Optics: white object reflection properties
In summary, when a red light is dropped on a red object, all of the red light is reflected and none is absorbed. However, when a red light is dropped on a white surface, some of the light will be absorbed and the intensity of the reflected light may be lower due to the diffuse reflection. It is possible for a white surface to have the same reflectivity as a red surface for a specific wavelength, but adding color to the white surface may change its reflectivity. Therefore, the total energy reflected may be a better parameter to consider rather than just the color of the reflected light. Additionally, it is not possible to have a device that is simultaneously sensitive to both the amount and intensity of the light absorbed.
Maniaks
If a red light drops on a red object, we know that all of the red light is reflected, and none is absorbed. But what happens if a red light drops on a white surface, is all of the red light reflected, will the intensity of the reflected light be the same? Or will the reflected light be of a different spectrum(meaning different colour, since a very small portion is absorbed)?
Science news on Phys.org
In both cases some light will be absorbed.
And the light reflected by the white surface will have the same wavelength as the incident light. Unless there is some fluorescence induced by the red light. (Not very likely for red light on paper)
How about the intensity? Will it be the same?
Probably not. It is very unlikely both surfaces would have the exact same reflectivity, but not impossible.
What Drakkith said.
But a "white surface" is not a mirror (is it?) and the reflected light will be diffuse. So the intensity (energy per unit area of angle) will be lower. But this is true (or may be) for the red surface too.
It may be that you are not asking the right question. Total energy reflected may be a better parameter. And this may be the same or not. Color is not the only factor.
If I had an device which would be sensitive to the amount and intensity of the light absorbed, would it show the same value(assuming the proposed variable is dependant on the factors mentioned before) for a red surface and a white one(not mirror)(presume a red light is falling to the incident plane, and the reflected the light is measured), assuming both of the surfaces are more or less the same(only the colour differs)? From your answers, I conclude that they would be the same, I just want to confirm this.
How would you have a device sensitive to the light absorbed?
If it's absorbed, it's not there to be "sensed", is it?
I don't really understand your goal. What do you mean by "proposed variables"? What are these variables? And what is the "incident plane"?
Adding color to a white surface may change its reflectivity.
But you can also have two surfaces, one white and one red, with the same coefficient of reflection for you specific wavelength. What more is to it? The reflectivity of the surface depends on properties of the material as well as the wavelength of the incident radiation.
Related to Optics: white object reflection properties
1. What is a white object in optics?
A white object in optics refers to an object that reflects all wavelengths of visible light equally, giving it a pure white appearance to the human eye. This is due to the object's surface reflecting all incoming light without absorbing any particular color.
2. How do white objects reflect light?
White objects reflect light through a process called diffuse reflection. This means that incoming light rays are scattered in all directions when they hit the object's surface, resulting in a uniform reflection and the perception of white color.
3. Why do white objects appear brighter than dark objects?
White objects appear brighter than dark objects because they reflect more light. Dark objects, on the other hand, absorb more light, resulting in less light being reflected back to our eyes and the perception of a darker color.
4. Can white objects have different reflection properties?
Yes, white objects can have different reflection properties depending on their surface texture and composition. For example, a rough white object may reflect light differently than a smooth white object, resulting in a different perceived color or brightness.
5. How does the color of the light source affect the reflection properties of a white object?
The color of the light source can affect the reflection properties of a white object by changing the color of the light being reflected. For instance, a white object may appear slightly yellow when lit by a yellow light source due to the selective reflection of yellow light by its surface.
  • Optics
