Brief-Wishbone
- 12
- TL;DR Summary
- Orangescrum not installing in Centos 7?
The official tutorial for automated installation of centos 7 doesn't work. So, I had to refer to online tutorials.
I installed apache 2.4,php 7.2, mysql 5.7.
Then I downloaded .zip source code from here
https://github.com/Orangescrum/orangescrum.
Then, I setup some permissions and ownership as per documentation.
Then I setup a virtual host orangescrum.conf in /etc/httpd/conf.d.
Then I created mysql database
Then I imported the database.
Then I updated orangescrum credentials inside `/var/www/html/orangescrum-1.6.1/app/Config/database.php`
But it's not working and I'm getting the below output when I enter my ip address in browser.How do I fix this issue? Is there a way?
http://i.stack.imgur.com/7FQg1.png
Code:
$ sudo mv ~/orangescrum-main /var/www/html && sudo chown root:root -R /var/www/html
$ sudo chmod -R 0777 /var/www/html/orangescrum-main/{app/Config,app/tmp,app/webroot}
Code:
<VirtualHost *:80>
ServerName orangescrum.example.com
DocumentRoot /var/www/html/orangescrum-main
<Directory /var/www/html/orangescrum-main>
Options Indexes FollowSymLinks MultiViews
AllowOverride All
Order allow,deny
allow from all
</Directory>
</VirtualHost>
Code:
CREATE DATABASE orangescrum;
CREATE USER 'orangescrumuser'@'localhost' IDENTIFIED BY 'yourpassword';
GRANT ALL PRIVILEGES ON orangescrum.* TO 'orangescrumuser'@'localhost' IDENTIFIED BY 'yourpassword' WITH GRANT OPTION;
FLUSH PRIVILEGES;
EXIT;
Code:
$ mysql -u root -p orangescrum < /var/www/html/orangescrum-main/database.sql
Code:
'login' => 'orangescrumuser',
'password' => 'yourpassword',
'database' => 'orangescrum',
