Optical counterpart of duckbill check valve in fluid dynamics
In summary, an optical counterpart of a duckbill check valve is a device used in fluid dynamics that allows for the visualization and measurement of fluid flow in a system. It is designed to mimic the function of a duckbill check valve, which is used to regulate the flow of fluid in a one-way direction. The optical counterpart uses light and sensors to detect changes in fluid flow, providing valuable data for analysis and optimization of fluid systems. This technology has applications in various industries, including aerospace, automotive, and biomedical engineering.
qnach
143
In fluid dynamics there is a duckbill check valve to prevent the reverse flow.
In EM wave an antenna emmits/receive at the same efficiency.
Is there anyway one can make a check valve for antenna so that it emmits more than received or
vice versa...or perhaps emitts without even receive?
deskswirl said:
I think you mean a faraday rotator https://en.wikipedia.org/wiki/Faraday_rotator
Yes, that is one possibility, which requires an externally applied magnetic field.
Is there any way that we can achieve the same purpose without external magnetic field?
For instance, the material might change shape or rotate if it received EM wave in one direction hence cause the EM wave flow in the other direction impossible?
There are many ways of making a non-reciprocal coupler.
1. The microwave circulator; https://en.wikipedia.org/wiki/Circulator
2. The TR switch used in a Radar; https://en.wikipedia.org/wiki/Duplexer
3. The “180° Hybrid Coupler” “Ring”, “Ratrace”, or “Magic-T”.
https://www.microwaves101.com/encyclopedias/hybrid-couplers
Consider connecting the antenna to one terminal, then the RX and the TX to adjacent terminals λ/4 away on each side of the antenna terminal. The RX and TX will be unable to see each other but both will see the antenna.
The third method (above) seems to be a special case for the first one?
That may be true if you look at it from a purely analytic viewpoint, but you need to also consider the physical implementation and wavelength. Microwave circulators with waveguides, ferrite and magnets are not built for the HF band. The “Ratrace” can be built with long coaxial cables for operation on the HF bands. I am sorry about the duplication.
For the circulator, what are the differences for 3, 4, 9, or perhaps 16 ports? Do they exits with different phase and hence different cancellation?
Anything can be built if needed, but microwave engineers are conservative and so tend to use the the many three port circulators that are available as off-the-shelf components. The microwave circulator connected as an isolator is the closest equivalent to a “check valve”. Where a three terminal circulator is used as an isolator, two can be used in series to square the isolation ratio.
Trees of hybrid transformers or transmission line transformers are assembled to make multi-port distributors and combiners. An arbitrary phase shift can be generated by using appropriate length transmission lines and transformers.
For the circulator, should the wave come from its side wall? Or, does not matter?
I do not understand the question.
What type of circulator? at what wavelength? what type of transmission line? which wave? Both walls are side walls, I guess it will depend on mode of propagation.
An EM wave in a waveguide is guided by the conductivity of the walls. Current flows in the walls, but the EM wave fills the inside volume of the guide.
By a circulator I mean
https://en.wikipedia.org/wiki/Optical_circulator
For microwaves, the waves are traveling between the walls of the waveguides. Since the EM transmission mode is important, the orientation of the ports need to be related. The perpendicular magnetic field requires the planar solution. The Magic-Tee is a four port coupler that requires perpendicular arms. [PLAIN]https://en.wikipedia.org/wiki/Magic_tee[/PLAIN]
In optical-isolators the polarisation is also important, as the light passes through transparent materials with anisotropic properties that rotate the polarisation in a controlled way.
Before you invent a spherical circulator you need to consider the perpendicular nature of the electric, magnetic and poynting vectors. You then need to apply the “Hairy Ball Theorem” to see why the ring structure and not the sphere is used; [PLAIN]https://en.wikipedia.org/wiki/Hairy_ball_theorem[/PLAIN]
So, in view of the hairy ball theorem, the conclusion is 3-D circulator is impossible?
That depends on your definition of 3D. The hairy ball suggests a torus rather than a sphere.
Is there any textbook explicitly calculate the irreversibility of a 3-port (or any port) circulator?
or discussed similar devices?
There are many advanced books available. Analysis of microwave junctions is often done using the multi-port “scattering matrix”, with frequency dependent parameters S11, S22, S12, S21, S31, etc.
There is probably a beginners guide to circulator design in most general textbooks on microwave technology. You need a good technical engineering library.
The publisher “Artech House” produces books in that field. Search their titles, then the web or local technical libraries.
Do you have a big second hand bookshop in your city?
There are second hand books available if you know what you want. Use; http://www.bookfinder.com/
If you find what you want, try to support the Physics Forums website by buying through;
https://www.physicsforums.com/threads/support-pf-buy-on-amazon-com-from-here.473931/
Hey, just give me a reference like J. Kraus, Antenna, Chapter 5.
You don't need to care whether is it advanced or not, nore do you need to care whether do I have a good technical engineering library...etc.
Baluncore said:
I saw in Collin's book discussed non-reciprocal/Lorentz reciprocal theorem and in chapter 6 3-port circulators.
The other two books did not find similar topics (perhaps I missed them)
Collin's book is the classical one, I remember I bought one but sold it because I did not need that at that time...
The link of PDF file you gave has some problem for the mathematical symbols...I will try to find other one...
You need to be more precise in your question. Reversibility or reciprocity?
How can you calculate irreversability? Either you compute the rejection ratio of a real circulator, or you somehow prove that an ideal circulator can be nonreciprocal.
A circulator can be synthesised from one or more two port gyrator networks.
A three port circulator is the minimum nonreciprocal junction.
Thanks, I think I am talking about reciprocity.
I am trying to get some books you mentioned.
Is there any book on optical-fiber talking about such business?
Those three above are on microwave Engineering.
Available books on the subject are very hard to find.
Download this .pdf from IOPscience, it refers to other papers on page 1.
"Magneto-optical non-reciprocal devices in silicon photonics", Yuya Shoji and Tetsuya Mizumoto.
http://iopscience.iop.org/article/10.1088/1468-6996/15/1/014602/pdf
So, is there any difference for microwave and optical device for a circulator?
There are conceptual and physical parallels in mode, polarisation and the control of phase shifts.
At the systems level, the scattering matrices and the synthesis of networks are the same.
The technology differs in wavelength and therefore in material selection and fabrication.
Any single torus or loop can be combed, but where one torus merges with another there will be problems. Your example has a central sphere where three separate loops combine. Each of those loops has two independent outer spheres with double bonds. So the purple and black hairy spheres cannot be combed and so will have combing problems where the EM waves meet.
It is your definition of 3D in post #13 that you must refine before your question can be answered.
Which book (on optics) can I find talking about Faraday rotator?
I have no single answer to that question. It will depend on your current understanding and what the application is that needs you to understand Faraday Rotation. Maybe you need to look for a book on electro-magnetics. Browse a library to find the next book you need, or visit a collection like; ht tp://inis.jinr.ru/sl/index00.html
Google 'faraday optical rotation'
Google BOOKS 'faraday rotation'
Related to Optical counterpart of duckbill check valve in fluid dynamics
1. What is an optical counterpart in fluid dynamics?
An optical counterpart in fluid dynamics refers to the use of optical methods, such as laser Doppler velocimetry or particle image velocimetry, to measure and visualize the flow behavior of a fluid. This allows for a more precise and detailed understanding of the fluid dynamics compared to traditional methods.
2. How does a duckbill check valve work?
A duckbill check valve is a type of one-way valve that allows fluid to flow in only one direction. It consists of a flexible rubber or silicone "duckbill" shaped flap that opens when fluid flows through it and closes to prevent backflow. This design eliminates the need for any mechanical components, making it a simple and reliable valve.
3. What is the purpose of using an optical counterpart for a duckbill check valve?
The use of an optical counterpart for a duckbill check valve allows for a non-intrusive and non-invasive way to study the fluid flow behavior and performance of the valve. This can provide valuable insights for improving the design and efficiency of the valve.
4. What are the advantages of using an optical counterpart in fluid dynamics?
Some advantages of using an optical counterpart in fluid dynamics include its ability to provide high-resolution and real-time measurements, non-invasive nature, and the ability to capture complex flow phenomena that may not be possible with traditional methods. It also allows for a more detailed analysis of the flow behavior, which can aid in the design and optimization of fluid systems.
5. Are there any limitations to using an optical counterpart for a duckbill check valve?
One limitation of using an optical counterpart for a duckbill check valve is that it may require specialized equipment and expertise, which can be costly. Additionally, the optical methods may be affected by certain factors such as the optical properties of the fluid and the presence of particles or bubbles in the flow. Therefore, it is important to carefully consider the specific application and limitations before using an optical counterpart in fluid dynamics.
  • Mechanical Engineering
  • Other Physics Topics
