Optimization Problem: Max and Min Values of e^(x+2y) with x^2+y^2=5 Condition
In summary, the maximum value and minimum value of the function:z=e^{x+2y}under the condition:x^{2}+y^{2}=5equals to:a. 0b. 1c. e^5d. ee. e^-1
Yankel
395
Hello all,
I am trying to solve this problem, and I don't know which way to go...
The product of the maximum value and minimum value of the function:
\[z=e^{x+2y}\]
\[x^{2}+y^{2}=5\]
Equals to:
a. 0
b. 1
c. e^5
d. e
e. e^-1
I have a feeling that this problem involves the Lagrange multipliers, but I am really not sure, and doesn't know how it's related to it (in case I am correct).
Thank you
Yes, Lagrange multipliers is a good way to go here. Your objective function is:
\(\displaystyle f(x,y)=e^{x+2y}\)
subject to the constraint:
\(\displaystyle g(x,y)=x^2+y^2-5=0\)
Can you form the system of equations that results from the partials?
Hi!
Let's indeed try with the Lagrange multipliers.
We define:
$$\Lambda = e^{x+2y} - \lambda(x^{2}+y^{2}-5)$$
And we set each of the partial derivatives of $\Lambda$ to zero.
Which system do you get?
I did what you suggested and got these 3 equations, technically (algebraically), how do I solve such a thing ?\[e^{x+2y}+2\lambda x=0\]
\[2e^{x+2y}+2\lambda y=0\]
\[x^{2}+y^{2}-5=0\]Thank you
You have a sign error in front of the terms having $\lambda$ as a factor.
The way I was taught, which is equivalent to I like Serena's suggestion, is to use:
\(\displaystyle f_x(x,y)=\lambda g_x(x,y)\)
\(\displaystyle f_y(x,y)=\lambda g_y(x,y)\)
Now this should give you an implication regarding the relationship between the two variables at the critical point. Solve both for $\lambda$ and then equate the results and simplify. What do you find?
I can't find any error. The Lagrangian function is:
\[L(x,y,\lambda )=e^{x+2y}+\lambda (x^{2}+y^{2}-5)\]
And I need to find it's derivatives by x, y and lambda, can't find my error there.
Well, you are correct in that within the Lagrangian function, the term with $\lambda$ may be either added or subtracted. I prefer subtraction as given by I like Serena. Either way, you should find the same implication though.
I am getting confused here. I learned that I need to add, not subtract. I believe you that you can do both.
But assume that adding is what needed, do we agree that my derivatives are correct ?
(they must be, checked with Maple)
How do I solve this system then ? :confused:
Yes, my apologies...what you have done so far is correct. So, let's look at your first two equations:
\(\displaystyle e^{x+2y}+2\lambda x=0\)
\(\displaystyle 2e^{x+2y}+2\lambda y=0\)
Now, solve both for $\lambda$ and then equate the results and simplify. What do you find?
No worries :)
What I got was:
\[\frac{1}{2x}=\frac{1}{y}\]
From which I got:
\[y=2x\]
I put it in the 3rd equation and got:
\[x=\pm 1\rightarrow y=\pm 2\]
Leading me to 2 critical points:
\[f(1,2)=e^{5}\]
\[f(-1,-2)=e^{-5}\]Are my calculations correct ?
Are these the only points, how do I know that they are absolute min/max ?
Yes, your calculations are correct. Does the constraint lead to any other critical points with the implication you found? To verify the nature of the critical points you found, you could use the constraint, solving it for one of the variables, and then substitute into the objective function to get a function in one variable, and then use the first or second derivative test.
Yep. All correct!
Since you have a continuous function defined on a circle, there can be no boundary extremum.
That leaves only local and absolute minima and maxima.
Since there is only one minimum and one maximum, both of them have to be absolute.
Thanks guys,
great help !
(Yes)
FAQ: Optimization Problem: Max and Min Values of e^(x+2y) with x^2+y^2=5 Condition
What is an optimization problem?
An optimization problem is a mathematical problem that involves finding the best possible solution to a given situation, while taking into account any constraints or limitations.
What are the different types of optimization problems?
There are several types of optimization problems, including linear programming, nonlinear programming, integer programming, and dynamic programming. Each type has its own specific characteristics and solution methods.
How is an optimization problem solved?
The solution to an optimization problem involves finding the values of the variables that will result in the best possible outcome, while also satisfying any constraints. This can be done using various mathematical techniques, such as gradient descent, simplex method, or genetic algorithms.
What are some real-life examples of optimization problems?
Optimization problems can be found in various fields, such as finance, engineering, and logistics. Some examples include optimizing investment portfolios, designing efficient transportation routes, and maximizing production in a manufacturing plant.
What are the main challenges in solving optimization problems?
One of the main challenges in solving optimization problems is the complexity and size of the problem, which can make it difficult to find an optimal solution. Additionally, formulating the problem correctly and selecting the most appropriate solution method can also be challenging.
