Optics. A laser beam is refracted in a piece of glass.
A red laser beam with a diameter of 3mm and power of 1mW is directed at a piece of glass with a refractive index of 1.5 and a thickness of 2 cm, at an incidence angle of 90 degrees. The front side of the glass is convex with a radius of curvature of 11 cm, while the back side is flat. The discussion revolves around calculating the distance from the focal point to the back side of the glass and determining the effect being focused at that point. Participants suggest using equations related to refraction in spherical surfaces and the concept of intermediate images for the two refractions involved. A sketch of the setup and clarification of variables are recommended for better understanding.
yglo98
Want help with physics question from my book.
My idea for 1. is to use the formula for refraction in spherical surfaces: (n1/2) + (n2/s') = (n2-n1)/R), where n is refraction index for glass and air. First I would apply it for the first front surface of the glass, then take the image of that and use it as the object for the second refraction in the back side. I would have to take into account for the sign convention and thickness of the lens.
For 2 I think that maybe we can approximate the 2 refractions as right angles and then use the formula: T=(1-R)*2, where the (initial intensity/transmitted intensity) = T, and R=(n1-n2)^2/(n1+n2)^2. It would be used two times, as in the 2 refractions. But exactly how I would write the intensity, effect and area in the right way to solve this I don't know.
A red laser with the diameter of 3mm is directed towards a piece of glass. It has the effect, P of 1mW. The angle of incidence is 90 degrees. The glass has refraction index n2= 1,5 and thickness 2 cm. Its front side is convex with a convergence radius,R, of 11 cm. The back side is plane.
  1. Whats the distance between the focal point and the back side of the glass?
  2. What effect is being focused in the focal point?
Appreciate all kinds of help! Am I thinking right?
Hello @yglo98 ,
:welcome: ##\qquad##!​
So what do we have here
Homework Statement:: A red laser with the diameter of 3mm is directed towards a piece of glass. It has the effect om 1mW. The angle of incidence is 90 degrees. The glass has refraction index 1,5 and thickness 2 cm. Its front side is convex with a convergence radius of 11 cm. The back side is plane.
Relevant Equations:: T=(1-R)*2
(Since you are new here, I thought it a good idea to show how the template is intended to be used -- see the PF guidelines)
And your work so far (without repetition) is
yglo98 said:
My idea for 1. was to use the forum for refraction in spherical surfaces and use the concept of intermediate image for the two refractions that take place.
Now,
Your relevant equation has no relationship with the variables that appear in the problem statement.
You don't explain what ##T## and ##R## are, but I guess Transmission and Reflectance.
Since the exercise comes from your book, you might want to try and find relevant equations there that have to do with focal length, thick lenses, etc.
A sketch of the situation showing some of the known variables might be a good thing to post as well ...
Likes fresh_42 and yglo98
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
