Orbitting electron moved to Magnetic Field
In summary, when an electron in a hydrogen atom is moved into a magnetic field parallel to its orbital angular momentum, the change in frequency of its motion can be calculated by finding the net force acting on the electron and using the formula frequency=v/(2*pi*r), where v is the final velocity of the electron and r is the radius of its orbit. This can be done by setting the magnetic force equal to the electric force and solving for v using the quadratic formula. The change in velocity caused by the magnetic field is relatively small compared to the initial velocity of the electron.
Dopefish1337
47
An electron in a hydrogen atom moves in a circular orbit of radius 5.10×10-11 m at a speed of 2.80×106 m/s. Suppose the hydrogen atom is transported into a magnetic field of 0.70 T, where the magnetic field is parallel to the orbital angular momentum. What is the change of frequency of the motion of the electron?
F=qvB
acircle=v2/r
Well, the initial frequency would be 2.800*106/(5*10-11*2*pi)= 8.7379*10^15 Hz.
If I then take qvB=mv2/r, and rearrange for r and stick that result into the frequency formula, I get qB/(2*pi*m)= 1.959*1010, 5 orders of magnitude less and thus essentially insignificant compared to the intial amount. Clearly this is wrong. However, I don't know what else to try from here.
Help?
(Oh, and although I doubt it'd matter looking at the initial speed, but I'm fairly confident any relativistic effects can be safely ignored.)
You wrote:
F=qvB​
That is the force due to the magnetic field. What other force acts on the electron (and thus contributes to the overall net force)?
Whatever force that was keeping it orbitting in the first place would still be there I suppose.
That force would be the electric force I guess, so F=qE=mvi2/r would be the initial force.
I suppose I could work out that initial force numerically, getting some number Fe.
Would it be possible to then have Fe+QvB=mv2/r, and solve that for v, substituting that result into the frequency formula?
Or would something else change complicating matters? (Or, am I barking down the wrong tree altogether?)
edit: Fe+QvB=mv2/r would need to be solved via the quadratic formula would it not?
I haven't actually solved it, so I'll just say that yes, it appears like the quadratic formula is the way to go here.
That being said, there might be some approximation that would simplify things, based on the QvB term is much, much smaller than both Fe and mv2/r. I don't know for sure if that is useful, just thought I'd mention it.
Doing it by hand, this method didn't work.
However, with some help from excel to carry decimals all the way through, it did work (my 'by hand' was close though...). Silly computer being picky about answers...
Anyway, thanks!
Incidently, the change in v was about 3.1 m/s, so that field really didn't make much of a difference relatively speaking...
FAQ: Orbitting electron moved to Magnetic Field
How does a magnetic field affect an orbitting electron?
The presence of a magnetic field can cause an orbitting electron to change its path or speed, depending on the orientation of the field and the direction of the electron's motion.
What is the relationship between the strength of a magnetic field and the motion of an orbitting electron?
The strength of the magnetic field can directly impact the motion of an orbitting electron. A stronger magnetic field will exert a greater force on the electron, causing it to change its path or speed more significantly.
Can a magnetic field cause an orbitting electron to move in a circular path?
Yes, a magnetic field can cause an orbitting electron to move in a circular path if the field is perpendicular to the direction of the electron's motion. This is known as circular motion or magnetic circular motion.
How does the mass of an electron affect its response to a magnetic field?
The mass of an electron does not significantly impact its response to a magnetic field. All electrons have the same charge-to-mass ratio, so they will experience the same force from a magnetic field regardless of their mass.
Can a magnetic field cause an orbitting electron to change its energy level?
Yes, a magnetic field can cause an orbitting electron to change its energy level through a process called Zeeman splitting. This occurs when the electron's orbit is disrupted by the magnetic field, causing it to jump to a different energy level.
