Optimum dimension for a cylindrical vessel subject to external pressur
In summary, the optimum dimension for a cylindrical vessel subject to external pressure depends on factors such as material properties, type of pressure, and intended use. Material properties play a crucial role in determining the maximum amount of stress the vessel can withstand, and different types of pressure may require different design considerations. The intended use of the vessel also affects the optimum dimension and there are various formulas and equations that can be used to calculate it, but it is best to consult with a qualified engineer for an accurate calculation.
rollingstein
While doing some ASME code calculations for a pressure vessel subject to external pressure I was wondering what'd be the optimum L/D ratio for a vessel that is subject to buckling under external pressure. For a given volume & Pressure.
Could a general L/D ratio be derived or would it change with scale & imposed pressure. It's hard to use conventional optimization since a lot of the buckling design seems a mix of tables, formulae & charts.
In general to prevent buckling larger wall thickness helps but on the other hand both small L & D are good. Wondering if L or D dominates. i.e. a long vessel or a shorter stouter vessel.
Any idea? Of course, this is assuming stiffing rings aren't an option.
The general L/D ratio to prevent buckling under external pressure will vary depending on the scale and imposed pressure. Generally, smaller L and D ratios are better for preventing buckling, as a shorter, stouter vessel can be more resistant to buckling due to its shorter length. However, if the vessel is large enough, a longer, thinner walled vessel may be preferred. Additionally, stiffening rings can also be used to help prevent buckling. Ultimately, the best L/D ratio will depend on the specific details of the pressure vessel, and should be determined through an appropriate design calculation.
Related to Optimum dimension for a cylindrical vessel subject to external pressur
1. What is the optimum dimension for a cylindrical vessel subject to external pressure?
The optimum dimension for a cylindrical vessel subject to external pressure depends on several factors such as the material properties, the type of pressure, and the intended use of the vessel. It is important to consult with a qualified engineer to determine the specific dimensions for your specific application.
2. How does the material properties affect the optimum dimension of a cylindrical vessel?
The material properties of the vessel, such as yield strength and elastic modulus, play a crucial role in determining the optimum dimension. These properties dictate the maximum amount of stress the vessel can withstand before it deforms or fails under external pressure. Therefore, the material properties must be carefully considered when determining the optimum dimension of a cylindrical vessel.
3. What types of external pressure can a cylindrical vessel be subjected to?
A cylindrical vessel can be subjected to various types of external pressure, such as hydrostatic pressure, pneumatic pressure, and mechanical pressure. Each type of pressure requires different design considerations, and the optimum dimension of the vessel may vary depending on the type of pressure it will be subjected to.
4. How does the intended use of the vessel affect the optimum dimension?
The intended use of the vessel is a crucial factor in determining the optimum dimension. For example, a vessel used for storage may have different dimension requirements compared to a vessel used for transportation. The intended use also affects the type of pressure the vessel will be subjected to, which in turn affects the optimum dimension.
5. Can the optimum dimension be calculated using a formula?
There are various formulas and equations used to calculate the optimum dimension for a cylindrical vessel subject to external pressure, such as the Barlow's formula and the Lame's equation. However, these formulas may not be applicable to all types of vessels and may require additional considerations. It is best to consult with a qualified engineer for an accurate calculation of the optimum dimension for your specific vessel.
  • Mechanical Engineering
11K
