Orbital transfers and escape velocity: relationship
In summary: I'm wondering if the same principle might not also apply to other dimensions or even universes. "In summary, if an object is traveling between two massive bodies with the same mass as the sun, it would have to maintain a level of velocity that matched to some extent that of the two bodies' orbital speed. If one of those two bodies is alone, i.e. without orbiting the other body, it would have the same escape velocity as the sun since it has the same mass, right? However, if the two sun-mass bodies are orbiting each other, an object cannot ascend much beyond Earth's orbit without falling into orbit around the second body, correct? So the escape velocity of the first body with the sun's mass was reduced
brainstorm
568
I have been told that there is no interaction between the gravitational fields of the sun and any planet, but the issue continues to stimulate my curiosity.
If the Earth orbits the sun at 30km/s, how could anything achieve an orbital speed around Earth at greater than 30km/s without transferring into solar orbit?
If it is the case that solar gravity influences escape velocity, then wouldn't something orbiting one of the distant gas giants be able to orbit those planets at a much more distant point at a lower velocity without escaping into solar orbit?
In that case, wouldn't a planet's escape velocity depend on its orbital velocity relative to the sun or whatever it was orbiting?
Astronomy news on Phys.org
"I have been told that there is no interaction between the gravitational fields of the sun and any planet"
Could you please explain what you mean by this
Ok, maybe this example is simple enough to clarify what I'm talking/asking about:
Imagine there are two massive bodies with the mass of the sun orbiting each other at close range. Let's say they have the same distance as Jupiter does from the sun. At such close proximity, these two bodies would have to orbit each other at a very high velocity to maintain constant distance from each other, correct?
As such, any object that came near the system of the two bodies would have to maintain a level of velocity that matched to some extent that of the two bodies' orbital speed. If the object was going much slower, it would fall into one of the two bodies and if it was much faster it would slingshot by them and continue on.
Now, if one of those two bodies would be alone, i.e. without orbiting the other body, it would have the same escape velocity as the sun since it has the same mass, right? That means that if an object was traveling at Earth's orbit, it would be moving at 30km/s, like Earth, yet still be far from reaching escape velocity of the solar system.
Yet, if the two sun-mass bodies are orbiting each other, an object cannot ascend much beyond Earth's orbit without falling into orbit around the second body, correct? So the escape velocity of the first body with the sun's mass was reduced by the fact that another gravitational field overtook the first one prior to the object reaching "escape velocity."
So, what I think (but don't sufficiently understand, which is why I'm asking about it) is that gravitational fields interact to limit how much velocity a satellite within one gravitational field can achieve before transferring orbit into another gravitational field. If that is the case, then I think "escape velocity" is an inadequate concept in that it treats each gravitational field as if it exists independently of others. In fact, I think the entire universe is composed of contingent gravitational fields, however weak they may become at their shared boundaries.
Now, if you thought critically about the idea of distant gravitational fields having a shared boundary, then hopefully you realized that one object's gravity doesn't necessarily give up just because another object's gravitation overshadows it. Take the effect of the moon on the tides. The moon's gravitation does not stop at the point Earth's gravitation becomes stronger. So, theoretically, any object traveling anywhere between the Earth and the moon is interacting with both gravitational fields simultaneously, right?
What interest me is how such gravitational field interactions may affect space/time dilation and the behavior of matter and energy generally.
Related to Orbital transfers and escape velocity: relationship
1. What is an orbital transfer?
An orbital transfer is the process of changing the orbit of a spacecraft or satellite around a celestial body. It involves using the spacecraft's propulsion system to transfer from one orbit to another.
2. How is orbital transfer related to escape velocity?
The relationship between orbital transfer and escape velocity lies in the amount of energy required for each. Orbital transfer requires less energy than escaping a celestial body's gravitational pull completely, which is represented by the escape velocity.
3. What factors affect the relationship between orbital transfer and escape velocity?
The main factors that affect this relationship are the mass and size of the celestial body, as well as the distance from the body. The larger the body and the closer the distance, the higher the escape velocity and the more energy needed for an orbital transfer.
4. Can an orbital transfer be used to reach escape velocity?
Yes, an orbital transfer can be used to reach escape velocity if the spacecraft's propulsion system is powerful enough. The spacecraft would need to accelerate to a speed greater than the escape velocity in order to break free from the celestial body's gravitational pull.
5. What is the significance of understanding the relationship between orbital transfer and escape velocity?
Understanding this relationship is crucial for successful space missions. It allows scientists and engineers to calculate the amount of energy and fuel needed for orbital transfers and escaping from celestial bodies, which is essential for efficient and safe space travel.
  • Astronomy and Astrophysics
  • Classical Physics
