Orbit of a star in a sherical potential
Your Name]In summary, we discussed the problem of finding r_min and r_max for a star in a spherical potential with given values of V, L, and E. We also talked about how to integrate the orbit numerically using a for loop in C/C++.
florian
A star is at radius r = 10kpc with v_t=100km/s and v_r=50km/s. The spherical potential is
\phi = V^2ln(r) with V=200km/s
1. what is r_min r_max?
2. Integrate the orbit numerically
at r_min and r_max v_r is 0 therefore I can write
E_min = E_max = L^2/(2r^2) + V^2ln(r) = E
but how can I solve this to r = ??
I thought actually I can use angular momentum conservation and say L^2/(2r_min^2) = L^2/(2r^2) which does not really work out? But I think I have to include angular momentum conservation somehow...
2.
I tried numerical integration with the following equation
dr/dt = sqrt(2*(E-\phi) - L^2/(2r^2))
but the value below the root is negative ?
I also found
(dr/r^2d\theta)^2 = 2E/L^2 - 1/r^2 + 2V^2ln(r)/L^2
but here I have a very similar problem.
So my question concerning the numerical integration is actually which equation should I use and how to integrate it. I would like to do the integration in a C/C++ for loop by myself instead of using mathematica or other tools... is that possible?
thanks and best regards
florian
Dear Florian,
Thank you for your post. Let's address your questions one by one.
1. To find r_min and r_max, we can use the fact that the total energy (E) of the star is conserved. This means that at any point along its orbit, the total energy will be the same. We can write this as:
E = L^2/(2r^2) + V^2ln(r)
Since we know the values of V, L, and E, we can rearrange this equation to solve for r:
r_min = e^(2E/V^2) and r_max = e^((2E+L^2)/V^2)
2. To integrate the orbit numerically, we can use the equation you mentioned:
We can plug in the values of E, L, and V, and also use the values of r_min and r_max that we found in the previous step. Then, we can use a for loop in C/C++ to iterate through a range of time steps and calculate the corresponding values of r. This will give us a set of points that we can plot to visualize the orbit of the star.
I hope this helps. Let me know if you have any further questions.
I would like to provide the following response to the content:
Firstly, based on the given information, we can calculate the minimum and maximum radii as follows:
r_min = L^2/(2E - 2V^2ln(r))^(1/2)
r_max = L^2/(2E)^(1/2)
Where E is the total energy of the star, L is its angular momentum, and V is the velocity at the given radius.
To integrate the orbit numerically, we can use the equation:
dr/dt = (2(E - \phi) - L^2/(2r^2))^(1/2)
Where \phi is the potential function given in the homework statement. This equation can be solved using numerical methods such as the Euler method or the Runge-Kutta method. It is important to note that the value below the square root should not be negative, so make sure to check your calculations and inputs.
In terms of using a C/C++ for loop for the integration, it is certainly possible. However, it would require a good understanding of numerical integration methods and programming skills. Alternatively, you could use existing software packages or online tools for numerical integration.
I hope this helps in your understanding and approach to solving the homework problem. Best of luck!
FAQ: Orbit of a star in a sherical potential
What is the "spherical potential" in relation to the orbit of a star?
The spherical potential refers to the gravitational potential created by a spherically symmetric distribution of mass. In the context of a star's orbit, it is the potential that influences the star's motion around a central mass, which can be a galaxy, star cluster, or black hole.
How does the mass of the star affect its orbit in a spherical potential?
The mass of the star does not affect its orbit in a spherical potential. Instead, it is the mass of the central object and the distribution of mass around it that determines the shape and properties of the star's orbit.
What factors influence the shape of a star's orbit in a spherical potential?
The shape of a star's orbit in a spherical potential is primarily influenced by the mass and distribution of mass of the central object, as well as the star's initial velocity and distance from the central object. Other factors, such as the presence of other nearby objects, can also play a role.
How is the orbit of a star in a spherical potential calculated?
The orbit of a star in a spherical potential is calculated using mathematical equations, such as Kepler's laws of planetary motion and the equations of motion in a gravitational field. These equations take into account the mass and distribution of mass of the central object, as well as the star's initial conditions, to determine the shape and properties of the orbit.
Can the orbit of a star in a spherical potential change over time?
Yes, the orbit of a star in a spherical potential can change over time due to various factors, such as the influence of other nearby objects or the gradual change in the mass and distribution of mass of the central object. However, these changes are usually very small and occur over long periods of time.
