Optical qualities of prism sheet and glass substrate (LCD screen)
In summary: So it can have an impact on image quality and might be the cause of eye pain.Welcome to PF.In summary, the two layers in an LCD screen that can hurt the eyes when the screen is disassembled are a prismatic sheet and a lower glass substrate. These layers reflect light and can cause discomfort or pain when the screen is used. It is possible that this problem is more biology-related than physics-related, and that it is not limited to LCD screens.
  • #36
I think it must be flicker related. This turns out to be rather involved for an LCD screen.
https://www.eetimes.com/lcd-screens-dont-flicker-or-do-they/
This can be simply investigated using an (amplified) photodiode and an oscilloscope. The frequencies are sub-kiloHz. You need some actual data.other than "my head hurts"!
Likes jrmichler
Biology news on Phys.org
  • #37
As I said it was investigated thoroughly.
Here is one example. I soldered a device that allows to smoothly change the PWM of the monitor in the range of 100Hz - 1200Hz. My sensitivity to PWM flicker is:
100-150Hz feels horrible
150-180Hz very bad
180-220Hz bad
220-240Hz OK
240-340Hz good
340-500Hz excellent
500-1000Hz makes no sense to use, no additional improvement
Also those layers from disassembled screen have no ability to flicker. I can take them in hands and... I do not know, wave fast? Then they will flicker :smile:
  • #38
It is complicated. Please read the article. The amount of flicker depends upon lots of stuff.
  • #39
150-180Hz very bad
180-220Hz bad
220-240Hz OK
240-340Hz good
340-500Hz excellent
Wait, that is very significant, no? If you can change the frequency of the flicker and it eliminates the pain, then the problem seems to be directly related to flicker frequency and not any of the LCD layers. Can you buy monitors with 340Hz refresh rates? What are typical LCD backlight flicker frequencies?
And I thought you said that your ophthalmologist(s) did flicker sensitivity tests on you and found nothing?
  • #40
On the contrary, it shows that I am flicker sensitive only up to these frequencies, and none of my LCD screens have these flicker frequencies. These frequencies are typical not to LCD but to OLED screens (typical PWM frequencies) and many if not the most people are sensitive to these frequencies (I mean solely PWM frequencies).
Refresh rates are not PWM flicker (PWM is stroboscopic full-screen flicker) and they are way lower, but my safe refresh rate is 60 Hz like for the most people.
I said there were ophthalmological tests and flicker tests, not ophthalmological flicker tests :smile:
  • #41
And, based on your flicker tests, a vote for this. It will tell what the screen is really doing, not what you think it is doing. Do this with screens that are both bad and good, or at least not as bad, looking for differences. If you do not find anything, try some color filters over the photodiode.
These type of problems are solvable. Finding the solution requires checking everything, especially those things that you don't think need to be checked.
It helps to create a document that states exactly what is known. The act of organizing that document frequently shows gaps in what is known. Those gaps need to be investigated. That document is useful in communicating what is known to people new to the problem. Such a document has helped me to solve similar difficult problems. It is well worth the time to create it.
Likes russ_watters, berkeman and hutchphd
  • #42
I could not agree more and have had many similar experiences.
  • #43
Sure, and this doc exists in Russian.
This is how we ruled out all the flicker influence (FRC, Vcom, inversion, PWM, refresh rate, software etc. etc.).
Again, I am now more interested in how exactly two non-flickering, very static pieces of material can be so problematic for the eyes.
  • #44
Ok, let me get this straight. Does anyone here have any experience with these layers or knows how they may work? I do realize that everyone are trying hard to help here and I am grateful, but maybe more experience with this particular tech is needed to help with this optical issue.
  • #45
Sure, I can probably dig up some SID papers that discuss those layers (Society for Infomation Display -- the main technical society that deals with this sort of display technology).
informerkh said:
Summary:: Need help with defining optical qualities of two LCD screen layers that can severely hurt eyes when the screen is disassembled (what do they do to light to make it dangerous)
I experimented with monitors a lot, and came to the conclusion that the problem is optical. I completely disassembled the LCD screen, took a table lamp with an incandescent light bulb, applied all the screen layers above the lamp one by one, and directed a lamp light onto a white wall. I noticed that my eyes hurt when looking at two layers - a prismatic sheet and a lower glass substrate. Moreover, my eyes hurt even from the reflected light from the wall! The symptoms are exactly the same as when working with the monitor. Does anyone know what these two layers do to light and why it can hurt eyes? I have found many people who have the same problem, to a greater or lesser extent. I have not found any research other than the effect of PWM on flickering and blue light, so any information will be appreciated.
So those two layers are the ones that you can shine DC illumination through and experience eye pain when looking at the light reflected from a white wall?
Likes informerkh
  • #46
Wow! Thank you so much! That would be great! I sincerely hope that will help to figure things out! (At least to define set of non-flicker probable causes)
Yes, they are the prism sheet (it might be not a direct cause of pain in the monitor but it definitely unexplainably hurts when it is disassembled) and lower glass substrate (it has a thin film transistor layer on it and they cannot be separated, at least I could not separate them). Glass substrate might be a direct cause and I can't understand why it has effect so similar to a prism lens.
  • #47
150-180Hz very bad
180-220Hz bad
220-240Hz OK
240-340Hz good
340-500Hz excellent
Could you perhaps try lower frequencies for the flicker test?
I ask because common refresh rates are 60Hz and 75Hz, and your data shows greater trouble with lower frequencies.
Typical vision can detect 50Hz with averted vision, but it is not usually noticable when looking directly at the source. 120Hz is not typically visible under any condition. Maybe your eyes just have a faster response time than most! (I wonder if that's a survival advantage, either in the distant past, or in the present with powered vehicles to avoid. 🤔)
Also, your comments indicate that there is more than one contributing factor, specifically the refresh rate and the presence of the prismatic layer. You may find that there are other contributions.
Cheers,
Tom
  • #48
There is a very simple explanation. There are two things participating in vision: eyes and brain. 120Hz is typically invisible to the brain. Person can't see it. But it is detected by eyes. Eyes can detect this flicker nonetheless. A very simple pen (or pencil) test proves this. If you take a pen and wave it in front of something that uses low frequency PWM (probably 120-400Hz, but here I am not sure) you will see not a usual pencil movement, very smooth, but a stroboscopic effect with 3, 5, 10 separate pencils. It is fun to watch. Meanwhile when looking at this source without any pencils you will see a usual normal image. This happens because brain takes an input from your eyes and proceeds it to you as a simple unmoving non-flickering image.
PWM is different than the refresh rate, it makes screen (or a light bulb) to flicker in a stroboscopic manner. So people are sensitive to it in a different way than to a refresh rate. No one knows yet why exactly people do react to PWM flicker. Does it break small involuntary eye movements (saccades) or does it affects the brain somehow or does it affects eyes in other way? Once scientists will find out.
But it is absolutely normal to react to PWM flicker. There is IEEE 1789-2015 - IEEE Recommended Practices for Modulating Current in High-Brightness LEDs for Mitigating Health Risks to Viewers. It says that frequencies up to 400 Hz are somewhat dangerous, they bring temporary health effects and should be avoided.
Here is the video that illustrated PWM flicker (it has a loud music so you might want to turn sound off):
I also tested another very common source of flicker, Vcom, and there is an opportunity to make it so strong that the flicker will be visible. I had no reaction to it. There are also test images for flickering, and my safe screens were flickering more that bad ones.
For example, this is how severe a Vcom flicker can be (upper image has Vcom flicker captured):
I would rather look at this flicker than to my bad non-flickering screen.
Yes, sure, there may be more than one contributing factor, hope to find them all! :smile:
  • #49
I just found this really cool article https://spectrum.ieee.org/visioncorrecting-display-means-no-need-for-reading-glasses. It describes methods of adjusting screen image for people who wear glasses so that they can see this image clearly without prescription glasses. I am now thinking again about that top polarizer with smaller than subpixel light rays. It may be possible to distort an image the other way round.
This is just a thought right now, nothing more.
  • #50
informerkh said:
I think this is not very newsworthy. In particular this technique has been known for a long time.
https://en.wikipedia.org/wiki/Pinhole_glasses
I don't see why you are so resistent to very good recommendations you have been given. I like to stumble around the internet sometimes but if the problem is related to flicker then why are you not looking at flicker using time resolved detection of some sort? Your methods are clearly inadequate to your purpose. What you say may be salient (or may not) but looking at the layers in a polarizing LCD stack is a very obtuse methodology for looking for frequency dependent effects.
I have no idea what the point of the video is other to illustrate one way to "see" frequencies higher than your flicker fusion rate. Folks with strobe lights know this.. that's why they have strobe lights.
Likes russ_watters
  • #51
Excuse me but I literally just described some tests for flicker sensitivity in detail.
Problem is not related to flicker.
Why do you suppose that it is?
I am not sensitive to any flickers other than the common low PWM rate that can easily be avoided and is not present in most LCD screens. Many LCD screens have no PWM at all!
I wrote here twice that replaced the LCD panel without the circuitry and problem moved with it. LCD panel cannot flicker by itself, it needs software of backlight or circuitry.
  • #52
Well, part of the problem might be, but you said that you can experience the pain with Static illumination through just the suspect LCD layers in isolation, right?
  • #53
Flicker is not part of the problem, I can easily test it and easily avoid it, it is a simple thing to check.
Right, that is exactly the case, I can experience the pain with static illumination. And that table lamp without LCD layers above it is completely fine for me, just like any ordinary lamp.
LCD panel without backlight layers, without backlight, with top polarizer replaced defines whether screen is good or bad for me. That is for sure. There's no other explanation why all the sensations from the screen move together with it. I placed it in another device and sensations moved with it. It is the most important cue.
Likes berkeman
  • #54
Did you read and understand the article I recommended??
  • #55
You posted an article about a Vcom voltage. I posted just now! that I tested Vcom by adjusting it to make its flickering totally visible. Monitors (not all) have a resistor that can be twisted and made better / worse up to a pronounced flickering of neighboring subpixels that can be seen easily, just like on the picture I posted.
  • #56
I agree that these are important clues.
Since you know others with similar eye pain problems with LCDs, do you know some who would be willing to go through a couple simple tests with you to start gathering more data?
If so, I'd suggest setting up a test where the subject is looking at a white wall in front of them, and from behind them, you randomly project the DC lamp light through different LCD layers to see if they have the same reactions that you do to the projected light on the wall. If they do (in this single-blind test), that could be pretty significant. (And to be complete, you should be one of the subjects in this test as well, with somebody else randomly switching out the layers.)
Likes Tom.G and informerkh
  • #57
Yes, that is a great idea and I want to do something similar!
There are three problems with the execution:
1. People are scattered around the world and even within one country. As I need people who are willing to participate, have free time, have these layers... It is super hard to organize. And only two people are ready to disassemble screens right now, other simply do not have skill or waiting curiously for the results. But I hope things would improve.
2. Screen layers have to be found, so it should be exactly a bad screen, preferably the worst one for clear conclusions. Because of the next point in this list, the best thing to do is find some expensive modern smartphones with IPS screens and that takes some time and money (or less money and more time if service center can give some).
3. People have different sensitivity levels. I have high sensitivity but others have less. This problem is the most prominent on modern smartphones and most of them are OLEDs, so there's nothing to disassemble.
The lady I mentioned took the slightly bad IPS screen, disassembled it and found out that:
- she has way less problems with the exact same prism layer
- she has problems with a layer that comes above it, it is sort of another prism but probably multifunctional, we couldn't figure out its name. It looks very similar to prism film and may be some sort of reflective polarizer combined with prism film... I am not sure.
- she has pressing sensation that resembles phone when she takes lover glass substrate with transistors, that is glued with rear polarizer, and that undefined multifunctional layer together. She feels pressure when she applies them above the safe screen (with no image, just white background).
As I said, she is at the very beginning and she doesn't want to jump to conclusions.
This is a tricky problem and it affects people randomly, so there is no critical number of EEs to do all the tests yet. I hope it will change over time. Maybe if I have some clear findings or simple tests that everyone can do, there will be more data.
  • #58
One more WAG (Wild Ass Guess):
Sensitivity to differential polarization. If you can get two polarizers (perhaps sacrifice a pair of plastic polarized sunglasses) to hold infront of your eyes.
Try viewing a screen thru the polarizers and see if you get any improvement/worsening when you independently rotate the polarizers. Try it with both 'good' and 'bad' screens.
Oh, and another WAG:
Do the screens give you a problem if you view them with only one eye?
Cheers,
Tom
Likes berkeman and informerkh
  • #59
Hi Tom,
Those two ideas are also interesting!
I personally haven't tried polarizers independently yet, but I may try and see what happens. I asked the lady I mentioned (she uses nickname Mrak0020 on the forums I mentioned) and she also haven't tried. But both me and her tried different polarizers on top of bad screens, it changes nothing. I suppose polarization should not be differential if a screen is covered with a "good" polarizer above it.
I tried to look both eyes and one eye. Here what I've got: when I look with both eyes it hurts. When I look with one eye it also hurts. And what is interesting, it seems it still have some connection to accommodation or convergence despite it is one eye only. And here is why.
Mrak0020 also tried it and she also have more severe reaction (less sensitivity level, so less bad screens, but more severe reaction, her eyes hurt more). She has new visible red blood vessels in her eyes immediately after looking on a bad screen.
She was playing with stereograms and a simple test for binocular vision dysfunction: Brock string. Using those she understood that bad screen influences her convergence (it is the process of eye muscles rotating eyeballs so that they look to the same point), she had never any problems with it but after looking on the screen she can't focus far, eyes converge at the wrong point. That can be fixed with exercises for convergence, or looking on parallel-view stereograms. Looking on the bad screen influences her convergence immediately again, exercises do not prevent this. Screen does something to the eye rotation or focus.
Now when she looks with one eye only, most symptoms remain, and she sees those new visible blood vessels in the mirror on the surface of that one eye. So it is connected to binocular vision or eye muscles or eye focus, and a single eye exposure is somehow enough for the pain.
I haven't tried Brock string yet, we've met with Mrak0020 not so long ago.
  • #60
Just wanted to clarify if maybe something was misleading. I do not represent any organized group of people, and due to the different background, skills and countries it is hard to do anything organized. I've seen a number of similar stories and Mrak0020 spoke to different people with the same problem. They always are easy to recognize because people are not sensitive to flicker or ruled all the flickers out (it is not so hard to do, typical screen flickers can be measured or avoided and there are guides how to do it). People complain about the pressure, pain, inability to focus on image and weirdly "piercing colors" of the screen, especially white (no matter what the brightness is, it could be minimum brightness). Just like in this review of a monitor: https://libredd.it/r/Monitors/comments/pmmt2l/trying_to_reduce_eye_strain_and_headaches_from/
It is about a flicker-free monitor and it says "I still get bad eye-strain and headaches from looking at the monitor even just for a few minutes. It feels like the colors, especially the white color pierce through my eyes even at lowest brightness if that makes any sense." There are two similar reviews in Russian for the exact same model.
I also checked spectrum by simply replacing backlight and it changed nothing. And Mrak0020 tried about 50 different bad phones, they couldn't use absolutely same diodes. So it seems to be neither flicker nor spectrum related.
We've teamed up with Mrak0020 and we are eager to try different tests, that is the best we can do now.
  • #61
Here are a couple Youtube videos on LCD displays. The first is a short quick look.
The second is about 34 minutes and the guy likes to talk but there is much information there. The prism layer is explained starting around 12 minutes. It is used for "light recycling," that is it redirects the backlight to go perpendicular thru the screen. Didn't you say that removing that layer reduced the discomfort?
Cheers,
Tom
Likes informerkh
  • #62
anorlunda said:
Maybe this?
https://www.physicsforums.com/threads/ophthalmic-migraine.71816/
Maybe flicker?
https://www.physicsforums.com/threa...amp-result-in-flickering.933119/#post-5893420
That thread discusses the variability of people's sensitivity to flicker. Some people can perceive flicker at frequencies that most other people don't.
What about when you use an old fashioned CRT screen? (if you can find one.)
What about when you watch TV at home?
What about when you go to a movie theater? (If you can find one still open.)
I agree with most of these studies...
As an old TV repairman, I recall that there was an on going balancing act between scan rate (29.5 fps US NTSC, 50 fps PAL Europe) and image retension of the phosphor.
Short retension ment flicker and retnal fatigue, long retension ment cometing of a moving object. Most opted for longer retention time.
Early computer monitors were monochrome and notorious for this.
LCD screens update on a pixle by pixle basis but used differing methods of maintaining and updating the image with florescent backlighting that operated from 120hz to 20khz somtimes creating a nausiating strobe effect.
Newer LCD screens have variable updates from 30fps to 240fps and a steady state led backlight. So the retension time can be very short and depending on subjet matter can affect people with "persistance of vision" problems.
I have this issue with some of these screens, early Apple CRT monitors were my biggest problem.
I have no problems with oled screens, no apearent or real flicker, no image shift due to thick LCD layers or shift in polarization, and no backlight.
Likes berkeman and anorlunda
  • #63
Hello, thank you for suggestions and happy holidays!
I doubt that this particular problem has any connection to this. For me, typical CRT frequencies of 75-85 Hz were difficult for perception, I saw how image 'pulses'. But my symptoms were completely different, my eyes were red and the head ached but I personally react to bad LCD in another way and clearly can differentiate my reaction. I was happy to purchase my first LCD and had zero problems with LCD screens for a long time.
CRT had only one drawback, flickering, although the picture felt more 'honest', like there was a 'surface' of the image, and LCD is the opposite - letters hang in the air (in the light) and there is no focus point for the eyes.
I didn’t think anyone’s eyes would hurt from the LCD, although now I found a bunch of similar complaints to mine, that started since LCD appeared and became widespread (early 2000s).
The problem I am fighting with right now is also present widely in modern oled screens.
I found a post (https://ledstrain.org/d/513-removing-the-metalic-semi-transparent-lcd-layer-helps) where the author removed a prism sheet from 5 different monitors and had a significant symptom decrease with every monitor. He said in the comments that nothing else helped. But he also said in another thread that LCD matrix itself is somehow problematic. It seems we came to the same conclusions.
  • #64
Cheers,
Tom
Hello Tom, happy holidays to you and have a great 2022!
I've seen a plethora of videos, including the first one, but the second one is new to me, it is way more detailed and interesting to watch. I found exact same 3M presentation that is featured in this video and yes, I told that removing this layer reduces the discomfort. Moreover, as I mentioned in another reply, I just found another person (https://ledstrain.org/d/513-removing-the-metalic-semi-transparent-lcd-layer-helps) who did exactly the same and reduced discomfort! He removed the prism layer from 5 monitors and got a significant relief, but he still could not find a way to use screen with no symptoms. He got stuck with the LCD matrix itself, he found it to be another cause of this problem. That corresponds with my experiences.
But LCD matrix is not a lens or at least should not be a lens, so it's hard to define what exactly happens.
I also wonder why prism layer that makes light go perpendicular trough the screen is problematic but any increase of brightness on the safe screen is completely OK for me. That is a big mystery to me.
I am not sure if all the light comes though it perpendicular, I've seen in some article that it reduces light angle but not completely.
I found a couple of articles about prism film and similar films (there can be few of them in one device):
http://archive.informationdisplay.o...play-marketplace-getting-the-light-through-tf
https://displaybly.com/brightness-enhancement-film-for-led-backlkight
And a big detailed part of a book (Applied Prismatic and Reflective Optics) that describes them (PDF file):
https://www.spiedigitallibrary.org/...sschapter&isFullBook=False&isResultClick=True
But I still can't figure out what's going on and how exactly this light is different from any other light. The most mysterious is LCD matrix (glass substrate with transistors) that should not be a lens.
  • #65
Now if you could just find someone looking for a Masters Thesis subject, maybe you could talk them into researching the problem!
Likes berkeman and Keith_McClary
  • #66
But the OP has still refused to conduct my single-blind experiment. That does not bode well for the future of this discucssion thread...
Likes russ_watters
  • #67
informerkh said:
I replied to you in PM.
My problem has no connection to flickers and there were plenty of Ophthalmologists and flicker tests.
I just joined the thread (and we are discussing in the mods forum). A quick note for the overall problem (on PF and otherwise): if you want people to treat this/you like this is a real issue you need to take/treat it seriously. These flippant answers don't help your case. Surely with your education you must see that at face value what you are suggesting isn't possible, so if you need to be extra rigorous to show that it is real.
FYI, 3 or 4 years ago I had an issue that felt like someone stabbing me in the back of my eyes. It went on for months and an ophthalmologist found no issues. It was frustrating. I know the pain was real. And I was primed to reach for environmental issues. But reaching for answers in the minutiae of nothing is not useful.
Likes jrmichler and anorlunda
  • #68
When I see something like this, I start to wonder if the OP has a real problem, or is playing games with us. People with real problems are willing to check everything, even those things that appear to be obvious. People who are serious about solving a difficult problem will follow the advice given earlier about documentation, then show the document.
I suggest one more test. Modify a monitor so that the problem is minimized. Then have somebody else randomly switch between that monitor and a second monitor. Both monitors must be identical in appearance, the switching must be random, and the switching must be done out of your sight. The switching MUST be done such that you have no idea which monitor you are looking at. The test needs to be repeated several dozen times, and the result of each switch, or fake switch, recorded. And you must go into the test with an open mind.
Likes russ_watters
  • #69
I clearly see I've come to a wrong place with the question. The majority have no actual experience with tech (or complicated optics) to make any advices, aside from very basic advices about how to organize data collection.
The blind test was proposed solely to prove to the contributors of this discussion that the problem is real and there are no tricks and no placebo. This very idea seems very odd to me, as on tech forums people usually are aware about eyestrains of different kinds and do not start from 'Prove it is real' or 'It is placebo'. Does a blind test make a slightest contribution to my research? No, as the problem is most definitely real for the everyone experiencing it (I provided a link to another person who tried the same experiment few years ago, but it was ignored, as I see). The only use of a blind test for me is to prove that the problem exists to hardware manufacturers, and that could be done when we know what to look for, what to test in every case.
The document in Russian (which as I said, was created long ago): https://4pda.to/forum/index.php?showtopic=943228&view=findpost&p=110571086
Tom, if such a chance will appear, I will use it, but it seems that it requires more skills and time than a Master Thesis, we spend a lot of time already and there's still a long road ahead.
Your suggestions were interesting and valuable, thank you for your inputs!
Everyone else, sorry for the bother. I'll ask somewhere else.
  • Skeptical
Likes weirdoguy and Tom.G
  • #70
Whelp, we tried our best. Thanks everybody for trying to help the OP to alleviate his issues.
Thread is now closed.
Likes russ_watters, hutchphd and anorlunda
