Optical proprieties of sulfur dioxide in the gaseous state
In summary: Summary:The first-year student in engineering is trying to find a way to do a presentation about geoengineering methods. He has read that sulfur dioxide is one of the geoengineering strategies that is contemplated. He has read that water strongly absorbs 170 nm light, so he is trying to find a way to use vaporized water instead of aerosols.
solar energy
TL;DR Summary
Hi, I am a second-year university student in engineering and for this year I have to do a presentation( with related experience ) about the physical implication of geoengineering methods.
Hi, I am a first-year university student in engineering and for this year I have to do a presentation( with related experience ) about the physical implication of geoengineering methods. The theoretical aspect seems quite understandable, my principal problem is to find a clear experience with the not-so-advanced laboratory instruments to which I have access.
At the start, basing myself on some research, I thought to use the refraction properties of saltwater: meanwhile, I should use water drops of a diameter range of 300-800 nm which is "instrumentally" impossible for me.
For this reason, I chose to try something different by using sulfur dioxide(that I can obtain thanks to the reaction of sodium metabisulfate with hidrochloric acid) but i this case i would only obtain its gas form(and not the aerosol form) so i fear that its propreties will be too much different.
If it is the case i though about using sulfur dioxyde in a suspension(i have seen that by a similar way we can evaluate its Trasmittance), the problem is that i should find a proper solvent(and for the moment i have no idea about).
I would be glad if can give some advices about my ideas or if you have some idea or critique to expose me.
Sincerly, A.O
What do you want to do? You directly jump to details of an experiment you didn't describe.
Likes Vanadium 50
I would like to measure the absorbance of sulfur dioxide and by this way give a general idea of his absorption capacities for what concerns short wave light
Why SO2 in particular? There are easier things to work with where you can measure absorption of light.
I have read in an article that the actual geoengineering strategies foresee to use SO2 because of his experimental absorption that apparently is between 170 and 310nm.
Then if is there another molecule that has a quite strong absorption on short-wave light(and possibly easier to manipulate) I would be glad, but( a part of the saltwater) I have no particular idea
At this rate of information dripping it we'll need a long time before there is a chance to actually answer questions. That's not very efficient.
Water strongly absorbs 170 nm light.
Likes Vanadium 50, berkeman and Bystander
I apologize if I forget to give some details or information(you can ask me more in detail and I will have no problem answering), but for what concerns water absorption the problem is that I should give a physical model that could stand for a certain period of time: using vaporized water in the atmosphere will not give the same effect of using, for example, aerosols based on sulfur or salt(the second will "stand for more time" as I think)
FAQ: Optical proprieties of sulfur dioxide in the gaseous state
What is sulfur dioxide and why is it important to study its optical properties?
Sulfur dioxide is a chemical compound composed of sulfur and oxygen. It is an important air pollutant and is also produced naturally by volcanic eruptions. Studying its optical properties is important for understanding its role in atmospheric processes and its impact on human health and the environment.
How does sulfur dioxide interact with light?
Sulfur dioxide has a strong absorption band in the ultraviolet region and a weaker band in the visible region. It also has a weak scattering effect on light. These interactions with light determine its optical properties and how it affects the transmission of light through the atmosphere.
What factors affect the optical properties of sulfur dioxide in the gaseous state?
The optical properties of sulfur dioxide in the gaseous state are affected by various factors such as temperature, pressure, and the presence of other gases. Changes in these factors can alter the absorption and scattering of light by sulfur dioxide, leading to changes in its optical properties.
How do scientists measure the optical properties of sulfur dioxide in the gaseous state?
Scientists use various techniques such as spectrophotometry and laser absorption spectroscopy to measure the absorption and scattering of light by sulfur dioxide. These techniques allow for precise measurements of the optical properties of sulfur dioxide in the gaseous state.
What are the potential applications of understanding the optical properties of sulfur dioxide in the gaseous state?
Understanding the optical properties of sulfur dioxide in the gaseous state has various applications, including atmospheric monitoring, air pollution control, and climate modeling. It also helps in the development of technologies for the detection and measurement of sulfur dioxide in the atmosphere.
