Oscillation of a drumhead membrane
In summary: So, in order to find ##a##, you need to find the equilibrium displacement and then integrate over the cycle.
A13235378
50
A horizontal membrane oscillates harmoniously along a vertical axis with a frequency equal to w. Determine the amplitude of the oscillations, if a grain of sand that is on the membrane, when jumping from it, reaches a maximum height of H in relation to the equilibrium position of the membrane.
Energy conservation.
w^2 = k/m.
My attempt,
Considering that it jumps in the maximum compression position:
$$\frac{kA^2}{2} = mg(H+A)$$
replacing k / m with w ^ 2 :
$$A^2 w^2-2gA-2gH=0$$
Solving the second degree equation:
$$A=\frac{2g+\sqrt{4g^2+8gHw^2}}{2w^2}$$
But the answer is:
$$A=\frac{g}{w}\sqrt{\frac{2H}{g}-\frac{1}{w^2}}$$
After that, I can't go on. I've tried to develop to arrive at the equality of both expressions, but I couldn't. Where am I going wrong?
A13235378 said:
Homework Statement:: A horizontal membrane oscillates harmoniously along a vertical axis with a frequency equal to w. Determine the amplitude of the oscillations, if a grain of sand that is on the membrane, when jumping from it, reaches a maximum height of H in relation to the equilibrium position of the membrane.
Relevant Equations:: Energy conservation.
w^2 = k/m.
My attempt,
That's a false assumption.
The first thing to try is to assume that the sand leaves the membrane at the equilibrium point. See what you get.
If that's not the right answer, then have another think about when the sand does actually leave the membrane.
Not sure what your thinking is wrt the k and m you refer to.
From the RHS of your equation, it looks like m is the mass of the grain of sand. But that is unrelated to w. The oscillation of the membrane is not affected by the sand grain.
As @PeroK notes, you need to figure out the point in the cycle where the grain will lose contact with the surface. Think about forces and accelerations at that point.
@A13235378:
To elaborate on what has already been said.
A free body diagram of the grain at the time of separation will be extremely helpful when following the suggestions above. Remember that, if an object oscillates harmoniously, its acceleration ##a## as a function of displacement ##x## from the equilibrium position is ##a(x)=-\omega^2 x##.
FAQ: Oscillation of a drumhead membrane
What is the oscillation of a drumhead membrane?
The oscillation of a drumhead membrane refers to the back and forth movement of the membrane when it is struck or vibrated. This movement creates sound waves that are responsible for the sound produced by a drum.
How does the size of the drumhead membrane affect its oscillation?
The size of the drumhead membrane directly affects its oscillation. A larger membrane will have a lower frequency and produce a deeper sound, while a smaller membrane will have a higher frequency and produce a higher pitched sound.
What factors influence the rate of oscillation of a drumhead membrane?
The rate of oscillation of a drumhead membrane is influenced by several factors, including the tension of the membrane, the material it is made of, and the force with which it is struck. These factors determine the frequency and amplitude of the oscillation.
How does the tension of the drumhead membrane affect its oscillation?
The tension of the drumhead membrane plays a crucial role in its oscillation. A tighter membrane will have a higher frequency and produce a brighter sound, while a looser membrane will have a lower frequency and produce a duller sound.
What is the relationship between the oscillation of a drumhead membrane and the sound produced?
The oscillation of a drumhead membrane directly affects the sound produced. As the membrane vibrates, it creates sound waves that travel through the air and reach our ears. The frequency and amplitude of the oscillation determine the pitch and volume of the sound produced.
