Optics fibre dispersion, pulse propagation
T=5*\Delta \tau.In summary, we are asked to draw a diagram of a pulse train consisting of Gaussian shaped pulses traveling in a single mode fiber. The separation of the pulse centers is five times the temporal width of an individual pulse, and the dispersion of the material is given. Using the given equations, we can calculate the spectral width and temporal broadening of the pulse, which allows us to draw the diagram of the pulse train.
cabam
A pulse train of Gaussian shaped pulses travels in a single mode fibre. The separation (T) of the pulse centres is five times the temporal width ([tex]\Delta[/tex] [tex]\tau[/tex]) of an individual pulse i.e. T=5*[tex]\Delta[/tex] [tex]\tau[/tex]. The dispersion of the material is D=200ps/nm/km.
L=0.1km, n plastic = 1.4, n air = 1.0 [tex]\lambda[/tex]=630nm
a)draw a diagram of the pulse train.
[tex]\Delta[/tex]T=D*[tex]\Delta[/tex][tex]\lambda[/tex]*L
[tex]\Delta[/tex][tex]\lambda[/tex]=[tex]\lambda[/tex]^2/(c*[tex]\Delta[/tex][tex]\tau[/tex])
[tex]\Delta[/tex][tex]\lambda[/tex]=(5*[tex]\lambda[/tex]^2)/(T*C)
[tex]\Delta[/tex]T= 2.1ps/T
im not sure where to go from here, help would be much appreciated :)
Hello! Thank you for your post. I am a scientist and I would be happy to assist you with this problem.
First, let's start by discussing the information given in the problem. We are told that the pulse train consists of Gaussian shaped pulses, which means the amplitude of the pulses follows a Gaussian curve. This is important to note because it affects the shape of the pulses in the diagram.
Next, we are given the separation of the pulse centers (T) and the temporal width of an individual pulse (\Delta \tau). We are also given the dispersion of the material (D) and the length of the fiber (L). The refractive indices of the plastic and air are also provided, along with the wavelength (\lambda) of the pulses.
To draw the diagram of the pulse train, we need to first understand how the pulses will behave in the fiber. The dispersion of the material (D) will cause the different wavelengths of light to travel at different speeds, leading to a spreading out of the pulse. This is known as chromatic dispersion. The equation for chromatic dispersion is given as:
\DeltaT=D*\Delta\lambda*L
where \DeltaT is the temporal broadening of the pulse, D is the dispersion of the material, \Delta\lambda is the spectral width of the pulse, and L is the length of the fiber.
Now, we can use the given equations to calculate the spectral width of the pulse (\Delta\lambda) and the temporal broadening of the pulse (\DeltaT). The equation for the spectral width of the pulse is:
\Delta\lambda=\lambda^2/(c*\Delta\tau)
where c is the speed of light. Plugging in the given values, we get:
\Delta\lambda=(5*\lambda^2)/(T*c)
Now, we can use the calculated value of \Delta\lambda to find the temporal broadening of the pulse using the equation for chromatic dispersion:
Plugging in the values, we get:
\DeltaT=200ps/nm/km * (5*\lambda^2)/(T*c) * 0.1km
Simplifying, we get:
\DeltaT= 2ps/T
Now, we can use this value of \DeltaT to draw the diagram of the pulse train. The diagram will consist of a series of Gaussian pulses, with a temporal width of 2ps,
Related to Optics fibre dispersion, pulse propagation
What is optics fibre dispersion?
Optics fibre dispersion is the phenomenon in which an optical pulse, or light signal, spreads out as it travels through a fibre optic cable. This is caused by the different wavelengths of light within the pulse traveling at different speeds, resulting in the pulse becoming distorted and dispersed.
What factors affect optics fibre dispersion?
The main factors that affect optics fibre dispersion are the type of fibre used, the wavelength of the light signal, and the length of the fibre. Different types of fibre have different dispersion characteristics, and longer fibres will cause more dispersion. Additionally, the higher the frequency (or shorter the wavelength) of the light, the more dispersion will occur.
How does optics fibre dispersion impact data transmission?
Optics fibre dispersion can impact data transmission by causing the light signal to become distorted and spread out, which can result in errors and loss of information. This can decrease the quality and speed of data transmission, and can also limit the distance that the signal can travel without needing to be amplified or regenerated.
What techniques are used to combat optics fibre dispersion?
There are several techniques used to combat optics fibre dispersion, including dispersion-shifted fibres, dispersion-compensating fibres, and dispersion management. These techniques involve altering the properties of the fibre and/or using additional components to manipulate the dispersion and keep the light signal intact.
How is pulse propagation affected by optics fibre dispersion?
Optics fibre dispersion affects pulse propagation by causing the pulse to spread out and become distorted as it travels through the fibre optic cable. This can result in a decrease in pulse intensity and duration, and can also cause changes in the phase of the pulse. These effects can impact the quality and accuracy of data transmission.
