Orbital velocity and rotational velocity
In summary: They are measuring the orbital speed of the stars at a given distance from the galactic center. So it would be more accurate to say "the rotational velocity of a galaxy."
mun
Hi
Is "orbital velocity" supposed to be the same as "rotational velocity"? it seems that a "rotation curve" is supposed to plot the rotational velocity of a star, but then some articles e.g. http://en.wikipedia.org/wiki/Galaxy_rotation_problem claim "orbital speed" is plotted.
The equation for rotational velocity seems to be in the shape of V sin(i) but the equation for orbital velocity doesn't depend on sin.
Any help will be much appreciated.
Thanks!
In this case the "orbital velocity" and "rotational velocity" refer to different objects. Galactic rotation refers to rotation of a galaxy, which is in turn composed of many stars. It is the orbital motion of these stars around the center of mass that corresponds to the rotation of the galaxy as a whole. So the rotational velocity of a galaxy is related to the the orbital speed of the constituent stars.
Hi
Thanks for the reply. So how is the rotational velocity of a galaxy related to the orbital speed of the constituent stars? It's probably not as simple as being related by a factor of a constant. What are the dependent factors here?
Thanks
Actually, some speak about the rotational velocity of stars: http://astro.berkeley.edu/~mwhite/darkmatter/rotcurve.html
"To make a rotation curve one calculates the rotational velocity of e.g. stars along the length of a galaxy by measuring their Doppler shifts..."
I thought a rotation curve plots the orbital velocity of stars (?)
Thanks
mun said:
Hi
Thanks
In practice what is measured are the orbital speeds of stars at a given distance from the galactic center. The orbital speeds are found to be roughly constant, but that means that the angular speeds are still decreasing as we go to further distances. So the different parts of the galaxy are not moving together like a solid object. Therefore, it's not straightforward to just convert the orbital motion into a rotation of the galaxy at a whole.
It still makes sense to talk about a rotational speed at a given distance, since the orbital speed at a fixed distance is essentially the same for any star because of the relationship between the centripetal force and gravitational force. Some stars may have orbits that deviate from the galactic plane, though, so the reported rotational velocity at a given distance is an average of several measurements.
Thanks
It seems to be just an abuse of terminology. It's clear from the discussion there that no one is measuring the rotation of the individual stars about their own axes.
Related to Orbital velocity and rotational velocity
1. What is orbital velocity and rotational velocity?
Orbital velocity refers to the speed at which an object orbits around another object, such as a planet around a star. Rotational velocity, on the other hand, refers to the speed at which an object rotates around its own axis.
2. How are orbital velocity and rotational velocity related?
Orbital velocity and rotational velocity are related in that they both involve the movement of an object in a circular path. However, their speeds and directions are different, as orbital velocity is affected by the pull of gravity from another object while rotational velocity is affected by the object's own spin.
3. What factors affect the orbital velocity of an object?
The orbital velocity of an object is affected by its distance from the object it is orbiting, the mass of the object it is orbiting, and the gravitational constant. These factors determine the strength of the gravitational pull and therefore the speed at which the object will orbit.
4. How is rotational velocity measured?
Rotational velocity is typically measured in units of rotations per minute (RPM) or radians per second. This can be calculated by dividing the angle of rotation by the time it takes to complete one full rotation.
5. Why is orbital velocity important?
Orbital velocity is important because it determines the stability and location of objects in orbit. It also plays a crucial role in space travel and the ability to launch satellites into orbit around Earth.
  • Astronomy and Astrophysics
  • Mechanics
