Undergrad Orbital Period In General Relativity
The discussion focuses on determining the orbital period in General Relativity using the Schwarzschild metric. For circular orbits, the orbital period can be derived from Kepler's Third Law by substituting the Schwarzschild radius as the orbital radius. The areal radius is defined as r = √(A / 4π), where A is the surface area of the 2-sphere around the central mass. Participants clarify the distinction between the Schwarzschild radius and the physical distance from the central mass. Understanding these concepts is crucial for accurately calculating orbital periods in a relativistic context.
dsaun777
What is the orbital period in General Relativity using the Schwarzschild metric? In classical mechanics, it is something like
T=2pi(GnM/a3). Where a is the semi-major axis, this is for a small body orbiting a larger one. I think I have an idea but I am not 100% sure. I am interested in an outside observer far away viewing a small particle m in orbit of some mass M.
For a circular orbit, it's the Kepler's Third Law expression with the Schwarzschild ##r## plugged in as the orbital radius. Note that this is the case even though ##r## is not the same as the physical distance from the center of mass of the central body.
Likes cianfa72 and PeroK
Yeah, its the areal radius found by integrating over the radial coordinate from r to rs dr using the metric components related to radial coordinates.
Yes, but...
...no, that's not what the areal radius is. The areal radius is ##r = \sqrt{A / 4 \pi}##, where ##A## is the surface area of the 2-sphere labeled by ##r## that is centered on the central mass.
MOVING CLOCKS In this section, we show that clocks moving at high speeds run slowly. We construct a clock, called a light clock, using a stick of proper lenght ##L_0##, and two mirrors. The two mirrors face each other, and a pulse of light bounces back and forth betweem them. Each time the light pulse strikes one of the mirrors, say the lower mirror, the clock is said to tick. Between successive ticks the light pulse travels a distance ##2L_0## in the proper reference of frame of the clock...
  • · Replies 62 ·
  • · Replies 42 ·
  • · Replies 43 ·
  • · Replies 21 ·
  • · Replies 30 ·
