Optimal amount of CO2 to purge air in a device
In summary: I would be effectively measuring the flow rate from the entire length of the tubing, not just from the nozzle.
Lyd_h
<Moderator's note: Moved from a homework forum.>
Dear team, I wish to use CO2 to de-air a device by exploiting the physical properties of CO2 as a heavier, more dense gas to air and therefore displace air in a very thin tube that has a nozzle at the end where both air and CO2 can escape.
I wish to know under what conditions should I study CO2 to effectively remove air. I think that I would need a high flow rate to ensure that diffusion with air within the tube is counteracted, a low velocity of CO2 to ensure laminar flow within the tube to reduce turbulence of CO2 and again ensure optimal air displacement, and deliver the CO2 at a high pressure and high pressure leads to low velocity.
The CO2 would be delivered from a standard cylinder tank that has a pressure gauge attached to it. A CO2 flow meter is attached to the pressure gauge and from the flow meter, 1/4inch tubing of length 120cm is then attached to the device which itself is about 120cm long and has an internal diameter of 8mm.
As there may be a pressure drop along the length of the CO2 tube and device tube, I am not sure if I need to also take this into account.
I thought about having a flow meter at the end of the device where CO2 comes out to look at what flow rate is actually coming out of the device.
2. Homework Equations
Ficks law
Grahams Law
Bernoulli's equation
3. The Attempt at a Solution
Have yet to test out the above assumptions.
Hello Lyd, ##\qquad## :welcome:##\qquad## !
Is there any reason the two flowmeters would show something different ?
So is the tube vertical ?
Lyd_h said:
effectively
'Effectively' meaning what, precisely ?
As you can see: you ask one question, get three in return :smile:
Funny you call 8 mm 'very thin' but don't say anything about the 1/4 "
That would count as 2 to 1 in a democratic process, and the 'highs' would carry it :wink:
Aren't you making this more diffficult than necessary ?
You can get some ideas by looking at wire feed welders. They use CO2 or Argon/CO2 as shielding gas, and are up against the same questions of laminar vs turbulent flow to displace air. Use search term wire feed welder gas flow rate to learn about flow rates.
The shielding gas displaces air to improve weld quality. To find if the flow is laminar or turbulent, measure the diameter of a welding nozzle, estimate a range of flow rates from your search results, and calculate some Reynolds numbers. Most any university engineering department will have a machine shop with a wire feed welder, if not, go to the maintenance department. And, like @BvU says, try to avoid overthinking the problem.
Likes sysprog
No. But wouldn’t the CO2 delivered flow at the beginning of the tube change at the end of the tube where the nozzle is, given that the tube has wires inside and a PTFE cylinder that is crushed down. So I’d expect there to be resistance to flow from these things? So even though my flow meter is set to deliver say 2l/min, what actually end up being delivered may be less? So is the tube vertical ?
Yes the tube is elevated to allow air to be purged
If I were to measure the o2 (as a surrogate of air) and CO2 concentrations, i’d find CO2 in high % and 02 in low % for a given time
Maybe? But to effectively de-air a gas with another gas, aren’t the flow rates, pressure and velocity of the displacing gas important so that you can be sure displacemt of the unwanted air is efficient? N
Is there something in my questions that is unclear ? You did not answer any
So sorry
I’m still getting used to this forum.
I answered below your questions
Will sneer here as well.
1. The flow meteres are the same, however, the tube has wires and a PTFE cylinder that is crushed down. All of this within the tube I would think would create resistance to flow, so even if I deliver CO2 say at 2l/min from the cylinder, wouldn’t there be loss of this down-stream because the gas would encounter these resistances to flow? So the flow actually coming out of the tube may not be what is delivered?
2. The tube is elevated to allow the de-airing
3. Effective means that as time goes on I would expect that there would be near 100% CO2 and very little 02 (as a surrogate marker of co2) . I would measure this with a gas sensor.
I may be making this more difficult... but, as we’ll be de-airing several devices, I would need the same flow-rate, velocity and pressure of CO2 that would de-air the device. And each of these parameters would have an ideal level?
Thank you!
Fair enough, all in good spirits :smile:
1. Flowmeters usually measure flow in Nl/min (or SCFM in some backcountries), i.e. proportional to the mass flow. No leakages --> same mass flow.
2. 'The tube', or 'one end of the tube'? I'll assume the latter :cool:
3. If you want less than 1 ppb of O2 you'll have to flush longer than if you need less than 1 ppm, that's what I meant. 'Near 100%' conveys no information.
wires? it it hairy? I assume the crushed PTFE leaves at least some room for the gas to pass ? How much ?
Nice to know. Means longer flushing, as you indicated.
You could assume a worst case and treat the volume before the PTFE constriction as an ideally stirred tank
Thank you! That’s all really helpful!
Yes my plan was to assume worst case ‘amount of air ‘ within the PTFE tube when the PTFE is a cylinder rather than when it is crushed down because it will be impossible to know the exact volume of dead space/air when it is crushed down.
When it is crushed down it also has a wire running through it which will also take up space within the PTFE cylinder but again it will be tricky to know what volume that small segment of wire is to then subtract that from the total volume of the PTFE cylinder.
So, using are x length of the PTFE cylinder, I will
Estimate the volume of air that needs replacing with co2. When the PTFE cylinder is crushed down it looks like spokes of a wheel type pattern in cross section so of course there’ll be air within the main lumen
and then air in between all the folds.
I know CO2 can get into
All
Of these spaces because I can feel a jet of CO2 out of the other end.
But there will be an optimum flow rate of CO2 needed to fill up the crushed cylinder and displace air, and so I wanted to know the best way to deliver CO2 to reduce turbulence of CO2 with air within the cylinder (which I think needs a low velocity) and I wasn’t sure how pressure of CO2 on the pressure reg fitted into this... Sorry I have probably not made my questions clear from the beginning!
I tend to agree :rolleyes:. On the other hand, I commend you for thinking about what exactly is the question to be answered, before working on answering just any question that pops up.
Something I saw makes me raise an eyebrow:
So why bother to calculate at all ? Flush until O2 < desired maximum !
Is the air being displaced to prevent corrosion of the equipment, prevent fire, chemically infuse the material, prevent oxidation, or what?
This can all be modeled pretty easily. Is the flow rate of 2 l/min roughly what you would plan to use, give or take?
Thread closed temporarily for Moderation...
Thread will remain closed at OP request. Thank you all for some great and helpful replies. :smile:
Related to Optimal amount of CO2 to purge air in a device
1. What is the optimal amount of CO2 needed to purge air in a device?
The optimal amount of CO2 needed to purge air in a device depends on various factors such as the size of the device, the level of contamination, and the desired level of purity. Generally, a concentration of 3-5% CO2 is considered optimal for purging air in most devices.
2. How does CO2 purging help in maintaining device cleanliness?
CO2 purging helps in maintaining device cleanliness by displacing oxygen, which is necessary for microbial growth, and reducing the moisture content in the air. This creates an inhospitable environment for microorganisms, preventing contamination and maintaining device cleanliness.
3. Can purging with CO2 be harmful to the device or its components?
No, purging with CO2 is not harmful to the device or its components. CO2 is a non-toxic, non-reactive gas that does not leave any residue. It is safe to use for purging air in devices and does not cause any damage to the device or its components.
4. Is there a specific procedure for purging air with CO2 in a device?
Yes, there is a specific procedure for purging air with CO2 in a device. It involves connecting the device to a CO2 supply and gradually increasing the flow rate to achieve the desired concentration. The purging process should be monitored carefully to ensure the optimal amount of CO2 is being used.
5. Can CO2 purging be used for all types of devices?
CO2 purging can be used for most devices, but it may not be suitable for all types. Some devices may be sensitive to changes in temperature or pressure, which can be caused by CO2 purging. It is important to consult the device manufacturer or conduct testing to determine if CO2 purging is suitable for a particular device.
  • Biology and Medical
  • Mechanical Engineering
