MHB Orthogonal trajectories of curves
The discussion focuses on finding the orthogonal trajectories for the curves defined by the equations x² - y² = c and x² + y² + 2cy = 1. The first curve represents hyperbolas, while the second describes lines that are only orthogonal at specific points related to the parameter c. To find the general orthogonal curves, the parameter c must be eliminated, leading to a differential equation that results in circles centered on the x-axis. The final conclusion is that the orthogonal trajectories are indeed circles, rather than lines. The participants confirm their understanding and express gratitude for the clarification.
evinda
MHB
Hello !
I have to find the orthogonal trajectories of the curves :
x^{2}-y^{2}=c , x^{2}+y^{2}+2cy=1 ..
How can I do this??
For this: x^{2}-y^{2}=c I found \left | y \right |=\frac{M}{\left | x \right |} ,and for this: x^{2}+y^{2}+2cy=1,I found: y=Ax-D,c,A,D \varepsilon \Re .
Is this right??And how can I continue??
Mathematics news on Phys.org
evinda said:
Hello !
How can I do this??
Hi evinda! :D
That is right enough.
Actually, you can sharpen the second one a bit since $D=c$.
What do you want to continue with?
Aren't you already done?
I like Serena said:
Hi evinda! :D
Since both of the curves are given at the same subquestion,don't I have to find something common between those two solutions?? :confused: Or,what do I have to do?? :confused:
The solution for the first set of curves is a set of hyperboles.
The solution for the second set of curves is a set of lines.
They have nothing in common.
So in my opinion they are separate questions and your answer is sufficient.
Nice..Thank you very much! :)
Hold on! :o
Something was still bugging me about that $c$ in the second set of curves $$x^2+y^2+2cy=1 \qquad (1)$$
When I started to draw them, I realized that
$$y=Ax-c \qquad \qquad (2)$$
is not the proper solution.
Draw them. You'll see!Those lines are only orthogonal for points on 1 specific circle that is defined by $c$.
To find the curves that are orthogonal to the whole set of circles, we need to eliminate $c$.
From (1), we get that:
\begin{array}{}
\frac{x^2}{y}+y+2c&=&\frac 1 y \\
\frac{2x}{y}dx - \frac{x^2}{y^2}dy + dy + 0 &=& -\frac{1}{y^2}dy \\
2xydx&=&(x^2-y^2-1)dy
\end{array}
See, no $c$ involved anymore! ;)
The solution of this differential equation is the set of curves (actually circles with their center on the y axis) in (1).
To find the orthogonal curves, we need to solve the "orthogonal" differential equation:
\begin{array}{}
(x^2-y^2-1)dx&=&-2xydy \\
\Big(1 - \frac{y^2}{x^2} - \frac 1 {x^2} \Big)dx &=& - \frac{2y}{x}dy \\
dx + \left(- \frac{y^2}{x^2}dx + \frac{2y}{x}dy \right) - \frac 1 {x^2}dx &=& 0 \\
x + \frac{y^2}{x} + \frac{1}{x} &=& 2C \\
x^2 + y^2 - 2Cx &=& -1 \\
(x - C)^2 + y^2 &=& C^2 - 1
\end{array}
In other words, this is a set of circles (with their center on the x-axis) instead of a set of lines.
I like Serena said:
Hold on! :o
\begin{array}{}
\end{array}
\begin{array}{}
\end{array}
I understood it now :o Thank you very much! :)
