Oscillation above the Surface of the Earth
In summary, the conversation discusses finding the period of a pendulum with a point mass on a massless string of length Lo, which has a period of 7.23 s on the surface of the Earth. It then asks to find the period of the same pendulum on a horizontal platform of height H = 2.23RE above the Earth's surface. Using the equations T = 2∏√(L/g) and g = G * Mass of Earth/R^2, it is determined that the period on the platform is √(7.23^2)(2.23)^2 = 16.1229. The conversation also discusses the correct value for r in the formula GMe/r^2
yaylee
A pendulum consists of point mass Mo swinging on a massless string of length Lo, with period To = 7.23 s on the surface of the Earth (at RE, the radius of the Earth). Find T1, the period of the same pendulum if it swings on a horizontal platform of height H = 2.23RE (stationary, not orbiting) above the Earth's surface.
T = 2∏√(L/g)
g = G * Mass of Earth/R^2, where R = radius of Earth
Squaring both sides of the Period, T, equation, we get,
T on surface of Earth: T^2 = 7.23^2 = 4∏^2(L/g), = 4∏^2(L)*R^2 / (G)(Mearth), and,
T at 2.23R above the Earth: T^2 = 4∏^2(L)*(2.23R)^2 / (G)(Mearth)
Dividing both equations, and solving for T, T = √(7.23^2)(2.23)^2 = 16.1229
Am I doing something wrong here? Many thanks in advance.
In the formula GMe/r2, what exactly is r?
Hi Haruspex,
This r should be (r PLUS 2.23R), or (R + 2.23R) = 3.23R ... Would I be correct here? Thank you for your assistance!
Go figure, it is! Thanks!
Your approach is correct. However, there seems to be an error in your calculation of T for the pendulum at 2.23R above the Earth's surface. It should be T = √(7.23^2)(2.23)^2 = 11.0756 s. This makes sense, as the period of a pendulum is proportional to the square root of its length, so increasing the length by a factor of 2.23 would result in a longer period. Additionally, your final answer should include the units of time (s), so the final answer would be T = 11.0756 s.
FAQ: Oscillation above the Surface of the Earth
1. What is oscillation above the surface of the Earth?
Oscillation above the surface of the Earth refers to the movement or vibration of an object or system that is located above the Earth's surface. This can include a variety of phenomena such as sound waves, seismic waves, and even the motion of satellites.
2. What causes oscillation above the surface of the Earth?
Oscillation above the surface of the Earth can be caused by a variety of factors, including the Earth's rotation, atmospheric pressure changes, and the movement of tectonic plates. It can also be caused by human activities such as industrial machinery and transportation.
3. How is oscillation above the surface of the Earth measured?
Oscillation above the surface of the Earth can be measured using various instruments such as seismometers and accelerometers. These devices record the movement or vibrations of the Earth's surface and can provide valuable data for scientific research.
4. What are the potential effects of oscillation above the surface of the Earth?
The effects of oscillation above the surface of the Earth can vary depending on the type and intensity of the oscillation. In some cases, it can cause damage to structures and infrastructure, while in others it can have a positive impact, such as in the case of renewable energy sources like wind turbines.
5. How does oscillation above the surface of the Earth impact our daily lives?
Oscillation above the surface of the Earth can have a significant impact on our daily lives, even if we are not always aware of it. For example, seismic waves can cause earthquakes, which can be destructive and have a lasting impact on communities. On a smaller scale, vibrations from transportation and machinery can also affect our daily activities and environments.
