Which Major Pathway Predominates for This Organic Reaction?
In summary, Alkyl halides can undergo substitution reactions (via SN1 or SN2 mechanisms) and/or elimination reactions (via E1 or E2 mechanisms). Substitution reactions are favoured by the presence of a leaving group, while elimination reactions are favoured by the presence of a weak base and a polar aprotic solvent.
Ian_Brooks
129
[PLAIN]http://sphotos.ak.fbcdn.net/hphotos-ak-snc3/hs527.snc3/29952_406506367415_501337415_4229454_854152_n.jpg
Alkyl halides can undergo substitution reactions (via SN1 or SN2 mechanisms) and/or elimination reactions (via E1 or E2 mechanisms). Illustrate your understanding of these pathways in the following by:
i) indicating the reaction mechanism(s) favoured by the particular type of: leaving group,
substrate, nucleophile/base and solvent employed,
ii) predicting the major pathway(s) that will occur under these conditions, and
iii) providing the structure(s) of the major product(s) of the reaction.
Leaving Group: TsO(-) is a good LG
Substrate: Secondary, which is favoured by all
Nucleophile/base:I(-) is a weak base, and not a great nucleophile, which promotes E1
Solvent: Polar aprotic, which promotes both SN2 and E2
I'm not sure if it's supposed to be SN2, E2 or E1! I know E2 is promoted with strong bases, but does it really need it? The other two questions in this section were E2 and E1, so maybe, to test broadness of capability, it whould be an SN@? But I don't see how the variables would support this, besides MAYBE the Nucleophile I(-) would support substitution rather than either E1 or E2?
Hi Ian_Brooks!
Your "atempts" are all correct. However, it is hardly true that iodide ion is a bad nucleophile (e.g. http://www.chem.ucalgary.ca/courses/351/Carey5th/Ch08/ch8-5.html). It will definitely substitute TsO- which is as you said a good leaving group! You were right that in acetonitrile both Sn2 and E2 are favourable and a small amount of the elimination product may form, but as the reaction is carried without heating and iodide ion is a very poor base (pKa of HI acid is -10) the main product will come from Sn2 reaction.
Thanks for the clarification! Nucleophilicity increases down the group, I have to remember that
FAQ: Which Major Pathway Predominates for This Organic Reaction?
1. What is "Organic Major Pathway prediction"?
Organic Major Pathway prediction is a scientific process that uses computational methods to predict the most likely biochemical pathways that an organic compound will undergo in a living organism.
2. Why is "Organic Major Pathway prediction" important?
Organic Major Pathway prediction is important because it allows scientists to understand and predict how a compound will interact with living organisms, which is crucial for drug development, environmental toxicology, and understanding biological processes.
3. How does "Organic Major Pathway prediction" work?
Organic Major Pathway prediction typically involves using computer software to analyze the structure and properties of a compound and compare it to known biochemical pathways. This can include using databases, algorithms, and molecular modeling techniques to make predictions.
4. What are the limitations of "Organic Major Pathway prediction"?
One limitation of Organic Major Pathway prediction is that it relies on the accuracy and completeness of the data used in the analysis. If there is limited information available on a specific compound, the predictions may not be reliable. Additionally, there may be other factors that influence a compound's pathway that are not accounted for in the prediction process.
5. How accurate is "Organic Major Pathway prediction"?
The accuracy of Organic Major Pathway prediction can vary depending on the methods and data used. Generally, predictions can be accurate for well-studied compounds, but may be less reliable for novel or complex compounds. It is important to validate predictions with experimental data to improve accuracy.
