Organic Nomenclature and Simple Reactions
In summary, ethane is formed when an excess of chlorine gas is added to acetylene gas. Bromine is then added to the mixture.
Shay10825
338
Hello. Can someone please check my work and help me with these problems. I'm sorry it is so long.
Predict and balance the following organic equation.
1. Ethanol (ethyl alcohol) is burned completely in air
C2H5OH + 3O2 > 2CO2 + 3H2O
2. Propane gas is heated with chlorine gas
C3H8 + Cl2 > C3H7Cl + HCl
3. Ethanol (ethyl alcohol) and methanoic acid (formic acid) are mixed and warmed
C2H5OH + CH3OH > CO2 + H2O
If this is correct then how do I balance it?
4. Ethene gas is bubbled through a solution of bromine
C2H4 + Br2 > C2H4Br2
5. Hydrogen gas is added to 2-pentene
H2 + C5H10 > C5H12
6. Octane is burned in oxygen
2C8H18 + 25 O2 > 16CO2 + 18H2O
7. 2-butene is combined with hydrogen gas in the presence of a nickel catalyst
C4H10 + H2 +Ni > ?
8. Ethanoic acid is combined with propanol
C2H5OH + C3H7OH > CO2 + H2O
9. An excess of chlorine gas is added to pure ethyne (acetylene) gas
Cl2 + C2H2 > C2H2Cl2
10. A limited amount of liquid bromine is added to an excess of benzene (C6H6)
Br2 + C6H6 > C6H4Br2 + H2
Name the following hydrocarbon compounds.
1. (CH3)2CHCl
dimethyl?? How do I name it with the Cl ??
2. CH3C(CH3)2CH2C(CH3)2CH2CH2CH3
2,4 dimethylheptane
3. CH3C(CH3)2CH - - C(CH3)CH2CH3
2,4 dimethylpentane
4. CH3C --- CCH3
1,2 dimethylethane
Thanks
That's right.
There can be more than 1 product here. This looks like the halogenation reaction. You will have to carry this out in the presence of sunlight
No, this is not correct. Formic acid is HCOOH. CH3OH is methanol
This is correct.
H2 + C5H10 > C5H12
Will there be a reaction? I think you would require a presence of a catalyst to notice any reaction.
Products are right. I have not checked if it's balanced
C4H10 + H2 +Ni > ?
Refer question 5
This is wrong. Ethanoic acid is CH3COOH. C2H5OH is Ethanol.
Not completely correct.
You are adding an excess of Chlorine gas. Will the reaction stop here?
This is wrong. Benzene is aromatic. It will undergo substitution reactions rather than addition reactions.
1. (CH3)2CHCl
The longest Carbon chain is 3 carbons long. So it will be a substitited propane rather than dimethyl methane. I'll do this one and see if you can do the rest. The IUPAC name will be 2-Chloro Propane.
2,4 dimethylheptane
This is not correct. How many methyl groups are attached? 2 on the second carbon and 2 on the fourth carbon.
2,4 dimethylpentane
This is wrong.
Look at the longest Carbon chain. Besides, there is a double bond. So it should be an alkene
Shay10825 said:
4. CH3C --- CCH3
1,2 dimethylethane
There should be a triple bond right? So it's an alkyne not an alkane.
well I remembered that alkynes don't undergo electrophilic additions as well as the alkenes, the exact reason I do not recall at the moment. There are methods of addition (whether electrophilic or nucleophilic) but I remember that it involves some sort of metal catalyst. There are some important reactions with ethyne (such as the possibility of carbon carbon bond formation) but I wasn't familiar with it just reacting with a bromine molecule (I can't remember at the moment but a particular halogenated ethane or ethene isomer predominates between interconversions of isomers and is a byproduct of a laundry detergent or some other industrial chemical...that is before they stopped using it-that is tetra-chloroethane may be formed to a certain extent).
When I learned this a couple of years ago in high school, I was taught that the addition of halogens to alkenes and alkynes is by the halonium ion intermediate (ie, the cyclic intermediate with the Br+ and the 2 carbons).
That is, in the first step the attacking species is Br+ which forms this cyclic halonium. Then, in the second step the Br- reacts with the halide ion to give the addition product.
So, I guess the reason why alkynes don't undergo electrophilic addition with halogens as well as alkenes is beacuse the intermediate formed with the alkynes is more strained and less stable than the intermediate formed from the alkenes.
In all my exams to date, I have been writing that the final product when excess halogens react with alkynes is the tetrahalo alkane. It was a surprise when you showed that it wasn't true for ethyne
Hey
i noticed you has the reaction for Propane + chloride = C3H7Cl + Hydrochloric acid
what is the name of C3H7Cl using the IUPAC system for naming
I believe you would refer to that one as either 1 or 2- chloro-propane depending upon the substitution location.
hey, thanks for the anwers
#3 should be C2H5OH plus CHOOH yield C2H5OOCH plus H2O, i think. Also, (CH3)2CHCl is 1-chloro-1-dimethylmethane. I'm not sure if you need the 1 though.
siddharth said:
GCT, that's an excellent link.
I thought that tetrachloro ethane would be formed but your link disproves that.
How did you know that such a reaction occurs?
This is possible if acetylene is introduced into a chlorine atmosphere in an uncontrolled (thermally) manner. The reaction is exothermic enought to decompose the initially-formed dichloroethene to carbon black. Under controlled conditions, the dichloro or tetrachloro product can form. Addition of X2 across the triple and double bonds is achieved under lower temperature conditions by performing the reaction under dilution with cooling and with metal catalysts (copper, manganese, etc...).
FAQ: Organic Nomenclature and Simple Reactions
1. What is organic nomenclature?
Organic nomenclature is the systematic naming of organic compounds, which are molecules primarily composed of carbon and hydrogen atoms.
2. How are organic compounds named?
Organic compounds are named using a set of rules established by the International Union of Pure and Applied Chemistry (IUPAC) to ensure consistency and accuracy in naming. These rules involve identifying the longest carbon chain in the molecule, determining the functional groups present, and using prefixes and suffixes to indicate the type and position of substituents on the carbon chain.
3. What is the purpose of organic nomenclature?
The purpose of organic nomenclature is to provide a standardized system for identifying and communicating the structure of organic compounds. This is important in scientific research, as well as in industries such as pharmaceuticals and agriculture where precise identification of compounds is crucial.
4. How are simple reactions named?
Simple reactions, such as addition, elimination, and substitution, are named based on the type of reaction and the molecules involved. The names may also include the reactants and products, as well as the conditions under which the reaction occurs.
5. Why is it important to understand organic nomenclature and simple reactions?
Understanding organic nomenclature and simple reactions allows scientists to accurately communicate and interpret information about organic compounds and their reactions. This knowledge is essential in fields such as organic chemistry, biochemistry, and pharmacology where the properties and behaviors of organic compounds are studied and utilized.
