Orbital period of satellite about a nonrotating body
A satellite orbits a nonrotating planet at an altitude of 1000 km with an orbital speed of 5.3 km/s, while the escape velocity is 11.3 km/s. The user initially calculated the orbital period but arrived at 25 minutes, which contradicted the answer key's 35 minutes. After reviewing the calculations, it was discovered that a multiplication error was made when solving for R, leading to the incorrect period. Correcting this error provided the accurate value of R, resulting in the correct orbital period of 35 minutes. The discussion highlights the importance of careful algebraic manipulation in orbital mechanics calculations.
mollybethe
A satellite is in circular orbit at an altitude of 1000 km above the surface of a nonrotating planet with n orbital speed of 5.3 km/s. The escape velocity for the planet is 11.3 km/s. In this situation the orbital period of the satellite, in minutes, is...?
v(orbital)=√(GM/R+r)
v(escape)=√(2GM/R)
T=2∏R/v
Of course I converted everything to SI units first. So v(orbital)=5300m/s and v(escape)=11300m/s and r=10^6m. What I did is solved the two equations for velocity for M and then plugged in what I had. I found that R is 282,028m which seems small, but then using that I find that and the second equation I find the time period in minutes to be 25. According to my answer key the answer should be 35. I don't know if I am wrong or the answer key is wrong. What I don't know how to do is allow for any effect that the fact that the planet is non-rotating may have. Help...am I making a silly mistake? It is after midnight and I have been at this a while.
Your value for R is not correct. Assuming that you mean GM/(R+r) in the first equation, your equations are correct and I guess something must have slipped solving those equations for R. (Hint: one way is to find GM from the second equation and insert this into the first equation and solve for R).
I got it! I left out a times two...I was trying to be smooth with my algebra to make my calculations easier and left out a x 2. I got it. R=784624 so R+r=1.78562x10^6. Using the third equation that gives me 35 minutes. Thank you, at least I knew I was working it out correctly!
  • · Replies 16 ·
