Oscillating series RLC circuit
RLC circuit with a 8.77 Ω resistor and a 15.0 H inductor, the time required for the maximum energy present in the capacitor during an oscillation to fall to 1/8 its initial value can be found by taking the maximum of the function U(t) and finding the time when it falls to 1/8 of the original value. The "phi" aspect in the function represents the initial phase angle and can be solved for by setting cos(w't+ phi) = 1. The maximum energy is then calculated using the equation (Qe^(-Rt/2L))^2/(2C).
reising1
54
In an oscillating series RLC circuit, with a 8.77 Ω resistor and a 15.0 H inductor, find the time required for the maximum energy present in the capacitor during an oscillation to fall to 1/8 its initial value.
I know that for an RLC Circuit,
q = Qe^(-Rt/2L)cos((w')(t) + phi)
and that
U = q^2 / 2C
Plugging in q, we have
U = (Q^2)(e^(-Rt/L))cos^2((w')(t) + phi)
I'm not sure where to go at this point. Ideally, I'd like to find the maximum of this function U(t), however I'm really confused about the "phi" aspect. What exactly is "phi" and what is it equal to in this case and why?
You can take the maximum of U at cos(w't+ phi) = 1. So the maximum energy is (Qe^(-Rt/2L))^2/(2C). Find the time when it falls 1/8 of the original value.
ehild
Related to Oscillating series RLC circuit
1. What is an oscillating series RLC circuit?
An oscillating series RLC circuit is an electronic circuit that consists of a resistor (R), inductor (L), and capacitor (C) connected in series. The circuit is designed to produce an oscillating current or voltage by utilizing the properties of the inductor and capacitor to store and release energy.
2. How does an oscillating series RLC circuit work?
When an AC voltage source is connected to an RLC circuit, the inductor and capacitor will store and release energy in a cyclical manner, causing the current and voltage to oscillate. The resistor serves to limit the current and dampen the oscillations. The frequency of the oscillations depends on the values of the inductor and capacitor, while the amplitude depends on the source voltage and the resistance.
3. What is resonance in an oscillating series RLC circuit?
Resonance in an oscillating series RLC circuit occurs when the inductive reactance (XL) and capacitive reactance (XC) cancel each other out, resulting in a purely resistive circuit. This causes the current to reach its maximum value while the voltage across the capacitor and inductor is at its minimum. Resonance can be achieved by adjusting the values of the inductor and capacitor to match the frequency of the AC source.
4. What are the applications of an oscillating series RLC circuit?
Oscillating series RLC circuits have a wide range of applications in electronics, including in filters, amplifiers, and oscillators. They are also used in radio and television tuners, where they are tuned to the frequency of the desired channel to select and amplify the signal. RLC circuits are also used in power supplies to regulate the output voltage.
5. How can I calculate the resonant frequency of an oscillating series RLC circuit?
The resonant frequency of an oscillating series RLC circuit can be calculated using the formula f = 1 / (2π√LC), where f is the resonant frequency in Hertz (Hz), L is the inductance in Henrys (H), and C is the capacitance in Farads (F). Alternatively, you can use an online calculator or software to determine the resonant frequency based on the values of L and C.
  • Electromagnetism
