A Orthogonality of variations in Faddev-Popov method for path integral
Wizard
TL;DR Summary
In the derivation of the free EM path integral, it seems to be take for granted that variations in the choice of gauge are functionally orthogonal to variations that are connected by a gauge transformation. I do not see why.
Hi there, I've been stuck on this issue for two days. I'm hoping someone knowledgeable can explain.
I'm working through the construction of the quantum path integral for the free electrodynamic theory. I've been following a text by Fujikawa ("Path Integrals and Quantum Anomalies") and also reading the introduction to this paper https://arxiv.org/pdf/1407.7256.pdf.
Let me explain the context first, and I'll get to the part I don't understand.
The approach being taken in Fujikawa is to fix the gauge of the vector potential ##A_\mu## by choosing the Coulomb gauge (## \partial_k A_k = 0 ##) and taking ##A_\mu(t, \vec{\infty})=0##. This gives the action which is valid for any field satisfying the Coulomb gauge:
$$ S = \int \mathrm d^4 x \Big[ \frac 1 2 \partial_\mu A_k \partial^\mu A_k - \frac 1 2 \partial_k A_0 \partial^k A_0 \Big] $$
So, now the quantum path integral is given by
$$ \mathcal Z = \int \mathcal D \bar{A}^c \exp\left\lbrace \frac i \hbar \int \mathrm d^4 x \Big[ \frac 1 2 \partial_\mu A_k \partial^\mu A_k - \frac 1 2 \partial_k A_0 \partial^k A_0 \Big] \right\rbrace $$
where ## \int \mathcal D \bar{A}^c ## refers to an integration over unique field configurations in the Coulomb gauge (multiple Coulomb-gauge fields can represent the same physical system via ## A_\mu \mapsto A_\mu + \partial_\mu w## with ## \partial_k \partial_k w = 0 ##). The measure ascribed to the differential ## \mathcal D \bar{A}^c ## is inherited from the ambient space of generic field configurations ## \mathcal D A_\mu ## which does not respect the duplicity of field configurations.
Now, we would like to write the integral in terms of ## \int \mathcal D A ##, which produces a functional determinant and dirac-delta distribution which must multiply the integrand. We later introduce some new integration variables so that we can absorb the functional determinant and the dirac-delta distribution into the exponential, and get an effective Lagrangian in the path integral, now written in normal form, which allows us to touch base with the operator formalism.
All good so far.
Here's the problem: the approach for writing ## \int \mathcal D A ## in terms of ## \int \mathcal D \bar{A}^c ##. The approach (https://arxiv.org/pdf/1407.7256.pdf equation 3) is to write
$$ A_\mu = \bar{A}_\mu + \partial_\mu w $$
or in Fujikawa's case
$$ A_k = \bar{A}^c_k + \partial_k w $$
where ## \bar{A}^c ## satisfies the Coulomb gauge. Then we say
$$ \int \mathcal D A \exp \left\lbrace \dots \right\rbrace = \int \mathcal D \bar{A}^c \int \mathcal D w \exp \left\lbrace \dots \right\rbrace \, .$$
But hold up. The equation above is only correct if the effect of variations in ##w## on the value of ##A## are orthogonal to the variations of ##\bar{A}^c##:
$$||\delta(A)||^2 = \sum_{k=1}^3 \int \mathrm d^4 x \Big[ ||\delta(\bar{A}^c_k)(x)||^2 + ||\delta(\partial_k w)(x)||^2 \Big] \, .$$
This is what Fujikawa claims in Path Integrals and Quantum Anomalies, eq. (3.28).
I cannot see why this should be true. In fact, if ## \partial_k \delta(\partial_k w) = 0 ## then it seems the two variations are certainly not orthogonal, as the gauge variation maintains the Coulomb gauge and could be replicated by a variation in ## \bar{A}^c ##. (reading this again, I realize that ## \bar{A}^c ## is restricted to fields not connected by gauge transformations by definition... I am really just confused in general here).
So the whole derivation of Fujikawa and in the linked paper both rely on this idea that the gauge degree of freedom ## w ## is functionally orthogonal to the degrees of freedom which are not equivalent under a variation of gauge. But I just can't see any reason why that should be the case. Any help appreciated. Maybe there is something else I'm not understanding properly.
I am not sure whether I understand your problem or not. Let me assume you seem to have an issue with the method in general, therefore please apologize if I am mistaken.
The Faddeev-Popov methods begins with the concept of separating the set of physically distinct field configurations from those sets of fields that are connected by some gauge transformation. In your notation the barred ##\bar{A}## fields are just this: different potentials/fields leading to different field strengths. Then, any gauge transformation by means of some gauge function ##\omega## automatically defines orthogonality (in the sense of the fibre bundle language).
Is this response somehow along the route of discussion you are heading to?
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
I am reading WHAT IS A QUANTUM FIELD THEORY?" A First Introduction for Mathematicians. The author states (2.4 Finite versus Continuous Models) that the use of continuity causes the infinities in QFT: 'Mathematicians are trained to think of physical space as R3. But our continuous model of physical space as R3 is of course an idealization, both at the scale of the very large and at the scale of the very small. This idealization has proved to be very powerful, but in the case of Quantum...
Thread 'Lesser Green's function'
The lesser Green's function is defined as: $$G^{<}(t,t')=i\langle C_{\nu}^{\dagger}(t')C_{\nu}(t)\rangle=i\bra{n}C_{\nu}^{\dagger}(t')C_{\nu}(t)\ket{n}$$ where ##\ket{n}## is the many particle ground state. $$G^{<}(t,t')=i\bra{n}e^{iHt'}C_{\nu}^{\dagger}(0)e^{-iHt'}e^{iHt}C_{\nu}(0)e^{-iHt}\ket{n}$$ First consider the case t <t' Define, $$\ket{\alpha}=e^{-iH(t'-t)}C_{\nu}(0)e^{-iHt}\ket{n}$$ $$\ket{\beta}=C_{\nu}(0)e^{-iHt'}\ket{n}$$ $$G^{<}(t,t')=i\bra{\beta}\ket{\alpha}$$ ##\ket{\alpha}##...
