Optics - Find the refractive index
In summary, the problem involves finding the refractive index of a material of a spherical surface, given an object located at a distance R from the surface and a final image formed at the same distance R on the other side of the sphere. Using the equation for refraction at spherical surfaces and ray tracing, the angles of the green ray can be calculated. Applying Snell's Law and the small-angle approximation, a relationship between the object distance, image distance, and refractive index can be established. However, further calculations are needed to determine the exact value of the refractive index.
Saitama
4,243
93
An object is located at a distance R from a sphere of radius R. The final image is formed at the same distance R on the other side of the sphere. Calculate the refractive index of the material of the sphere.
Since we are dealing with refraction at spherical surfaces, the equation to be used is:
$$\frac{\mu_2}{v}-\frac{\mu_1}{u}=\frac{\mu_2-\mu_1}{R}$$
I take the direction to the right as positive.
Refraction at the first surface, ##\mu_2=\mu##, ##\mu_1=1## and ##u=-R##:
$$\frac{\mu}{v}+\frac{1}{R}=\frac{\mu-1}{R}$$
Solving for v,
$$v=\frac{\mu R}{\mu-2}$$
I have to apply the equation for the second surface now but the problem is how do I calculate u? I don't know if the image formed by first refraction lies outside or inside the sphere.
Any help is appreciated. Thanks!
Try ray-tracing, using the symmetry of geometry.
ehild
ehild
I really have no idea what you mean. Please elaborate. :redface:
See picture. The blue and green rays are easy to follow.
ehild
ehild
Why the green ray deviates? It passes through the pole of refracting surface, it should pass without deviation, no? :confused:
Snell's law?
voko said:
Snell's law?
Silly on my part, sorry.
But I still don't see how to calculate u. :(
By u, I mean the distance of image formed by the first surface from the second surface.
The green ray has three segments, let's call them, left to right, A, B and C. Let the angles of the green ray with the normals at the interfaces be, left to right, a, b, c, d. What of these can you not calculate, given the size of the object is s and the radius of the sphere is R?
I can calculate all of them. Also, angle b is equal to angle c and angle d is equal to a. Correct?
What remains to be done, then?
Yes.
Find the location of image formed by the first refraction? I still have no idea about this.
I am not sure what "first refraction" is. The whole point of ray tracing is that two rays must meet in one location. And that should yield a condition on whatever ray tracing is used for.
I meant that the image formed by the refraction through the spherical surface nearest to object.
:rolleyes:...:confused:
Think what is required for the two rays to meet at the image.
They should not diverge? :-p
I am still clueless. :cry:
The two rays must meet at the specified distance behind the sphere.
Why do you want to find the first image when you know the position of the final image? And you also know its height. And you know Snell's Law. And you can apply the small-angle approximation.
By the way, if you want to know the position of the first image at any cost: The final image is real. If the image formed by a concave surface is real, is the object real or virtual?:-p
ehild
And do not forget that the refractive index is sin(a)/sin(b), a/b at small angles.
ehild
Why not? :confused:
I think about the problem this way. Since the rays refract twice from the spherical surface, I have to apply the equation I posted twice. First, I apply it for the refraction at the first spherical surface (near to the object) and find the location of image formed. Now the rays refract at the second surface (surface near the final image). I will have to calculate the distance of image formed by the first surface from the second surface. The first image formed acts as the object for the second surface. I again apply the same equation for the second surface and calculate ##\mu##.
Am I thinking along the wrong lines? :confused:
ehild
Object is real.
Snell's Law is more basic than the equation you use to find the images. It can happen that the image distance is longer than 2R: the first image is behind the sphere. (It is not there really, only virtually.) The first image is object for the second surface. Normally, the object should be in front of the surface, but what is the object distance for the second spherical surface if the object is behind it?
The problem asks the refractive index. Can you determine it from the data given?
ehild
The distance is ##\frac{\mu R}{\mu-2}-2R=\frac{(4-\mu)R}{\mu-2}##.
I choose the direction to the right to be positive. Applying the equation to second spherical surface,
$$\frac{1}{R}-\cfrac{\mu}{\cfrac{(4-\mu)R}{\mu-2}}=\frac{1-\mu}{-R}$$
Solving this gives ##0=-4##. :confused:
No idea but let me try making the equations.
Applying Snell's law on the first surface, ##\sin(a)=\mu \sin(b)##. From small angle approximation, ##\sin(a)=a=\tan(a)=s/R##, ##\Rightarrow s/R=\mu b \Rightarrow b=\frac{s}{R\mu}##. Angle subtended by the object at center is s/(2R). I don't see a way ahead. :confused:
Your solution is wrong. Check.
How are the red and green angles related?
Are you sure you ask me those two red angles? It looks like you marked the wrong angles. I am sorry if I have missed something.
I assume you mean to ask me this:
$$\text{Red angle}=\frac{\text{Green angle}}{2}$$
No. I asked how a red angle is related to a green one. And their ratio is not 2.
Yes, you are right, their ratio is not 2. Sorry. :redface:
Red angle, y=s/(2R). Green angle, x=s/(Rμ)=2y/μ. Looks good?
The red angle is equal to the green angle. Do you see it? So s/(2R)=s/(Rμ). So what is the refractive index?
ehild
No, do you mean that the green and blue ray are parallel? If so, how do you conclude that? :confused:
The part of the green ray inside the circle is parallel with the blue line which goes across the centre of the circle.
See figure.
Likes 1 person
See figure.
Thanks, this gives ##\mu=2##.
Can you tell me how you thought of applying the Snell's law and apply the small-angle approximation? The question says nothing about the approximation so how am I even supposed to think about that?
The formula you used to find the image distance is derived from Snell's Law, using small-angle approximation. Was not it shown to you?
Now, that you know the refractive index, you find the first image at infinity, beyond the sphere. And it is a virtual object for the second surface. Quite confusing is it not? But solving the problem with Snell's Law no such problem arises, everything is clear.
By the way, you get the same refractive index with your method if you solve the last equation correctly. ehild
  • #31
Yes, it was shown to me, I forgot about it. Thanks a lot ehild! :)
I still don't get the correct answer with that equation. I always end up with 0=-4. I feel there is some sign error in my last equation but I can't spot it. :frown:
  • #32
[tex]\frac{1}{R}-\cfrac{\mu}{\cfrac{(4-\mu)R}{\mu-2}}=\frac{1-\mu}{-R}\rightarrow[/tex]
[tex]1-\frac{\mu(\mu-2)}{4-\mu}=-1+\mu\rightarrow 2-\mu+\frac{\mu(2-\mu)}{4-\mu}=0 \rightarrow \left(2-\mu\right) \left(1+\frac{\mu}{4-\mu}\right)=0[/tex]
2-μ can be factored out, and you get a product equal to zero. One of the factors must be zero. The second one can not. Never "simplify" an equation dividing by a term that contains the unknown!
  • #33
Thanks a lot ehild! I need to be more careful while solving the equations. Thanks. :)
Related to Optics - Find the refractive index
1. What is the refractive index?
The refractive index is a measure of how much a material bends or slows down light as it passes through it. It is the ratio of the speed of light in a vacuum to the speed of light in the material. It is denoted by the symbol "n" and has no units.
2. How is the refractive index measured?
The refractive index can be measured using a variety of methods, including Snell's law, which involves measuring the angle of incidence and angle of refraction of a light ray passing through a material. Other techniques include interferometry, ellipsometry, and spectroscopy.
3. What factors affect the refractive index of a material?
The refractive index of a material is affected by several factors, including the density and composition of the material, the wavelength of light passing through it, and the temperature and pressure of the environment. It can also vary depending on the direction of light passing through the material, known as anisotropy.
4. How does the refractive index impact the behavior of light?
The refractive index determines how light bends or refracts as it passes through a material. This affects a variety of optical phenomena, such as the formation of images by lenses, the dispersion of colors in a prism, and the reflection and refraction of light at the interface between two materials.
5. What are some common materials with high and low refractive indices?
Materials with high refractive indices include diamond, which has a refractive index of 2.42, and water, which has a refractive index of 1.33. Materials with low refractive indices include air, which has a refractive index of approximately 1, and glass, which has a refractive index ranging from 1.5 to 1.9 depending on its composition.
