Orthogonal coordinate systems - scale factors
In summary, Homework statement states that the derivative of a function with respect to a given variable is the sum of the derivatives of the function with respect to all other variables. The Attempt at a Solution attempted to derive the equation for the summation for the derivative of a function with respect to a given variable, but was not successful. Differentiating with respect to a given variable gives the result that the hat{q sub i} is the sum of the hat{q sub j}s. Finally, the solution for the summation for the derivative of a function with respect to a given variable was found by Frederik when he scanned the document that he had done on the topic.
ognik
643
Start from the 'relevant equation' below and derive
$$ (1) \frac{\partial{\bf{\hat{q}}_{i}}}{{\partial{q}}_{j}}={\hat{q}}_{i}\frac{1}{{h}_{i}} \frac{\partial{h}_{i}}{{\partial{q}}_{j}}, {i}\ne{j}$$
$$ (2) \frac{\partial{\bf{\hat{q}}_{i}}}{{\partial{q}}_{i}}= -\sum {\hat{q}}_{j}\frac{1}{{h}_{j}} \frac{\partial{h}_{i}}{{\partial{q}}_{i}}, {j}\ne{i} $$
$$ \frac{\partial{\bf{r}}}{{\partial{q}}_{i}}={h}_{i}{\hat{q}}_{i} $$
I have finished the first part, using $$ \frac{\partial{\bf{\hat{r}}}}{{\partial{q}}_{j}}={h}_{j}\hat{q}_{j} $$
But I am not getting anywhere with part 2), especially with the summation ... a hint or 2 would be much appreciated please
I will put down my attempt for deriving the (2) part, although not very useful I suspect ...
I used the chain rule to get $$ \frac{\partial{\hat{q}_{i}}}{\partial{q}_{i}} = \frac{\partial\hat{{q}_{i}}}{\partial{q}_{j}}.\frac{\partial{{q}_{j}}}{\partial{q}_{i}} = \hat{q}_{j}\frac{1}{{h}_{i}}.\frac{\partial{{h}_{j}}}{\partial{q}_{i}}.\frac{\partial{{q}_{j}}}{\partial{q}_{i}}$$
So I've got the LHS and some part of the RHS - but without any way I can to end up with a -∑ term
Any problem involving partial derivatives is definitely not precalculus. I have moved this thread to the calculus section.
Sorry for the hassle, of course you're right - I must have been too focused on the problem (been struggling with it for weeks and going round in the same circles ... I'm studying by correspondence but in practice forums are the only useful support I have)
$$I\: had\: one\: of\: those\: random\: thoughts\:while\: abed\:,\: to\:use\:\hat{q}_{i}.\hat{q}_{j}=0 $$
$$Differentiating\: w.r.t.\: {q}_{i} \:gives: $$
$$ \hat{q}_{j}.\frac{\partial{{q}_{i}}}{\partial{q}_{i}} =-\hat{q}_{i}.\frac{\partial{\hat{q}_{j}}}{\partial{q}_{i}} $$
$$ From\: the\: result\: of\: part(1)\: above\: I\: can\: use\: \frac{\partial{\hat{q}_{j}}}{\partial{q}_{i}}=\hat{q}_{i}. \frac{1}{{h}_{j}}\frac{\partial{{h}_{i}}}{\partial{q}_{j}} $$
$$Therefore\: \hat{q}_{j}\frac{\partial{\hat{q}_{i}}}{\partial{q}_{i}}=-\hat{q}_{i}.\hat{q}_{i} \frac{1}{{h}_{j}}\frac{\partial{{h}_{i}}}{\partial{q}_{j}}\:and\: \hat{q}_{i}.\hat{q}_{i}=1$$
This is closer than my other efforts, but it still leaves me with a ∑ missing from the RHS and a unit vector on the wrong side ...then my brain threatened to explode, so hopefully someone will see this and help me complete it.
Apologies about my Latex, still a learning curve. Rather then confuse you further, please view this doc -
https://drive.google.com/file/d/0ByNoaXX7FNqRQ1NSZXg4WjN0czQ/view?usp=sharing
- I have copied the question first, then the text pages that lead up to it.
I managed the 1st 2 parts of the question, stuck on the third... Thanks.
I had another look at it today. (The first look was after oqnik linked to this thread from another). I still haven't been able to obtain those results for ##\frac{\partial\hat{\mathbf q}_i}{\partial q_j}##, but I think I got a bit closer. If I can prove that ##\frac{\partial^2\mathbf r}{\partial q_i\partial q_j}## is a vector in the plane spanned by ##\{\mathbf q_i,\mathbf q_j\}##, then I will have proved the ##i\neq j## result at least.
You asked specifically about the summation in the result for ##\frac{\partial\hat{\mathbf q}_i}{\partial q_j}##. That's the only part that I understand completely. For all vectors ##\mathbf v##, we have
$$\mathbf v=\sum_{j=1}^3 (\mathbf v\cdot\hat{\mathbf q}_j)\hat{\mathbf q}_j.$$ When we consider the special case ##\mathbf v=\frac{\partial\hat{\mathbf q}_i}{\partial q_i}##, the ##j=i## term is going to be zero. (I was able to prove that). So we get
$$\frac{\partial\hat{\mathbf q}_i}{\partial q_i} =\sum_{j\neq i} \left(\frac{\partial\hat{\mathbf q}_i}{\partial q_i}\cdot\hat{\mathbf q}_j\right)\hat{\mathbf q}_j.$$
You said that you were able to obtain the result for ##\frac{\partial\hat{\mathbf q}_i}{\partial q_j}## when ##i\neq j##. How did you do that? I'm not quite there yet. I feel like I must be missing something that makes the problem easier.
Hi Frederik - I didn't trust my latex with rewriting it, so I scanned the page I had done on deriving (1) in my initial post - so my solution for (1) should be viewable at https://drive.google.com/file/d/0B_fp1L8s2RmZZTMyQ25IQTI4Um8/view?usp=sharing
Your equation was all I needed (I think), but I would be grateful if you'd also check my solution to part (2) above - posted at https://drive.google.com/file/d/0B_fp1L8s2RmZTkFTdEpjWVJkcnc/view?usp=sharing
I have to admit I don't fully understand what most of the expressions mean geometrically, I was just doing the arithmetic ... I believe the h's represent the coefficiants of a generalized curvilinear orthogonal transformation, making the hat{q sub i}s the basis, so if you could also breakdown the 2 equations I 'proved' into something I can understand (maybe a sketch?), that would be very helpful as well :-) Thanks again, Alan
In the first attachment, you say without explanation that ##\frac{\partial\hat{\mathbf q}_i}{\partial q_j}## is in the ##\hat{\mathbf q}_j## direction. Have you been able to prove that?
I still haven't worked out the first part completely, but I will show you what I have. I will save myself some typing by defining
$$\mathbf X_{ij}=\frac{\partial^2\mathbf r}{\partial q_i\partial q_j}.$$ My understanding of ##h_i## and ##\hat{\mathbf q}_i## is that the latter is defined as the unit vector in the direction of ##\frac{\partial\mathbf r}{\partial q_i}##, and the former is defined by ##\frac{\partial\mathbf r}{\partial q_i}=h_i\hat{\mathbf q}_i##. This implies that ##h_i=\big|\frac{\partial\mathbf r}{\partial q_i}\big| =\sqrt{\big(\frac{\partial\mathbf r}{\partial q_i}\big)^2}##. It's not hard to show that this implies that
$$\frac{\partial h_i}{\partial q_j}=\hat{\mathbf q}_i\cdot\mathbf X_{ij}.$$ I will use that result in the calculation below. Now let ##i,j,k## have three different values in the set ##\{1,2,3\}##. We have
\begin{align}
&\frac{\partial\hat{\mathbf q}_i}{\partial q_j} =\frac{\partial}{\partial q_j}\left(\frac{1}{h_i}\frac{\partial\mathbf r}{\partial q_i}\right) =-\frac{1}{h_i^2}\frac{\partial h_i}{\partial q_j}\frac{\partial\mathbf r}{\partial q_i}+\frac{1}{h_i}\mathbf X_{ij} =\frac{1}{h_i}\left( -\big(\hat{\mathbf q}_i\cdot\mathbf X_{ij}\big)\hat{\mathbf q}_i+\mathbf X_{ij}\right)\\
&=\frac{1}{h_i} \big(\big(\hat{\mathbf q}_j\cdot\mathbf X_{ij}\big)\hat{\mathbf q}_j +\big(\hat{\mathbf q}_k\cdot\mathbf X_{ij}\big)\hat{\mathbf q}_k\big) = \frac{1}{h_i} \left(\frac{\partial h_j}{\partial q_i}\hat{\mathbf q_j}+\big(\underbrace{\hat{\mathbf q}_k\cdot\mathbf X_{ij}}_{=0?}\big)\hat{\mathbf q}_k\right)
\end{align}
I haven't examined your second attachment yet.
A) Yes, briefly - $$ \hat{q}_{i}.\hat{q}_{i}=1,\: differentiating\:w.r.t.\:{q}_{i}\: gives\: \hat{q}_{i} \frac{\partial \hat{q}_{i}}{\partial {q}_{i}} =0\:
\: \therefore \:\frac{\partial\hat{q}_{i}}{\partial {q}_{i}}\:must\:be\:in\:same\:direction\:as\:\hat{q}_{i} $$
B) You don't say, but is there a flaw in my attempt at (1)?
C) Maybe this helps :
Going back to basics, qi are generalized curvilinear (and orthogonal) coordinates, so that (q1, q2, q3) could, for example, be (r, θ, ϕ).
What is hi? It is a coefficient (with units of length), such that dsi = hi dqi - keeping with the above spherical example:
$$ h_{r}=\frac{\partial \vec{r}}{\partial r}=(sin{\theta} cos{\phi}, sin{\theta}sin{\phi},cos{\theta} $$
If the dot product of two non-zero vectors is zero, then they're not in the same direction. Instead, one of them is in the plane that's orthogonal to the other.
Edit: I see now that the calculation you did there is an essential part of the proof of the result for ##\frac{\partial\hat{\mathbf q}_i}{\partial q_i}##. It explains why we can drop the ##j=i## term from the sum right away, and then use that ##j\neq i## in the remaining terms.
I don't see anything that's wrong, but the proof isn't complete until you have proved that ##\frac{\partial\hat{\mathbf q}_i}{\partial q_j}## is in the direction of ##\hat{\mathbf q}_j##.
My attempt is no better, since I wasn't able to prove that ##\hat{\mathbf q}_k\cdot\mathbf X_{ij}=0##.
##h_r## is the scalar you get when you take the dot product of that vector with itself, and then take the square root of the result.
I like this way of looking at it: We have ##dr_i=\sum_j \frac{\partial r_i}{\partial q_j}dq_j## and therefore
$$ds^2=\sum_i dr_i^2 =\sum_i\sum_j\sum_k \frac{\partial r_i}{\partial q_j}\frac{\partial r_i}{\partial q_k}dq_j dq_k =\sum_j\sum_k \frac{\partial\mathbf r}{\partial q_j}\cdot\frac{\partial\mathbf r}{\partial q_k}dq_j dq_k.$$ When we're dealing with an orthogonal coordinate system, that dot product is zero when ##j\neq k##, so we can simplify the above to
$$\sum_j\left(\frac{\partial\mathbf r}{\partial q_j}\right)^2 dq_j^2.$$ The ##h_i## are supposed to satisfy
$$ds^2=\sum_j h_j^2 dq_j^2,$$ so we have ##h_i^2=\big(\frac{\partial\mathbf r}{\partial q_j}\big)^2##, where the "square" on the right-hand side is a dot product.
I checked your solution for the last part of the problem. To be more precise, I took a quick look at what you did, and then tried to do the same thing myself. I got the right result, and you seem to have done the same thing I did, so I think we can consider that part of the problem solved.
Related to Orthogonal coordinate systems - scale factors
What are orthogonal coordinate systems?
Orthogonal coordinate systems are mathematical systems used to represent points and locations in space. They consist of two or more axes that are perpendicular to one another, forming a right angle at their intersection.
What are scale factors in orthogonal coordinate systems?
Scale factors in orthogonal coordinate systems are used to convert distances and measurements between different axes. They represent the ratio of the change in one axis to the change in another, and are necessary because the axes in these systems are not always equal in length.
How do scale factors affect measurements in orthogonal coordinate systems?
Scale factors affect measurements in orthogonal coordinate systems by changing the units of measurement between axes. For example, if a scale factor is 2, then one unit on one axis would be equal to 2 units on the other axis.
What is the purpose of using orthogonal coordinate systems and scale factors in science?
Orthogonal coordinate systems and scale factors are used in science to accurately represent and measure points and locations in space. They are essential for mathematical calculations, data analysis, and modeling in various scientific fields such as physics, engineering, and geography.
How do you calculate scale factors in orthogonal coordinate systems?
The scale factor for an orthogonal coordinate system can be calculated by dividing the distance between two points on one axis by the distance between the same two points on another axis. This calculation can be done for each pair of axes to determine the scale factors for the entire system.
