songoku
- 2,319
- 331
A copper ring is suspended by a long, light rod pivoted at X so that it may swing as pendulum, as shown in the diagram below. An electromagnet is mounted so that the ring passes over it as it swings. The ring is set into oscillation with switch K open. What happens to the motion after switch K has been closed?
a. the periodic time will decrease
b. the oscillation will be heavily damped
c. the amplitude will increase because the ring is accelerated towards the magnet
d. the oscillation will continue at constant amplitude while the battery can supply energy
e. the ring will attracted to the magnet and stop moving
not sure
I think the answer will be (b). The motion will be damped because there will be induced current in the ring so some of the kinetic energy of the motion will be converted to thermal energy causing the movement of the ring becomes slower.
I am not sure why (a) is wrong. The periodic time will be constant? I don't know why
And by "heavily damped" does it mean the ring won't oscillate and takes a long time to go back to vertical position (equilibrium position)? If yes, so option (b) is also wrong?
Thanks
