Optimal Dragster Exhuast Pipe Angle: Energy of Systems and Force
In summary, a top-fuel dragster's ability to accelerate at a rate of 5g is due to its elimination of tire tread and use of engine exhaust. In order to achieve maximum acceleration, the exhaust pipes should be oriented at an angle of 68 degrees with respect to the horizontal. This is determined by taking into account the normal force, friction force, and exhaust force in the x-direction and finding the value of θ that maximizes acceleration.
winowmak3r
24
I'm having a real hard time on the last homework question for this week for my Uni Physics I course. Here it is:
Top-fuel dragsters can accelerate from rest at a rate of about 5g. If this does not sound impressive, consider that for most automobiles the friction between the ground and the tires produces the acceleration. Since the coefficient of friction between regular treaded tires and pavement is typically less than or about equal to 1.0, a car relying on friction with normal force equal to its weight should accelerate at no more than about 1g.
Dragsters use two methods to increase their acceleration. First, they greatly increase the friction between their tires and the road by eliminating tire tread (dragsters do not race in wet or snowy road conditions) and also by performing a “burnout” which lays down a patch of heated rubber on the track that the partially-melted tires will adhere to. The result of these measures is a coefficient of friction exceeding 2.0. The second important method for increasing acceleration is the use of engine exhaust to provide force. The high-speed exhaust gases exiting the dragster’s enormous 8000 hp engine produce a force with a size comparable to the car’s weight.
a.) Assuming a coefficient of friction equal to 2.5, at what angle θ measured with respect to the horizontal (bottom picture) should the exhaust pipes be oriented in order to achieve maximum acceleration? Assume the engine is capable of using the tires to produce a force equal to the maximum friction force (μN) regardless of how large the normal force becomes!
θ
b.) Supposing the coefficient of friction is 2.5 and the exhaust is configured at the optimal angle found in part (a), how much force (as a fraction of the dragster’s weight) would the exhaust have to produce if the dragster accelerates from rest at 4.7g?
F=m*a
F(friction)=uN
W=F*r*cos(theta)
More?
I honestly have no idea. The correct answer for part a is 68 degrees (After much coercing the professor gave us the answer to part a but wouldn't tell us how to get there yet). A friend and I tried to do this problem and came up with 0 degrees but the logic was pretty shaky. Basically we reasoned that if u is 2.5, and the normal force is m*g*cos(theta) then you would want cos(theta) to be 1, hence zero degrees.
Any help is much appreciated!
Hello winowmak3r,
Oooh, this is a fun [phun] physics problem! 'Best I've seen in awhile. :smile:
It's not zero degrees. Your instructor's ~68o answer to part a.) is correct.
The normal force is not mgcosθ. The car is on a flat, horizontal surface. So the part of the normal force due to the car's weight is not a function of θ. In addition to the car's weight, there is the force of exhaust pushing down on the car, and that is what is a function of θ. Both the car's weight and this exhaust force combine to make up the car's normal force.
Start by defining a notation for the magnitude of the force of the exhaust. Call it Fe (you can call it anything you want, but you have to call it something). You don't know what its actual value is yet. And it turns out you don't need to know its value. But you do need to put Fe into your equations.
Now let me guide you by asking the following questions:
o What is the normal force (in terms of m, g, Fe, and θ)?
o How do you express Newton's second law (ma = ∑F) in the x-direction (horizontal only)? (Hint: there are two forces involve, the frictional force that is related to the normal force, and also the exhaust force which is related to Fe and θ.)
o What value of θ maximizes the acceleration a? (Hint: it involves taking the derivative of something and setting the result equal to zero. Answer pops right out [well, with a tiny bit of algebra, that is].)
Good luck! :smile:
Related to Optimal Dragster Exhuast Pipe Angle: Energy of Systems and Force
1. What is the optimal angle for a dragster exhaust pipe?
The optimal angle for a dragster exhaust pipe is typically between 35-45 degrees. This angle allows for the most efficient release of exhaust gases and helps to minimize drag on the vehicle.
2. How does the angle of the exhaust pipe affect the energy of the system?
The angle of the exhaust pipe affects the energy of the system by determining the direction of the exhaust gases. A properly angled exhaust pipe can help to minimize back pressure and increase the efficiency of the engine, resulting in higher energy output.
3. What role does force play in determining the optimal exhaust pipe angle?
Force plays a crucial role in determining the optimal exhaust pipe angle. The force of the exhaust gases exiting the pipe must be balanced with the force of drag on the vehicle. The angle of the exhaust pipe helps to minimize the force of drag and maximize the force of the exhaust gases.
4. How do other factors, such as air resistance, impact the optimal exhaust pipe angle?
Other factors, such as air resistance, can impact the optimal exhaust pipe angle. The angle must be adjusted to account for the direction and strength of the wind, as well as the shape and size of the vehicle. These factors can affect the drag force on the vehicle and therefore, the optimal angle for the exhaust pipe.
5. Are there any other considerations when determining the optimal exhaust pipe angle?
In addition to the factors mentioned above, there are other considerations when determining the optimal exhaust pipe angle. These may include the type of fuel being used, the temperature and pressure of the gases, and the design and placement of other components of the vehicle's exhaust system.
