Order of Accuracy for $\frac{f(x+2h)-f(x)}{2h}$ - Wave
  • MHB
  • Thread starter evinda
  • Tags
    Accuracy
In summary, the divided difference $\frac{f(x+2h)-f(x)}{2h}$ approximates the derivative with an order of accuracy of 1, according to the formula and calculation provided. The conversation confirms that the summary is correct.
evinda
MHB
3,836
Hello! (Wave)
With what order of accuracy does the divided difference $\frac{f(x+2h)-f(x)}{2h}$ approximate the derivative?
I have tried the following:
$$f(x+2h)=f(x)+ 2h f'(x)+ 2h^2 f''(\xi) , \xi \in (x,x+2h)$$
$$\frac{f(x+2h)-f(x)}{2h}=\frac{2h f'(x)+ 2h^2 f''(\xi)}{2h}=f'(x)+hf''(\xi)$$
$$\left|\frac{f(x+2h)-f(x)}{2h}-f'(x) \right|=h f''(\xi)$$
Thus the order of accuracy is $1$.
Am I right? (Thinking)
Mathematics news on Phys.org
Hey evinda! (Smile)
Yep. You are right. (Nod)
I like Serena said:
Hey evinda! (Smile)
Nice... Thank you! (Smile)
FAQ: Order of Accuracy for $\frac{f(x+2h)-f(x)}{2h}$ - Wave
What is the order of accuracy for $\frac{f(x+2h)-f(x)}{2h}$ - Wave?
The order of accuracy for $\frac{f(x+2h)-f(x)}{2h}$ - Wave is second-order. This means that the error decreases quadratically as the step size, h, is decreased.
How is the order of accuracy determined for this equation?
The order of accuracy is determined by analyzing the Taylor expansion of the function, which approximates the original function at each step size. The highest order term that remains in the expansion is used to determine the order of accuracy.
What is the significance of the order of accuracy for $\frac{f(x+2h)-f(x)}{2h}$ - Wave?
The order of accuracy indicates how quickly the error decreases as the step size, h, is reduced. A higher order of accuracy means that the function is a better approximation of the actual function, and the error decreases faster.
Does the order of accuracy affect the precision of the equation?
Yes, the order of accuracy directly affects the precision of the equation. A higher order of accuracy means that the function is a better approximation of the actual function, resulting in a more precise solution.
Are there any other factors that can affect the accuracy of this equation?
Yes, there are other factors that can affect the accuracy of this equation, such as the smoothness of the function and the choice of step size, h. A function that is not smooth may result in a lower order of accuracy, and a larger step size may also decrease the accuracy of the equation.
