Optics - destructive interference
In summary, the conversation discusses a problem involving white light shining on a layer of water on a sheet of plastic film. The minimum thickness of water needed to produce destructive interference on the surface is being asked. The solution involves calculating the phase difference between incident and reflected beams at the air/water and water/plastic interfaces, and equating it to the phase difference condition for destructive interference. The general relation between thickness and phase difference is also discussed.
ChuckB
White light (most intense at 550nm wevelength) shines on a layer of water (n=1.33) setting on a sheet of plastic film (n=1.25). What minimum thickness of water will produce destructive interference on the surface?[/B]
a) phase reversal of light reflecting off an optically denser medium
b) n=c/v (?)[/B]
I am absolutely stumped on this problem. 1) The light reflecting off the top of the water layer will be, as I understand it, phase reversed by the reflection. 2) The light will also slow as it enters the water such that v = c / Nwater, and then reflect back through the water to interfere destructively with the light in 1. This seems to tell me that if the water is one molecule thick, there would be destructive interference due to the phase reversal? As you may be able to tell, I'm just flat stumped. Any help greatly appreciated.[/B]
It doesn't ask for the constructive interference?
I double checked, it asks for that minimum thickness of water that will result in destructive interference.
Ok, then what you need is the expression of the optical path difference between the rays reflected from the upper surface of the water (air-water interface) and those reflected from the bottom surface (water-plastic interface). Since it's not specified, you can assume normal incidence of the light. See the picture below,
If the thickness is ##d##, what is the distance traveled by the rays which is reflected from the bottom surface?
That would be 2d. So d should be half the wavelength of light in water (n=1.33). Or am I oversimplifying?
Although, this is probably not what is asked from you in the exercise you mention, you are correct.
A soap bubble film has a similar construction similar to your problem: low n (air) / High n (soap) / Low n (air). As you may suspect, the iridescent colors of a bubble are due to thin film interference. With time, the thickness of the bubble wall will decreases. When the film reaches a thickness such that the bubble is about to pop, notice the change in color: the bubble becomes transparent - all reflected (visible) light is cancelled.
However, I suspect that what is asked from you is to find the a non-negligible thickness.
First, determine the phase difference between incident beam and beam reflected at the air / water interface: Φ1
Second , determine the phase difference between incident beam and beam reflected at the water / plastic interface: Φ2
equate the difference (Φ2 - Φ1) to the phase difference condition for destructive interference, and rearrange the equation so you can calculate the minimum thickness.
Right, it's 2d. So what is the phase accumulated by this ray when it emerges at the upper surface? Having found this, find the phase accumulated by the ray reflected at the upper surface, then take the phase difference between the phases of the two rays.
That might be the case, but I will let the OP derive the general relation between the thickness and phase difference to allow him to know why a negligible thickness can occur as the answer in this problem.
FAQ: Optics - destructive interference
1. What is destructive interference in optics?
Destructive interference in optics is a phenomenon where two or more light waves with opposite phases cancel each other out, resulting in a decrease or complete elimination of the light's intensity. This occurs when the peaks of one wave align with the troughs of another wave, causing them to cancel each other out.
2. How does destructive interference affect the color of light?
Destructive interference can affect the color of light by causing certain wavelengths to be canceled out, resulting in a change in the color of the light. For example, if red light and green light are combined and experience destructive interference, the resulting light may appear blue, as the red and green wavelengths are canceled out.
3. What is the difference between constructive and destructive interference?
The main difference between constructive and destructive interference is the resulting intensity of light. In constructive interference, the waves combine to create a higher intensity of light, while in destructive interference, the waves cancel each other out, resulting in a decrease or elimination of the light's intensity.
4. How can destructive interference be used in practical applications?
Destructive interference has practical applications in many areas, such as in anti-reflective coatings for glasses and camera lenses. By using destructive interference, these coatings can reduce glare and increase the clarity of the image. Destructive interference is also used in some types of noise-cancelling headphones and in optical filters to block specific wavelengths of light.
5. Can destructive interference occur with other types of waves besides light?
Yes, destructive interference can occur with other types of waves, such as sound waves, water waves, and electromagnetic waves. The principles of destructive interference remain the same, with the waves canceling each other out when they are out of phase. This phenomenon is not limited to just light waves.
