Orthogonality Problem (From Fourier Analysis Text)
In summary, the problem is that you are trying to find the double integral of a function in a domain that is not the unit circle. You may want to use the Cauchy-Goursat theorem if you are familiar with it. Another approach could be to use the exponential rep.
GridironCPJ
44
Hello all,
I'm working through a majority of the problems in "A First Course in Wavelets with Fourier Analysis" and have stumbled upon a problem I'm having difficulty with. Please view the PDF attachment, it shows the problem and what I have done with it so far.
Once you have seen the problem and my work so far, what do you suggest I do for the next step? I thought about using the definition of the space D and setting everything less than or equal to the double integral of 1^(j+k_/2, which is just the double integral of 1 and you get xy, then I'm at a dead end, so perhaps that's not the correct route. Your ideas would be greatly appreciated.
  • Physicsforum question 1.pdf
Before you dive into the math, think what these functions look like geometrically. The region is the unit circle...
You should be able to see "why" it is true geometrically, and therefore see how to prove it before you start writing down integrals.
(Hint: the word "circle" is in bold)
Another approach: You may also want to consider using the Cauchy-Goursat theorem, if you're familiar with it.
Think also of the exponential rep. e. Maybe this is what Aleph was suggesting.
BTW, your factorization is incorrect.
And, sorry to nitpick,but you're not really letting your θn's be in L2(D); they are there already; you're letting your θn's be given by (x+iy)n
EDIT: Cauchy-Goursat does not apply here, since the product function is not analytic.
Yes, I realized earlier that my expansion was incorrect. I used polar coordinates, so we start with
∫∫[(rcosθ+irsinθ)^j(rcosθ-rsinθ)^k]rdrdθ
From here I integrated with respect to r first and then I pulled in out and was left with
[r^(j+k+2)/j+k+2]∫(cosθ+isinθ)^j(cosθ-isinθ)^k dθ
where j≠k. I am not sure exactly how to proceed. Is there an expansion of (x+iy)^j(x-iy)^k that I am not thinking of? The value in the integrand will have the form cosθ^j+k+" "+/-isinθ^j+k, where the " " represents combinations of sinθcosθ's, which integrate to zero. So I'm left with the first and last terms, which should be zero if θ=∏, correct?
If my method or logic is not optimal, please point me in the right direction.
FAQ: Orthogonality Problem (From Fourier Analysis Text)
What is the Orthogonality Problem in Fourier Analysis?
The Orthogonality Problem in Fourier Analysis is a mathematical problem that asks whether two different trigonometric functions can be orthogonal to each other on a given interval.
Why is the Orthogonality Problem important in Fourier Analysis?
The Orthogonality Problem is important in Fourier Analysis because it helps us understand how different trigonometric functions behave and interact with each other. It also plays a key role in the development and applications of Fourier series and transforms.
What are some real-world applications of the Orthogonality Problem?
The Orthogonality Problem has many real-world applications, including signal processing, image and sound compression, and solving differential equations in physics and engineering.
What are the implications of solving the Orthogonality Problem?
Solving the Orthogonality Problem can lead to a better understanding of the behavior of trigonometric functions and their applications in various fields. It can also provide more efficient and accurate methods for analyzing and processing signals and data.
What are some related concepts to the Orthogonality Problem?
Related concepts to the Orthogonality Problem include the concept of orthogonality in linear algebra, the Fourier series, and the Fourier transform. These concepts all involve the idea of orthogonality and have applications in various fields of mathematics and science.
