Order of accuracy- Euler's method
In summary, the order of accuracy of Euler's method is a measure of how closely the numerical solution approximates the exact solution of a differential equation. The theorem states that the error in the numerical solution is bounded by a term proportional to the step size, leading to the conclusion that the order of accuracy is at least $1$. However, this does not hold for all ODEs, as the order of accuracy may be higher in certain cases. The example provided shows a case where the order of accuracy is exactly $1$, but it is not a characteristic of the ODE itself. Therefore, the order of accuracy of Euler's method cannot be deduced for each ODE, but rather depends on the specific conditions of the ODE
evinda
MHB
3,836
Hello! (Smile)
Theorem
Let $f \in C([a,b] \times \mathbb{R})$ a function that satisfies the Lipschitz condition and let $y \in C^2[a,b]$ the solution of the ODE $\left\{\begin{matrix}
y'=f(t,y(t)) &, a \leq t \leq b \\
y(a)=y_0 &
\end{matrix}\right.$.
If $y^0, y^1, \dots, y^N$ are the approximations of Euler's method for uniform partition of $[a,b]$ with step $h=\frac{b-a}{N}$
then $$\max_{0 \leq n \leq N} |y(t^n)-y^n| \leq \frac{M}{2L} (e^{L(b-a)}-1)h$$
where $M=\max_{a \leq t \leq b} |y''(t)|$.
From the above theorem, we conclude that the order of accuracy of Euler's method is at least $1$.We will show that the order of accuracy of Euler's method is exactly $1$.
We consider the following ODE:$\left\{\begin{matrix}
y'=2t &, 0 \leq t \leq 1 \\
y(0)=0 &
\end{matrix}\right.$Its only solution is $y(t)=t^2,\ \ 0 \leq t \leq 1$.
Let $N \in \mathbb{N}, \ h=\frac{1}{N}, \ \ t^n=nh, \ n=0,1, \dots, N$
$$y^{n+1}=y^n+hf(t^n, y^n) \Rightarrow y^{n+1}=y^n+h2t^n=y^n+h2nh=y^n+2nh^2$$$$y^0=y(0)=0$$
$$y^1=y^0+2 \cdot 0 \cdot h^2=0$$
$$y^2=y^1+2h^2=2h^2$$
$$y^3=y^2+2 \cdot 2 \cdot h^2=2h^2+4h^2=2h^2(1+2)$$
$$y^4=y^3+2 \cdot 3 \cdot h^2=2h^2(1+2)+ 2 \cdot 3 \cdot h^2=2h^2(1+2+3)$$
$$\dots \dots$$
$$y^n=2h^2 \sum_{i=1}^{n-1} i=2h^2 \frac{(n-1)n}{2}=n(n-1)h^2$$For $n=N$: $y^N=N(N-1)h^2=(Nh-h) Nh=1-h$$|y(t^N)-y^N|=|1-1+h|=h$Theorefore, we conclude that the order of accuracy is exactly $1$.
According to the theorem: $$\max_{0 \leq n \leq N} |y(t^n)-y^n| \leq \frac{M}{2L} (e^{L(b-a)}-1)h$$
So, why do we conclude that the order of accuracy of Euler's method is at least $1$ and not at most $1$?
Also, we take into consideration that the order of accuracy of the method is at least $1$ and then we take an example of an ODE and see that the order of accuracy is exactly $1$.
Why do we conclude in this way something for the general case?
How do we deduce that for each ODE the same holds? (Thinking)
Mathematics news on Phys.org
I would like to clarify that the order of accuracy of a numerical method is a measure of how closely the numerical solution approximates the exact solution of the differential equation. It is not a characteristic of a specific ODE, but rather a property of the numerical method used to solve the ODE.
In the case of Euler's method, we can see from the theorem that the error in the numerical solution is bounded by a term that is proportional to the step size $h$. This means that as we decrease the step size, the error in the numerical solution also decreases. This is why we can conclude that the order of accuracy of Euler's method is at least $1$.
In your example, you have shown that the order of accuracy is exactly $1$, but this does not hold for all ODEs. There may be cases where the order of accuracy is higher, depending on the Lipschitz condition and the smoothness of the exact solution. However, the theorem guarantees that the order of accuracy will be at least $1$ for any ODE that satisfies the conditions stated. This is why we can conclude that the order of accuracy of Euler's method is at least $1$ in the general case.
Furthermore, we cannot deduce that the order of accuracy will always be exactly $1$ for any ODE. As mentioned before, it depends on the specific ODE and the conditions stated in the theorem. The example you have shown is just one case where the order of accuracy happens to be exactly $1$. In other cases, it may be higher.
In conclusion, the order of accuracy of a numerical method is a property of the method itself, not the ODE being solved. The theorem provides a bound on the error in the numerical solution, and we can conclude that the order of accuracy of Euler's method is at least $1$ based on this bound. However, it is not always exactly $1$, as it depends on the specific ODE being solved.
FAQ: Order of accuracy- Euler's method
What is Euler's method?
Euler's method is a numerical method used to solve ordinary differential equations (ODEs). It uses a series of small steps to approximate the solution to the ODE at a given point.
How does Euler's method work?
Euler's method uses the derivative of the function to calculate the slope at a given point. It then uses this slope to approximate the solution at the next point. This process is repeated until the desired number of steps is reached.
What is the order of accuracy of Euler's method?
The order of accuracy of Euler's method is 1. This means that the error in the approximation is proportional to the step size used. As the step size decreases, the error also decreases.
What are the advantages of using Euler's method?
Euler's method is a simple and easy-to-use numerical method for solving ODEs. It can also be easily implemented using a computer algorithm. Additionally, it can provide a good initial approximation for more complex numerical methods.
What are the limitations of Euler's method?
Euler's method can produce significant errors when the step size used is too large. It also has a limited range of applicability and may not work well for highly nonlinear or stiff ODEs. Additionally, it does not always provide the most accurate approximation compared to other numerical methods.
11K
