MHB Order of operations doubt on this expression
The expression $\frac{1}{2}*2x*x-2$ can be evaluated in two ways, leading to different results. The first method simplifies directly to $x^2 - 2$, while the second method incorrectly applies the order of operations, resulting in $x^2 - 1$. The discrepancy arises from the interpretation of the expression; the order of operations dictates that multiplication should be prioritized over subtraction. The correct interpretation confirms that the first method is valid. Understanding the proper application of the order of operations is crucial for consistent results.
mathlearn
Let's say that we have this expression,
So now solving this in one method we can
$\frac{1}{\cancel 2}*\cancel2x*x-2=x^2-2$
In another way
$\frac{1}{2}*2x*x-2=\frac{2x^2-2}{2}=x^2-1$
What is the reason that I get two different answers ? I hope that both ways are valid
Many THanks :)
Mathematics news on Phys.org
The order of operations dictates that we do multiplication/division first before subtraction, so the first method is correct. The second method you used would be valid if we had:
$$\frac{1}{2}(2x\cdot x-2)$$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
