B Optimizing permutations of hero traits in a computer game
The discussion focuses on optimizing the matching of hero traits with banner cards in a computer game to maximize ability outcomes. The user has developed code to iterate through permutations of traits and is exploring further optimization techniques. The optimization goal is to maximize the number of ability matches between heroes and banner cards, raising questions about the constraints of leveling abilities. It is suggested that this problem resembles an n-dimensional discrete optimization challenge, with potential solutions involving continuous linear optimization methods. The conversation emphasizes the need for a rigorous setup to apply appropriate algorithms effectively.
liquidFuzz
TL;DR Summary
Trying to optimize perk cards in a computer game
I have a game where heroes have a set of traits, or abilities. The level of the abilities are raised in two ways, by banner cards and/or by leveling the hero. The Banner cards and heroes don't match perfectly, rather a banner card can match 1 or 2 (sometimes 3) abilities of the heroes abilities. Being... me, i wrote some lines of code that iterated trough the possible permutations to find the optimal permutation in terms of maximizing the ability outcome for the heroes.
Now I wonder if there is a way of using optimization to solve similar problems.
The setup is as follows,
Hero 1 : A, D, F, R
Hero 2 : B,D,E,S
Hero 3 : A,E,R,T
Etc..
Banner Card 1 : A,B,C,D
Banner card 2 : A,F,R,E
etc...
Edit, I'm interested in optimization in terms of maximum number ability matching between heroes and banner cards.
Mathematics news on Phys.org
I think I still don't understand exactly what your optimization goal is, just to try to use as many cards as possible? Can you only level up each ability once or something?
This sounds like an ##n-##dimensional discrete optimization problem. I'm sure there are algorithms for it once you set up your problem rigorously. I assume you have to find a closest lattice point to an edge of an irregular polyhedron. One possibility that comes to mind is to solve the corresponding continuous linear optimization problem and determine the nearest lattice point from the solution.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
