MHB Optimisation Problem (Global extreme points)
The discussion revolves around finding the global extreme point of the function f(x) = e^(x-1) - x. The derivative f'(x) is set to zero, leading to the conclusion that x = 1 is a critical point, which is confirmed as a minimum by the second derivative test. The confusion arises from interpreting the term "minimizes f(x)," where it is clarified that this refers to the x-value at which the minimum occurs, not the minimum value itself. The minimum value of the function at this point is f(1) = -1. Thus, x = 1 is the correct point that minimizes the function.
Foosey96
Hi there everyone, wonder if anyone can help as I'm a bit confused.
Ive been asked to find the global extreme point of f(x)=e^(x-1) - x.
I have checked my answer against the solution and am correct and my working is as follows:
f'(x) = e^(x-1) - 1 = 0. Therefore (x-1)=ln1 (which = 0) therefore x = 1.
f''(x) = e(x-1). sub in x=1 and f''(x) = 1 which is > 0 hence the extreme point is a minimum.
The solution however then goes on to conclude that x*=1 minimizes f(x)
This is what I am confused by as I thought minimum points by their nature were the y-values not the x values and hence x* should actually be e^(1-1) - 1 = 0 and so x*=0 minimizes f(x)??
Thanks for any help you can give that final conclusion has just thrown me off. Thanks everyone!
Mathematics news on Phys.org
What they said is correct. To say that x = 1 minimises f(x) is to say that when x = 1 IN the function, then the function value will be at its minimum.
Here the minimum value is f(1) = e^(1-1) - 1 = -1.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
