Orbital period of two moons in the same orbit
In summary: Since centripetal accelration is : v^2 / R. Where v = w*R. we get ((w*R)^2)/R . and that simplified is w*R^2. and angular velocity = (pi*2*R)/T since it is distance divided by time. putting all of that into one equatin and solving...In summary, the moons of mass 2 maintain opposite positions in a circular orbit around a planet of mass M. T2, the square of the orbital period, is given by: (4*pi2*R3)/(G*M).
mr_trollface_-
1. Homework Statement
Two identical moons of mass m maintain opposite positions in the same circular orbit of radius R around a planet of mass M. Find T2 the square of the orbital period.
2. Homework Equations
T2=(4*pi2*R3)/ ( G*M )
3. The Attempt at a Solution
Hi there, well so I tried just inputting that equation for the square of the orbital period as the anwser .And it marked me wrong.my logic behind that was well if one moon orbits with that period.And the two moons are opposite rather each other then they both are going top have the same orbital period.So I guess it would be the right anwser. But as I've said it's not.So I'm puzzled at what's wrong. Did I somehow miss read the question.or am I thinking of a wrong orbital period or something.could someone explain why my anwser is incorrect.And guide me along the right path , so I could improve my understanding of physics. Any help will be greatly appreciated. :)
P.S. I don't know if it will work but here's the image I got with the problem.
Hello face, and welcome to PF.
I wonder where you picked up the relevant formula you quote. I don't see m appearing in there (or 2m in this particular case). Perhaps you want to start your search with a few more fundamental equations.
You cannot neglect the gravitational force from the other moon. ehild
The formula is Kepler's 3rd law. And the big M there is the mass of the planet.
ehild said:
You cannot neglect the gravitational force from the other planet.
ehild
I did think of that, but then dissmissed because I thought that Newton's third law would cause them to cancel out.
So in this case, the gravitational force exerted on one of the moons by the other is: (G*M*m)/(2*R). right? . But I have no idea how it will contribute to the period of the moon
Yes, but Kepler's third law is only valid in a system where all masses except the central body are negligible. Since we are given the masses of the moons, this would not necessarily be the case (also, otherwise there really is no point in doing the problem with two moons).
Do you know of some kinematical relations that have to hold true in a circular orbit?
Likes 1 person
There is a third party, the other moon. You cannot apply Kepler's third law if the masses of the moons are comparable to the mass of the planet. Considering one of the moons, it is attracted both by the planet and the other moon. What is the total force it experiences? That is the centripetal force keeping it on circular orbit.
ehild
The forces of the moons on the planet cancel out. However, the forces of the moons on each other contribute to their centripetal acceleration ...
Mhmm, So I calculated the centripetal acceleration to be: (G*M)/(R^2) + ( G*m )/((2*R)^2). am I right? and also by which equation could I relate the centripetal acceleration to the period ?
p.s. sorry if some of what I'm writing doesn't make much sense , It's really late at night and I'm really tired. :)
It is correct, and how is the centripetal acceleration acprelated to radius R and angular velocity ω?
ehild
Likes 1 person
since centripetal accelration is : v^2 / R. Where v = w*R. we get ((w*R)^2)/R . and that simplified is w*R^2. and angular velocity = (pi*2*R)/T since it is distance divided by time. putting all of that into one equatin and solving for T we get : T= (4*pi*R^(3/2))/( sqrt( G*( 4*M + n ) ) ). Then to get the anwser we square it .which we finally arrive at :( 16*pi^2*R^3)/( G*(4*M + m) ) . And WOOOAHOOOOAHAHHAHAOOOO! it's right . I've made a mistake in the final working above but wooooo I got it right :) . Thank you so much to all of you :)
since centripetal accelration is : v^2 / R. Where v = w*R. we get ((w*R)^2)/R . and that simplified is [STRIKE]w*R^2[/STRIKE].
It is w^2R.
Why did you take the square root and square again? But the result is correct at the end.
ehild
Related to Orbital period of two moons in the same orbit
1. What is the orbital period of two moons in the same orbit?
The orbital period of two moons in the same orbit is the amount of time it takes for both moons to complete one full revolution around their shared center of mass.
2. How is the orbital period of two moons in the same orbit calculated?
The orbital period can be calculated using Kepler's third law, which states that the square of the orbital period is proportional to the cube of the semi-major axis of the orbit.
3. Can the orbital period of two moons in the same orbit be the same?
Yes, it is possible for two moons in the same orbit to have the same orbital period. This occurs when the moons have the same distance from their shared center of mass and are moving at the same speed.
4. Can the orbital period of two moons in the same orbit change?
Yes, the orbital period of two moons in the same orbit can change over time due to factors such as gravitational interactions with other objects or changes in the shape or size of the orbit.
5. How does the orbital period of two moons in the same orbit affect their gravitational pull on each other?
The orbital period of two moons in the same orbit is directly related to their gravitational pull on each other. The longer the orbital period, the weaker the gravitational pull between the moons, and vice versa.
