Optics Equations - to reduce height
  • Thread starter Thread starter btb4198
    Height Optics
An optics equation to reduce the height and distance in an existing setup while maintaining focus is not straightforward, as the original poster's description lacks specific details about their system. The simple lens equation (1/u + 1/v = 1/f) is relevant, but merely reducing the diameter and spacing of optical elements without adjusting their power can degrade image quality. The discussion highlights that optimizing optical systems is complex and often requires multi-element lenses designed for specific parameters. Additionally, the impact of f-stop values on image quality is noted, with f8 being a practical choice for most photography. More detailed information from the original poster is necessary for a precise solution.
btb4198
Is there an optics equation that can take an existing optics set-up and tell you would components, you would need to reduce the distance and still get the same result?
I have a working system, but it is really larger and I would like to reduce the distance, the height.
I am using a light source to pre-analyzer filter to lens to camera, a basic Optical setup.
Is that any equation I can use ?
Science news on Phys.org
That's all a bit too open ended for a proper answer, I'm afraid. What's the actual set-up and what do you actually need to know? A diagram is always worth the effort.
I want to reduce the distance from the camas to the lens and keep my same focus.
That still doesn't mean a lot to me, I'm afraid. You may know what you mean but you are leaving out a lot of stuff that's necessary for me to understand you.
I presume you know the simple lens equation (1/u +1/v = 1/f) and the ratio of image and object size being equal to the two distances. Have you read around about this or is this your first taste of optics? It isn't clear.
Reducing the diameter and spacing of the elements without changing their power will do nothing but make your image worse. Optical systems are notoriously difficult to optimize, so I'm not sure there's a simple equation that would work. Unfortunately my 2 semesters of optics didn't give me enough knowledge to elaborate further or give a concrete answer.
Likes sophiecentaur
Whilst this is sometimes the case, most camera lenses sit between diffraction and aberration problems. For a lot of photography, diffraction is not a problem and f values around f8 will give least impairment. f1.4 is a great advantage for low light or movement but not a 'preferred value' when a smaller stop will work.
The OP is far too vague for a good answer, as I have already said. If the requirement is very critical then any suitable (obviously multi-element) lens would be optimised for its size and you'd have to pay for it!
Some input from OP is required now.
I would like to use a pentaprism with some amount of magnification. The pentaprism will be used to reflect a real image at 90 degrees angle but I also want the reflected image to appear larger. The distance between the prism and the real image is about 70cm. The pentaprism has two reflecting sides (surfaces) with mirrored coating and two refracting sides. I understand that one of the four sides needs to be curved (spherical curvature) to achieve the magnification effect. But which of the...
