Hello Israel, :welcome: !
The animation is valid and in fact shows what you can expect in your scenario: standing waves with nodes at half wavelength intervals and antinodes halfway between them.
This is for a single-frequency sound.
Normal sounds are a wild mixture of many wavelengths, so the effect is blurred.
Likes Israel Lucindo and davenn
The only place that you can 'guarantee' getting a consistent interference result is half way between two co-phased speakers (or along the normal to the line of centres), where you will always get addition of the sound pressures. Anywhere else you will get frequency dependent phase differences and an uncertain interference result.
Thanks
Likes BvU
Very much "blurred" in most places but along the mid line of two speakers with equal amplitude and in anti-phase (easy to do by mistake) you can get a very obvious 'hole' in the sound, where all / most of the frequencies cancel out. You need to be in a room where most echos are very low level (acoustically treated) to get the effect reliably but fooling around with speaker positions and gains can give a convincing result. A listener with 'golden ears' can often identify the problem despite odd listening conditions.
Likes BvU
Hold identical drivers face-to-face so that they are touching. It's a very convincing demonstration of destructive interference.
Have someone hold a pair of speakers facing forward and move from side to side, you'll hear the nulls in the sound pattern.
I'm not sure what precise experiment you are proposing but with the cones facing each other, the sound pressure between them would be high. This would be additive interference. Driven in antiphase, they would produce a (near) zero net displacement of the air around them but the details of what is going on behind the speakers would affect what you actually heard.
Yes, but there is a very noticeable drop in the volume when they approach contact.
But that would be due to a mismatch of impedance and not interference. Each cone would be preventing the other one from moving as far as the amplifier would be expected to move it. There would be a significant Mutual Impedance between the two sources.
FAQ: Opposing speakers and standing waves
What is the difference between opposing speakers and standing waves?
Opposing speakers are two speakers that are placed facing each other and produce sound waves that cancel each other out at certain points, resulting in a null or quiet zone. Standing waves, on the other hand, are produced when sound waves reflect back and forth between two parallel surfaces, resulting in areas of constructive and destructive interference.
How do opposing speakers and standing waves affect sound quality?
Opposing speakers can be used to improve sound quality by canceling out unwanted noise and reducing echoes in a room. Standing waves, however, can negatively affect sound quality by causing uneven frequency response and dead spots in a room.
Can standing waves be eliminated?
Standing waves can be reduced but not completely eliminated. This can be achieved by using sound-absorbing materials in a room to reduce sound reflections and breaking up parallel surfaces to prevent sound waves from bouncing back and forth.
How do opposing speakers and standing waves impact live performances?
Opposing speakers are commonly used in live performances to improve sound quality and reduce feedback. However, standing waves can cause issues for performers on stage, as they may experience uneven sound levels and frequency response due to the room's acoustics.
Are there any safety concerns with opposing speakers and standing waves?
Opposing speakers and standing waves do not pose significant safety concerns. However, high sound levels from opposing speakers can potentially damage hearing, and standing waves can cause structural damage if the sound pressure levels are high enough. It is important to follow proper safety guidelines when using these sound techniques.
