Why Does the Orbit Space of a Covering Map Not Necessarily Equal the Base Space?
In summary: Aut_q(E)##. In general, the orbit space will be a "coarser" space than the quotient space, meaning that there will be more points in the quotient space than in the orbit space. Hope this helps!In summary, we have discussed the difference between the quotient space and the orbit space of a covering map ##q##. While the quotient space ##E'## is formed by identifying all points in ##E## that are mapped to the same point in ##X## under ##q##, the orbit space is formed by identifying all points in ##E## that are mapped to the same point in ##X## under some automorphism in ##Aut
PsychonautQQ
784
Suppose ##q: E-->X## is a covering map (not necessarily normal). Let ##E' = E/ Aut_{q}(E)## be the orbit space, and let ##\pi: E-->E'## be the quotient map. Then there is a covering map ##q': E' --->X## such that ##q' * \pi = q## where ##*## is composition of functions.
I am confused why ##E'## doesn't equal ##X##. Isn't ##E'## a space formed by the exact same identifications that ##E## makes on ##X## under the map ##q##? Why would these spaces be different at all then? A part of me believes that these spaces can only be equal if ##q## where a normal map, because the action of ##Aut_{q}(E)## is transitive and sooo yeah I need some help filling in my lack of understanding on this.. Thanks!
I suspect (but have no proof) that, if ##q## is normal, ##E'## will at least have the same cardinality as ##X##, and maybe the same topology too. But it will be a different set.
Consider the usual example of ##q:E=\mathbb R\to X=S^1## given by ##q(x)=e^{2\pi i x}##. Then an element of ##X## is a single number in the complex plane, whereas an element ##x## of ##E'## is a set of the form
$$\{\alpha_x+n\ :\ n\in\mathbb Z\}$$
where ##\alpha_x\in[0,1)## uniquely characterises ##x##.
In that example the covering map is normal, and the cardinality and topology of ##E'## are the same as those of ##S^1##.
But where the covering map is not normal, the set ##Aut(q)## of deck transformations is not transitive, so there may be more than one orbit per fibre. That suggests to me that the cardinality of ##Aut(q)## may be greater, and hence the cardinality of ##E'## may be greater than that of ##X##. Differences in topology may also follow.
Perhaps the reason the text said 'not necessarily normal' was because it's in those non-normal cases that ##E'## becomes different from ##X## in more than just set composition, and things become more interesting.
This is all a bit hand-wavy, but hopefully it gives you an idea of the potential differences.
Likes PsychonautQQ
Hi there,
I can see where your confusion is coming from. The key here is to understand the difference between the quotient space and the orbit space. The quotient space ##E'## is formed by identifying all points in ##E## that are mapped to the same point in ##X## under the covering map ##q##. So, in a sense, ##E'## is a "collapsed" version of ##E## where all the points that are "equivalent" under the map ##q## are identified as one point.
On the other hand, the orbit space is formed by identifying all points in ##E## that are mapped to the same point in ##X## under the action of the automorphism group ##Aut_q(E)##. So, in this case, the points in ##E## are not necessarily mapped to the same point in ##X## under the covering map ##q##, but they are mapped to the same point under some automorphism in ##Aut_q(E)##.
To see the difference, let's consider an example. Let ##E = \mathbb{R}## be the real line and let ##X = S^1## be the unit circle. Let ##q: \mathbb{R} \to S^1## be the covering map given by ##q(x) = e^{2\pi ix}##. Now, let's consider the point ##p = 1## in ##X##. Under the map ##q##, there are infinitely many points in ##\mathbb{R}## that are mapped to ##p##, namely, all the integers. So, in the quotient space ##E'##, all these points will be identified as one point, say ##[p]##. On the other hand, the orbit space of ##p## will consist of all the points in ##\mathbb{R}## that are mapped to ##p## under some automorphism in ##Aut_q(E)##. In this case, since ##Aut_q(\mathbb{R}) = \mathbb{Z}##, the orbit space of ##p## will just be the set of integers, which is different from the quotient space ##E'##.
So, to answer your question, ##E'## is not necessarily equal to ##X## because the points in ##E'## are identified based on the covering map ##q##, while the points in
FAQ: Why Does the Orbit Space of a Covering Map Not Necessarily Equal the Base Space?
What is an orbit space of a covering map?
The orbit space of a covering map is a mathematical concept that describes the space obtained by identifying all points of a covering space that lie in the same orbit, or have the same pre-image, under the covering map. It is a way to simplify a topological space by collapsing multiple points into a single point.
How is the orbit space related to the covering map?
The orbit space is closely related to the covering map as it is constructed from the pre-images of the covering map. The covering map determines the equivalence relation that is used to identify points in the covering space, which results in the orbit space.
What is the significance of the orbit space in topology?
The orbit space is significant in topology as it allows for the study of spaces with complicated covering maps in a simpler and more manageable way. It also allows for the comparison and classification of different spaces based on their orbit spaces.
How is the orbit space calculated?
The orbit space is calculated by first determining the equivalence relation induced by the covering map. This is done by identifying all points in the covering space that have the same image under the covering map. The orbit space is then constructed by collapsing each equivalence class into a single point.
What are some examples of orbit spaces?
Some examples of orbit spaces include the real projective space, which is the orbit space of the covering map from the unit sphere to the real projective plane, and the torus, which is the orbit space of the covering map from the plane to the torus. Other examples include the Möbius strip, the Klein bottle, and the surface of a sphere.
