Orthogonal complement of the orthogonal complement
  • A
  • Thread starter victorvmotti
  • Tags
    Orthogonal
In summary, the infinite dimensional vector space of functions ##M## over ##\mathbb{C}## has an inner product defined as in square integrable functions used in quantum mechanics. The orthogonal complement of a subspace is itself closed, but the orthogonal complement of the orthogonal complement gives the topological closure of the vector space, not the vector space itself, as shown by the equation $$M^{{\perp}{\perp}}=\overline M.$$ A proof for this statement is that, by definition, ##M## is a subset of its double orthogonal complement, and taking closures shows that the topological closure of ##M## is a subset of the double orthogonal complement. It is also noted that orthogonal complements are
victorvmotti
155
Consider the infinite dimensional vector space of functions ##M## over ##\mathbb{C}##.
The inner product defined as in square integrable functions we use in quantum mechanics.
If we already know that the orthogonal complement is itself closed, how can we show that the orthogonal complement of the orthogonal complement gives the ***topological closure*** of the vector space and not the vector space itself?
$$M^{{\perp}{\perp}}=\overline M$$
Is this a homework question or are you merely curious? I would say you should look carefully at the definition of the orthogonal complement (keeping in mind the infinity of the dimension).
Clearly ##\overline{M}## is contained in the double orthogonal complement as limits of sequences preserve orthogonality. So you can't expect that it is equal to ##M## in general.
Is this proof a good one:
Let ##M \subseteq \mathcal{H}## be a linear subspace.
(i) Consider ##\{\varphi_n\}## as a Cauchy sequence in ##M##
Because ##\forall \varphi_n \in M \implies \forall \mu \in M^\perp: \langle\mu, \varphi_n\rangle=0\implies \varphi_n\in (M^\perp)^\perp##
Therefore, ##M \subseteq M^{\perp\perp}##
(ii) Now ##M^{\perp\perp}## is a closed linear subspace of ##\mathcal{H}## because it is an orthogonal complement.
Therefore, it is a sub Hilbert space. Hence complete. So ##\{\varphi_n\}## is a Cauchy sequence in ##M^{\perp\perp}## and hence it converges in ##M^{\perp\perp}##:
##\lim_{n \to \infty} \varphi_n= \varphi \in M^{\perp\perp}##
We have shown that ##\{\varphi_n\}## as a Cauchy sequence in ##M## converges to ##\varphi## in ##M^{\perp\perp}## or ##M## is densely defined in ##M^{\perp\perp}##. That is the topological closure of ##M## is ##M^{\perp\perp}##:
$$\overline{M}=M^{\perp\perp}$$
This is true in any inner product space (or indeed in any space with a symmetric bilinear form). You don't need to talk about Cauchy sequences. Here is an argument: let ##v\in M##. Then, by the definition of orthogonal complement, ##\langle v,w\rangle=0## for all ##w\in M^{\perp}##. This equation also means ##v\in (M^{\perp})^{\perp}.##
Right, although you might want to check this fact (that orthogonal complements are topologically closed) if you haven't thought about the proof. Using this, taking closures of ##M\subset (M^{\perp})^{\perp}## shows that ##\overline{M}\subset (M^{\perp})^{\perp}.##
What you wrote doesn't imply that ##M## is dense in ##(M^{\perp})^{\perp}##. e.g. consider ##\mathbb{R}^1\subset\mathbb{R}^2## included in the obvious way. Any Cauchy sequence in ##\mathbb{R}^1## converges in ##\mathbb{R}^2##, but it's definitely not dense.
Related to Orthogonal complement of the orthogonal complement
What is the definition of the orthogonal complement of the orthogonal complement?
The orthogonal complement of the orthogonal complement of a vector space V is the set of all vectors in V that are orthogonal to every vector in the orthogonal complement of V.
How is the orthogonal complement of the orthogonal complement related to the original vector space?
The orthogonal complement of the orthogonal complement is a subspace of the original vector space V. This means that it shares the same properties and operations as V, but it is a smaller subset of V.
Why is the orthogonal complement of the orthogonal complement important in linear algebra?
The orthogonal complement of the orthogonal complement plays a crucial role in understanding and solving systems of linear equations. It allows for a more efficient and simplified way of finding solutions by reducing the dimension of the problem.
Can the orthogonal complement of the orthogonal complement be equal to the original vector space?
Yes, in some cases, the orthogonal complement of the orthogonal complement can be equal to the original vector space V. This occurs when V is a finite-dimensional vector space and the orthogonal complement of V is the zero vector space.
How can the orthogonal complement of the orthogonal complement be calculated?
The orthogonal complement of the orthogonal complement can be calculated using the orthogonal projection matrix. This matrix projects any vector onto the subspace orthogonal to V, and then projects that result onto the subspace orthogonal to the orthogonal complement of V, resulting in the orthogonal complement of the orthogonal complement.
  • Linear and Abstract Algebra
  • Topology and Analysis
