Optical signal and encryption
In summary, the conversation discusses the difference between encrypting an electrical signal and converting it to optics, and converting the signal to optics and then encrypting it. The use of symmetric or asymmetric encryption techniques is also mentioned. The idea of encrypting in the optical domain is questioned and compared to encrypting in the electrical domain. The potential advantages and disadvantages of an all-optical processor are discussed, including improved security and potential difficulties with image compression. A proposed scheme for all-optical encryption/decryption is also mentioned.
Fiona Rozario
55
What is the difference between encrypting an electrical signal and converting it to optics; & converting the signal to optics and then encrypting it? (Any of the symmetric or asymmetric encryption techniques).
What are your thoughts? And how do you propose to encrypt the optical signal?
With reference to the papers attached...I am just unclear in my head as to why one would need to encrypt in the optical domain. Wouldn't it be just simpler to encrypt in the electrical domain and then convert it to optics?
  • asymmetric encryption.pdf
  • 3DES implementation.pdf
It is unlikely at this stage that such an optical technique would have a commercial advantage. If it did they would not be publishing their research.
The advantage of an all optical processor would be better security because it could not be “wedged” by the insertion of hostile software via the net. A parallel optical processor would improve image encryption speed.
Optical encryption has a disadvantage in that it cannot benefit from widely used image compression techniques and requires a reliable error correction code. There is however a possibility of using optical techniques such as spatial frequency analysis prior to optical encryption. Maybe that is how they could implement compression?
https://en.wikipedia.org/wiki/Fourier_optics#Fourier_analysis_and_functional_decomposition
A scheme for all-optical encryption/decryption of QPSK signals based on ND-FWM in HNLF is proposed
Related to Optical signal and encryption
1. What is an optical signal?
An optical signal is a type of electromagnetic radiation that is used to transmit information through optical fibers. It is in the form of light waves, typically in the infrared range, and carries data by varying the intensity or frequency of the light pulses.
2. How is an optical signal encrypted?
An optical signal can be encrypted by converting the data into a series of light pulses that correspond to specific patterns or codes. This can be achieved through techniques such as polarization coding, wavelength coding, or frequency hopping, making it difficult for unauthorized parties to intercept and decipher the information being transmitted.
3. Why is encryption important for optical signals?
Encryption is important for optical signals because they are commonly used for transmitting sensitive data such as financial information, personal data, and government communications. Without encryption, these signals can be easily intercepted and accessed by unauthorized parties, compromising the security and privacy of the transmitted data.
4. What are the benefits of using optical signal encryption?
There are several benefits to using optical signal encryption, including increased security and privacy of transmitted data, improved network reliability, and greater resistance to interference and eavesdropping. It also allows for faster data transmission rates and larger bandwidth capacity compared to traditional electronic encryption methods.
5. Are there any challenges with optical signal encryption?
While optical signal encryption offers many advantages, it also presents some challenges. One of the main challenges is the complexity and cost of implementing and maintaining the necessary equipment and protocols for encryption. There may also be compatibility issues with different encryption methods used by different networks, making it difficult for them to communicate securely.
  • Computing and Technology
  • Electrical Engineering
  • General Engineering
