Optimization in Projectile Motion
In summary, the conversation discusses projectile motion and optimization, specifically how to find the launching angle that produces the largest range and longest flight time simultaneously. The method involves setting up an equation with a weight factor for each variable and differentiating it to find the optimal angle. The conversation also touches on the units and coefficients of the equation.
fog37
1,568
108
Dear Forum,
I am working on projectile motion and optimization these days. Projectile motion uses the kinematic equations of free fall for the vertical direction together with the equations of constant velocity in the horizontal direction.
Maximum Range: if an object is launched at a certain initial speed, the angle theta of maximum range depends on the initial and final height. For example, the angle is 45 degrees for same level launching and landing. The angle decreases as the launching elevation becomes larger than the landing elevation.
Maximum Flight Time: the launching angle will be 90 degrees in the case but the range will be zero. the object is going straight up and will stay in the air the longest in comparison to other situation.
Now, what if I wanted to find the launching angle that produces the largest range and the longest flight time simultaneously? What would I go about that? Is that possible? Do I need to construct a function having two variables, the range and the flight time, and assign some weight factor to each? The weight would give relative importance to range and flight time. I am not sure how to get started on this...
For the previous simple cases (maximize either time or distance), it was simply about setting the first derivatives equal to zero.
thanks,
fog37
You could get, say, 1 point for every metre of the range and, say, 2 points for every second it's in the air.
You would need to set up an equation for the variable "points" in terms of the variable "angle".
Thanks for your help, Perok.
I am not clear yet. Let's assume that the initial and final levels are the same, i.e. ##y_0=y_f=0##. The range has an equation ##R(\theta)## and the time of flight an equation ##T(\theta)##. To find the angle for the maximum range we set ##\frac {R(\theta)} {d\theta} =0## and to find the angle for the maximum time we set ##\frac {T(\theta)} {d\theta} =0## .
That said, could you help me understand how to use these two functions, ##R(\theta)## and ##T(\theta)## to create the new function, which we can call MAXI, that would give the angle that simultaneously maximizes both the range and the flight time? Is the function MAXI supposed to be the sum, the product of the two functions ##R(\theta)## and ##T(\theta)##, each assigned a weight? For example is the function be something like ##MAXI(\theta)##= ## a_1 R(\theta)## + ## b_2T(\theta)## or the product between the two terms?
It's up to you what you want to optimise, but maximising ## a R(\theta)## + ## bT(\theta)## is a good mathematical exercise with a clear solution.
I see some problems though. I am summing a function that units of distance to a function that has units of time. What can I do about the coefficients? Do they have units? What should their range be? Should they go from 0 to 1?
##a, b## are dimensionless, but the problem assumes the SI units. (a points for every metre and b points for every second). Change the units and you automatically change the scoring system. Personally, I'd solve the problem first and then work out what range ##a, b## should have.
Anyway, you should get started by differentiating wrt to ##\theta## the expression ## a R(\theta)## + ## bT(\theta)##.
The two functions are:
##R(\theta)= \frac {v^2 sin (2\theta)} {g}## and ##T(\theta)= \frac {2 v sin (\theta)} {g} ##
which we use to build the function ##MAXI (\theta)##:
$$MAXI(\theta)= a_1 \frac {v^2 sin (2\theta)} {g} +b_1 \frac {2 v sin (\theta)} {g}$$
We set the first derivative of MAXI equal to zero:
$$\frac {dMAXI(\theta)}{dt}= 2 a_1 \frac {v^2 cos( 2 \theta)} {g} +b_1 \frac {2 v cos (\theta)} {g} =0$$
$$ a_1 v ( 1- 2 sin^{2} (\theta) ) +b_1 cos (\theta) =0$$
$$ a_1 v - a_1 v 2 sin^{2} (\theta) = - b_1 cos (\theta) $$
$$\frac {dMAXI(\theta)}{dt}= 2 a_1 \frac {v^2 sin (\theta) cos(\theta)} {g} +b_1 \frac {2 v cos (\theta)} {g} =0$$
You need to check your derivative of ##\sin(2\theta)##
thanks. I fixed it. But i am stuck a little bit...
Why did you choose to simplify ##cos(2\theta)## in terms of ##sin(\theta)##? Isn't there a better idea?
mmm...missing that step:
d [sin(2x)]dx= 2 cos(2x)
cos(2x) can be expanded in terms of sin(x) or in terms of tan(x). Is that what you are referring to?
Sorry"
cos(2x) = 2 cos^2 (x) -1
That's it!
So $$ 2a_1 v cos^{2}(\theta) -a_1 v + b_1 cos(\theta)=0$$
Use the quadratic equation now to solve for ##cos(\theta)##?
Sounds good.
Ok, I applied the quadratic formula and got:
$$\theta= cos ^ {-1} [\frac {-b_1 \pm \sqrt {b_1^2+8 a_1^2 v}} {4 a_1}]$$
not a very friendly solution. Now, what about the values and meaning of the ##a_1## and ##b_1## weight coefficients? Also, how would we call a function like MAXI, that mixes both the distance and the time to find some compromise between them?
the initial velocity variable should not be part of the story...
The answer ashould be:
##\cos \theta = \frac{-b + \sqrt{b^2 + 8a^2v^2}}{4av}##
Then, with ##\alpha = \frac{b}{4av}## this becomes:
##\cos \theta = -\alpha + \sqrt{\alpha^2 + \frac{1}{2}}##
You can check this. For range only, you set ##b = 0##, hence ##\alpha = 0## and ##\cos \theta = \frac{1}{\sqrt{2}}##, hence ##\theta = \frac{\pi}{4}##.
And, for time only, you can take ##b >> a##, hence ##\cos \theta \approx 0## and ##\theta = \frac{\pi}{2}##
Related to Optimization in Projectile Motion
1. What is optimization in projectile motion?
Optimization in projectile motion refers to finding the best possible conditions or parameters to achieve a desired outcome, such as maximizing the range or height of a projectile.
2. Why is optimization important in projectile motion?
Optimization is important in projectile motion because it allows us to determine the optimal angle, velocity, and other factors that will result in the best performance of a projectile. This can be useful in various applications, such as designing efficient projectiles for military or sports purposes.
3. How is optimization achieved in projectile motion?
Optimization in projectile motion is achieved through mathematical calculations and simulations. By using equations and principles of physics, we can determine the optimal conditions for a projectile to achieve a desired outcome.
4. What are some real-world applications of optimization in projectile motion?
Optimization in projectile motion has various real-world applications, such as designing efficient artillery weapons, optimizing the trajectory of a golf ball, or determining the best angle for a ski jump.
5. What are some limitations of optimization in projectile motion?
Some limitations of optimization in projectile motion include the assumption of ideal conditions and neglecting external factors such as air resistance and wind. Additionally, optimization may not always be feasible or practical in certain situations due to various constraints.
  • Classical Physics
