MHB Optimizing the Area of a Norman Window - 25 Feet Perimeter
  • Thread starter Thread starter MarkFL
    Area Window
The discussion focuses on optimizing the area of a Norman window, which consists of a semicircle above a rectangle, given a perimeter of 25 feet. The area is calculated using the objective function f(h,r) = 2rh + (1/2)πr², with the constraint g(h,r) = 2r + 2h + πr - P = 0. By applying Lagrange multipliers, it is determined that the height h equals the radius r, leading to the maximum area formula f_max = P² / (2(4 + π)). Substituting the perimeter value, the maximum area is found to be 625 / (2(4 + π)) square feet. This approach provides a mathematical solution for maximizing the area of the Norman window under the given constraints.
MarkFL
MHB
Here is the question:
A Norman window has the shape of a semicircle atop a rectangle so that the diameter of the semicircle is equal?
A Norman window has the shape of a semicircle atop a rectangle so that the diameter of the semicircle is equal to the width of the rectangle. What is the area of the largest possible Norman window with a perimeter of 25 feet?
Here is a link to the problem:
A Norman window has the shape of a semicircle atop a rectangle so that the diameter of the semicircle is equal? - Yahoo! Answers
I have posted a link there to this topic so that the OP can find my response.
Mathematics news on Phys.org
Hello Christopher,
One approach is to use Lagrange multipliers. We have the objective function:
$\displaystyle f(h,r)=2rh+\frac{1}{2}\pi r^2$
subject to the constraint:
$\displaystyle g(h,r)=2r+2h+\pi r-P=0$
giving the system:
$\displaystyle r=\lambda$
$\displaystyle 2h+\pi r=\lambda (2+\pi)$
which implies:
$\displaystyle h=r$
Substituting into the constraint, we then find:
$\displaystyle g(r)=(4+\pi)r=P$
$\displaystyle h=r=\frac{P}{4+\pi}$
And finally, substituting into the objective function, we find:
$\displaystyle f_{\text{max}}=\frac{P^2}{2(4+\pi)}$
Now, plug in the given perimeter for P to find the maximum area of the window:
$\displaystyle f_{\text{max}}=\frac{(25\text{ ft})^2}{2(4+\pi)}=\frac{625}{2(4+\pi)}\,\text{ft}^2$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
