Optical Pumping (Zeeman Effect)
In summary, increasing the strength of the magnetic field in optical pumping-style experiments leads to an increase in the transmission of light through rubidium. This is because the energy gap between the mF levels also increases, making it more difficult for atoms to jump between levels and resulting in a higher degree of polarization. The Earth's magnetic field is not strong enough for this effect to occur.
ssj2poliwhirl
I am a bit confused about optical pumping-style experiments, and why increasing the strength of the magnetic field increases the amount of optical pumping --> increases the transmission of light through rubidium
So basically we have Rubidium with energy levels like this:
http://t3.gstatic.com/images?q=tbn:ANd9GcRPcNj_MWyOh1pOkvsfohSY6o9HRxO25v031mNC2xG7nFfnoWtj2Q
My understanding is, an external magnetic field will cause the final splittings on the right (into m_F levels), and as we increase the magnetic field from 0 the gap between the m_F levels gets broader [until we pass the weak field limit and get the quadratic Zeeman effect instead].
Can someone help me understand why increasing this gap increases the amount of pumping/rubidium polarization we get? Based on the theory of how/why it work, it just seems like, 'as long as there is a gap, we will get optical pumping'. Why does an applied field cause so much more light transmission than just the Earth's magnetic field?
Science news on Phys.org
Great question! Let me explain the concept of optical pumping and how increasing the magnetic field can enhance it.
Optical pumping is a process in which atoms are excited from a lower energy state to a higher energy state through the absorption of light. This is typically done using a laser, which emits light at a specific frequency that corresponds to the energy difference between the two states.
In the case of rubidium, the atoms have multiple energy levels, as shown in the diagram you provided. When a laser is shined on the atoms, it can excite them from the ground state (F=2) to the excited state (F=3). However, due to the presence of the external magnetic field, the energy levels split further into mF levels. This means that there are multiple paths for the atoms to be excited, depending on the orientation of the magnetic field.
Now, here's where the increasing magnetic field comes into play. When the magnetic field is weak, the energy gap between the mF levels is small, and the atoms can easily jump between the different levels. This results in a lower degree of polarization, as the atoms are not all in the same energy level.
However, when the magnetic field is increased, the energy gap between the mF levels also increases. This means that the atoms can only be excited to specific mF levels, and it becomes more difficult for them to jump to other levels. As a result, more atoms end up in the same energy level, leading to a higher degree of polarization.
So, to answer your question, increasing the magnetic field increases the energy gap between the mF levels, making it more difficult for the atoms to jump between levels. This results in a higher degree of polarization and an increase in the amount of light transmitted through the rubidium sample.
As for why the Earth's magnetic field is not sufficient for this effect, it is simply because the field is not strong enough. The Earth's magnetic field is relatively weak compared to the field used in optical pumping experiments, and therefore the energy gap between the mF levels is not significant enough to cause a noticeable increase in polarization.
I hope this helps to clarify the concept of optical pumping and the role of the magnetic field in enhancing it. Let me know if you have any further questions. Happy experimenting!
Related to Optical Pumping (Zeeman Effect)
1. What is optical pumping?
Optical pumping is a technique used in spectroscopy to manipulate the energy levels of atoms or molecules by using light. This technique involves the absorption of photons by atoms, which can cause them to move to a higher energy state.
2. What is the Zeeman effect?
The Zeeman effect is the splitting of spectral lines in the presence of a magnetic field. This phenomenon was first observed by the Dutch physicist Pieter Zeeman in 1896. The effect occurs because the magnetic field causes a splitting of the energy levels of the atoms, resulting in multiple spectral lines instead of a single one.
3. How does optical pumping produce the Zeeman effect?
Optical pumping can produce the Zeeman effect by polarizing the atoms in the sample with circularly polarized light. This polarized light can cause the atoms to align their magnetic moments in the direction of the light's polarization, resulting in a splitting of the spectral lines when a magnetic field is applied.
4. What are the applications of optical pumping and the Zeeman effect?
Optical pumping and the Zeeman effect have numerous applications in physics and chemistry. They are commonly used in spectroscopy to study the energy levels and magnetic properties of atoms and molecules. They are also used in the production of masers and lasers, as well as in the development of atomic clocks and other precision instruments.
5. Are there any limitations to optical pumping and the Zeeman effect?
One limitation of optical pumping and the Zeeman effect is that they are only effective on atoms or molecules with a non-zero nuclear spin. This means that they cannot be used to study elements with even numbers of protons and neutrons, such as helium. Additionally, the strength of the applied magnetic field can affect the accuracy of the Zeeman effect measurements.
