Optical trap Raman - oil refractive index matching
In summary, to improve Raman detection, it is recommended to use an immersion oil with a refractive index closer to the glass of the objective, around 1.51, or to consider using a specialized oil for Raman applications.
donroy81
I have a Optical trap that collects Raman. With Glass cover-slips we use a 1.51 refractice index oil (DF cargille). The trap works but glass has high auto-fluorescence at our excitation wavelength(785 nm9), the weak Raman can't be detected. So we use synthetic fused silica cover-slips with a refractive index of 1.48. The trap is weaker (no numbers yet, but I have been doing this for a while). Should an immersion oil with a lower refractive index ( like 1.48 for cargille FF) work better? That would be a mismatch with the glass from the objective. Any clues?
Science news on Phys.org
I would suggest trying to use an oil with a refractive index closer to the glass of the objective. Since the excitation wavelength is 785 nm, you could look for an oil with a refractive index that is close to 1.51. This would minimize the mismatch between the glass of the objective and the oil, and should help reduce auto-fluorescence. Additionally, some companies make special oils specifically designed for Raman applications, which may also help reduce auto-fluorescence.
Related to Optical trap Raman - oil refractive index matching
1. What is an optical trap Raman?
An optical trap Raman is a technique that combines optical trapping (using lasers to manipulate microscopic particles) with Raman spectroscopy (a method for analyzing the chemical composition of a sample). This allows for the precise measurement and manipulation of small particles or molecules in a liquid or gas environment.
2. How does oil refractive index matching work in optical trap Raman?
In optical trap Raman, a high refractive index oil is used to match the refractive index of the sample being studied. This reduces the scattering of light and improves the quality of the Raman signal, making it easier to obtain accurate measurements.
3. What are the advantages of using oil refractive index matching in optical trap Raman?
Oil refractive index matching allows for better control and manipulation of particles or molecules in the sample, as well as improved signal quality for more accurate measurements. This technique also reduces the risk of damaging delicate samples with high laser intensities.
4. Can any type of oil be used for refractive index matching in optical trap Raman?
No, not all oils are suitable for refractive index matching in optical trap Raman. The oil must have a high refractive index (close to that of the sample) and also be transparent to the laser and Raman wavelengths being used.
5. What types of samples can be studied using optical trap Raman with oil refractive index matching?
Optical trap Raman with oil refractive index matching is commonly used for studying small particles or molecules in liquid or gas environments. This technique has applications in various fields such as biological and medical research, environmental monitoring, and materials science.
