Optimization algorithm to apply to my system?
In summary, the conversation discusses the speaker's project to minimize the annual running costs of a chemical manufacturing plant through the use of a model with over 50 inputs. They are currently trying to optimize the system and are considering using a metaheuristic method such as Genetic Algorithm or PSO. The speaker is also seeking suggestions and relevant literature for their problem and is wondering if minimizing the cost could be the fitness function. They also mention that their variables have multiple possible choices.
GregoryB82
I am at the moment working on a project in which I try to minimize the annual running costs of a chemical manufacturing plant. To predict annual running costs I created a model with over 50 inputs, including things such as the type of chemicals and equipment used at different points in the process, type of renewable system used to provide energy, type of air conditioning system used at the plant, etc. Some of these inputs are binary (yes/no), while others contain a number of choices (e.g. for renewable system we have a choice of wind/solar/biogas). The model outputs a single number (overall running costs).
Currently I am trying to optimize the system (i.e. find minimum cost) and I have studied some relevant literature. However, I am, as you might say, a optimization novice. From what I have read I do not think I have the computer power to apply dynamic programming to this system, so I am searching for a metaheuristic method such as Genetic Algorithm or PSO. However, much of the literature seems to apply these to continuous space or binary systems. I am confused as some of my variables have 3/4/5/6 possible choices. Would anybody have suggestions for how to solve my problem, or relevant literature applicable to my problem?
Also, since the model only outputs one number, would minimizing the cost be the fitness function? Many fitness functions I see in the literature seem complex, so I wonder if one can be this simple?
Apologies if these questions are stupid or unclear!
Thanks,
Grégory.
Technology news on Phys.org
I think you could use a genetic algorithm here. You make a solution vector of your 50 variables and then create a population of solutions by tweaking each one.
Then you need a fitness function to score each solution vector keeping the best and discarding the rest then mix and modify the solutions for the next generation and repeat the process and after a few iterations you'll hopefully have an approximately optimal solution.
https://en.wikipedia.org/wiki/Genetic_algorithm
Likes GregoryB82
If all your independent variables have a finite number of discrete values, then your problem is an integer programming problem. There are algorithms to solve integer programming problems.
Likes GregoryB82
FAQ: Optimization algorithm to apply to my system?
What is an optimization algorithm?
An optimization algorithm is a mathematical procedure used to find the best solution for a given problem. It involves finding the optimal values for a set of parameters or variables that will result in the most efficient or desirable outcome.
Why is it important to apply an optimization algorithm to my system?
Applying an optimization algorithm to your system can help improve its performance and efficiency. It can also help identify any areas of improvement and find the best solutions to maximize the system's potential.
How do I determine which optimization algorithm is best for my system?
The best optimization algorithm for your system will depend on various factors such as the type of problem, the available data, and the constraints. It is important to analyze your system's requirements and do research on different algorithms to determine the best fit.
What are some common optimization algorithms used in scientific research?
Some common optimization algorithms used in scientific research include gradient descent, genetic algorithms, simulated annealing, and particle swarm optimization. Each algorithm has its own strengths and weaknesses, and the choice depends on the specific problem at hand.
Can an optimization algorithm be applied to any type of system?
Yes, an optimization algorithm can be applied to any type of system, as long as there is a clear objective to optimize and parameters or variables that can be adjusted to achieve the desired outcome. However, the effectiveness of the algorithm may vary depending on the complexity and nature of the system.
